Problem with running Screaming Frog Spider (Java app)
What I would like to run:
There is a tool for SEO called Screaming Frog SEO Spider. There is no official package for Arch Linux, but it is available from the AUR (https://aur.archlinux.org/packages/screamingfrogseospider)
Problem:
The app crashes on “Initializing components” stage. Error from the terminal:
Summary
2022-12-09 13:20:33,200 [main] INFO - Creating Lock File: /home/dmytro/.ScreamingFrogSEOSpider/instance_locks/cfd3abd8-fe48-44e5-829e-79607f51ab6e.lck
2022-12-09 13:20:33,247 [main] INFO - Applying antialising fix
2022-12-09 13:20:34,567 [main] INFO - SfRoboto fonts loaded
2022-12-09 13:20:35,689 [JavaFX-Launcher] INFO - Persistent config file does not exist, /home/dmytro/.ScreamingFrogSEOSpider/spider.config
2022-12-09 13:20:36,196 [22226] [JavaFX-Launcher] INFO - Application Started
2022-12-09 13:20:36,278 [22226] [JavaFX-Launcher] ERROR - Error in SeoSpiderUi.initjava.lang.StringIndexOutOfBoundsException: begin -1, end 23, length 23
at java.lang.String.checkBoundsBeginEnd(String.java:4601) ~[?:?]
at java.lang.String.substring(String.java:2704) ~[?:?]
at java.lang.String.substring(String.java:2677) ~[?:?]
at uk.co.screamingfrog.utils.help.SfPlatformUtils.getLinuxDistro(SourceFile:92) ~[utils-1.0-SNAPSHOT.jar:?]
at uk.co.screamingfrog.utils.utils.SystemInfo.getPlatformInfo(SourceFile:133) ~[utils-1.0-SNAPSHOT.jar:?]
at uk.co.screamingfrog.utils.utils.SystemInfo.a(SourceFile:258) ~[utils-1.0-SNAPSHOT.jar:?]
at uk.co.screamingfrog.utils.utils.SystemInfo.dump(SourceFile:88) ~[utils-1.0-SNAPSHOT.jar:?]
at uk.co.screamingfrog.utils.boostrap.BootStrapper.bootStrap(SourceFile:62) ~[utils-1.0-SNAPSHOT.jar:?]
at seo.spider.ui.aK.a(SourceFile:49) ~[ScreamingFrogSEOSpider.jar:?]
at uk.co.screamingfrog.seospider.ui.b.a(SourceFile:294) ~[ScreamingFrogSEOSpider.jar:?]
at uk.co.screamingfrog.seospider.ui.b.init(SourceFile:141) ~[ScreamingFrogSEOSpider.jar:?]
at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:825) ~[javafx-graphics-17.0.3-ea+c15-linux.jar:?]
at com.sun.javafx.application.LauncherImpl.lambda$launchApplication$2(LauncherImpl.java:196) ~[javafx-graphics-17.0.3-ea+c15-linux.jar:?]
at java.lang.Thread.run(Thread.java:833) ~[?:?]
2022-12-09 13:20:36,296 [22226] [JavaFX-Launcher] ERROR - Exception in Application init method
2022-12-09 13:20:36,330 [22226] [JavaFX Application Thread] ERROR - Exception in thread “JavaFX Application Thread”
2022-12-09 13:20:36,331 [22226] [JavaFX Application Thread] ERROR - java.lang.IllegalStateException: The view has already been closed
2022-12-09 13:20:36,332 [22226] [JavaFX Application Thread] ERROR - at com.sun.glass.ui.View.checkNotClosed(View.java:435)
2022-12-09 13:20:36,333 [22226] [JavaFX Application Thread] ERROR - at com.sun.glass.ui.View.getX(View.java:471)
2022-12-09 13:20:36,334 [22226] [JavaFX Application Thread] ERROR - at com.sun.javafx.tk.quantum.SceneState.update(SceneState.java:109)
2022-12-09 13:20:36,335 [22226] [JavaFX Application Thread] ERROR - at com.sun.javafx.tk.quantum.GlassScene.updateSceneState(GlassScene.java:281)
2022-12-09 13:20:36,335 [22226] [JavaFX Application Thread] ERROR - at com.sun.javafx.tk.quantum.WindowStage.lambda$setScene$1(WindowStage.java:301)
2022-12-09 13:20:36,336 [22226] [JavaFX Application Thread] ERROR - at com.sun.javafx.tk.quantum.QuantumToolkit.runWithRenderLock(QuantumToolkit.java:442)
2022-12-09 13:20:36,336 [22226] [JavaFX Application Thread] ERROR - at com.sun.javafx.tk.quantum.WindowStage.setScene(WindowStage.java:294)
2022-12-09 13:20:36,336 [22226] [JavaFX Application Thread] ERROR - at javafx.stage.Window$12.invalidated(Window.java:1146)
2022-12-09 13:20:36,337 [22226] [JavaFX Application Thread] ERROR - at javafx.beans.property.BooleanPropertyBase.markInvalid(BooleanPropertyBase.java:110)
