hello i have reinstall my laptop yesterday in wifi the first module in installation take not too much time and the installation goes quickly.
today i try to reinstall my pc(another one) and the first module of installation time is big(now i’m waiting since ten minute).
i have try to install it with the same usb key than my laptop and with a dvd i burn to see it s the same problem.
is this a known problem ?
i have install several time this computer without any problem
please… without installlog or any info about the hardware, no one can help.
i transfer my data on a 2nd hdd and ai try again tonight i will send you the system log if it always do the same things
thanks
ju
does i have too install it to give you the install log or could i use the live cd?
Kernel: 6.7.1-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 dm: SDDM
Mobo: ASUSTeK model: TUF GAMING B550-PLUS v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3404
date: 10/07/2023
Battery:
Device-1: hidpp_battery_0 model: Logitech ERGO M575 Trackball
serial: <filter> charge: 100% status: discharging
Info: 6-core model: AMD Ryzen 5 5500 bits: 64 type: MT MCP arch: Zen 3
rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 720 high: 4242 min/max: 400/4267 cores: 1: 400 2: 4242
3: 400 4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400
bogomips: 86270
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Gigabyte
driver: amdgpu v: kernel arch: RDNA-2 pcie: speed: 16 GT/s lanes: 16 ports:
active: DP-1,HDMI-A-1,HDMI-A-2 empty: DP-2 bus-ID: 03:00.0
chip-ID: 1002:73ff
Display: server: X.Org v: 21.1.11 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 4880x1080 s-dpi: 96
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left
model: Idek Iiyama PLX2783H res: 1920x1080 dpi: 82 diag: 686mm (27")
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: center model: W2221A
res: 1680x1050 dpi: 90 diag: 559mm (22")
Monitor-3: HDMI-A-2 mapped: HDMI-A-1 pos: right model: NEC LCD1970NXp
res: 1280x1024 dpi: 86 diag: 482mm (19")
API: EGL v: 1.5 platforms: device: 0 drv: radeonsi device: 1 drv: swrast
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (radeonsi navi23
LLVM 16.0.6 DRM 3.56 6.7.1-arch1-1) device-ID: 1002:73ff
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-2: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 0e:00.1 chip-ID: 1002:1637
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK
bus-ID: 0e:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.7.1-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0d:00.0 chip-ID: 10ec:8125
IF: enp13s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 6.35 TiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 980 PRO 2TB size: 1.82 TiB
speed: 63.2 Gb/s lanes: 4 serial: <filter> temp: 26.9 C
ID-2: /dev/sda vendor: Seagate model: ST2000DM008-2UB102 size: 1.82 TiB
speed: 6.0 Gb/s serial: <filter>
ID-3: /dev/sdb vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
ID-4: /dev/sdc vendor: LDLC model: N/A size: 894.25 GiB type: USB rev: 2.1
spd: 480 Mb/s lanes: 1 serial: <filter>
ID-5: /dev/sdd vendor: SanDisk model: Cruzer Blade size: 14.91 GiB
type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 serial: <filter>
ID-1: / size: 10 GiB used: 135.7 MiB (1.3%) fs: overlay source: ERR-102
System Temperatures: cpu: 40.8 C mobo: N/A gpu: amdgpu temp: 30.0 C
mem: 30.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Processes: 333 Uptime: 6m Memory: total: 32 GiB note: est.
available: 31.14 GiB used: 4.22 GiB (13.6%) Init: systemd v: 255
default: multi-user Compilers: gcc: 13.2.1 Packages: pm: pacman pkgs: 978
Shell: Bash v: 5.2.26 running-in: konsole inxi: 3.3.31
here it is
This is only the hardware output of your system not an install log.
if you have installed and it failed the log is only stored on the live session after a reboot it will be lost. to provide the installer log ,share it directly after failed install (without rebooting) is needed.
the problem is that i couldn’t install it the installation blocked to the first module searching and the countdown continue an eternity without doing something and i install the same os on my laptop and it works,weird nope?
log would still give details about what is failing. in case…
And in most case such behavior on loading the installer indicates corrupted install media.
Be it the way install media is created or issues with the used hardware itself, or the port used…