2022-12-09 13:20:36,337 [22226] [JavaFX Application Thread] ERROR - at javafx.beans.property.BooleanPropertyBase.set(BooleanPropertyBase.java:145)
2022-12-09 13:20:36,337 [22226] [JavaFX Application Thread] ERROR - at javafx.stage.Window.setShowing(Window.java:1190)
2022-12-09 13:20:36,338 [22226] [JavaFX Application Thread] ERROR - at javafx.stage.Window.hide(Window.java:1215)
2022-12-09 13:20:36,338 [22226] [JavaFX Application Thread] ERROR - at com.sun.javafx.stage.WindowPeerListener.closed(WindowPeerListener.java:105)
2022-12-09 13:20:36,338 [22226] [JavaFX Application Thread] ERROR - at com.sun.javafx.tk.quantum.GlassWindowEventHandler.run(GlassWindowEventHandler.java:144)
2022-12-09 13:20:36,338 [22226] [JavaFX Application Thread] ERROR - at com.sun.javafx.tk.quantum.GlassWindowEventHandler.run(GlassWindowEventHandler.java:40)
2022-12-09 13:20:36,339 [22226] [JavaFX Application Thread] ERROR - at java.base/java.security.AccessController.doPrivileged(AccessController.java:399)
2022-12-09 13:20:36,339 [22226] [JavaFX Application Thread] ERROR - at com.sun.javafx.tk.quantum.GlassWindowEventHandler.lambda$handleWindowEvent$4(GlassWindowEventHandler.java:178)
2022-12-09 13:20:36,339 [22226] [JavaFX Application Thread] ERROR - at com.sun.javafx.tk.quantum.QuantumToolkit.runWithoutRenderLock(QuantumToolkit.java:424)
2022-12-09 13:20:36,339 [22226] [JavaFX Application Thread] ERROR - at com.sun.javafx.tk.quantum.GlassWindowEventHandler.handleWindowEvent(GlassWindowEventHandler.java:176)
2022-12-09 13:20:36,340 [22226] [JavaFX Application Thread] ERROR - at com.sun.glass.ui.Window.handleWindowEvent(Window.java:1336)
2022-12-09 13:20:36,340 [22226] [JavaFX Application Thread] ERROR - at com.sun.glass.ui.Window.notifyDestroy(Window.java:1250)
2022-12-09 13:20:36,340 [22226] [JavaFX Application Thread] ERROR - at com.sun.glass.ui.gtk.GtkWindow._close(Native Method)
2022-12-09 13:20:36,340 [22226] [JavaFX Application Thread] ERROR - at com.sun.glass.ui.Window.close(Window.java:352)
2022-12-09 13:20:36,341 [22226] [JavaFX Application Thread] ERROR - at com.sun.glass.ui.Application.terminate(Application.java:397)
2022-12-09 13:20:36,341 [22226] [JavaFX Application Thread] ERROR - at com.sun.javafx.tk.quantum.QuantumToolkit.lambda$exit$13(QuantumToolkit.java:843)
2022-12-09 13:20:36,341 [22226] [JavaFX Application Thread] ERROR - at com.sun.javafx.tk.quantum.QuantumToolkit.runWithRenderLock(QuantumToolkit.java:442)
2022-12-09 13:20:36,341 [22226] [JavaFX Application Thread] ERROR - at com.sun.javafx.tk.quantum.QuantumToolkit.exit(QuantumToolkit.java:839)
2022-12-09 13:20:36,342 [22226] [JavaFX Application Thread] ERROR - at com.sun.javafx.application.PlatformImpl.lambda$tkExit$16(PlatformImpl.java:624)
2022-12-09 13:20:36,342 [22226] [JavaFX Application Thread] ERROR - at com.sun.javafx.application.PlatformImpl.lambda$runAndWait$12(PlatformImpl.java:484)
2022-12-09 13:20:36,342 [22226] [JavaFX Application Thread] ERROR - at com.sun.javafx.application.PlatformImpl.lambda$runLater$10(PlatformImpl.java:457)
2022-12-09 13:20:36,342 [22226] [JavaFX Application Thread] ERROR - at java.base/java.security.AccessController.doPrivileged(AccessController.java:399)
2022-12-09 13:20:36,343 [22226] [JavaFX Application Thread] ERROR - at com.sun.javafx.application.PlatformImpl.lambda$runLater$11(PlatformImpl.java:456)
2022-12-09 13:20:36,343 [22226] [JavaFX Application Thread] ERROR - at com.sun.glass.ui.InvokeLaterDispatcher$Future.run(InvokeLaterDispatcher.java:96)
2022-12-09 13:20:36,343 [22226] [JavaFX Application Thread] ERROR - at com.sun.glass.ui.gtk.GtkApplication._runLoop(Native Method)
2022-12-09 13:20:36,343 [22226] [JavaFX Application Thread] ERROR - at com.sun.glass.ui.gtk.GtkApplication.lambda$runLoop$11(GtkApplication.java:290)
2022-12-09 13:20:36,344 [22226] [JavaFX Application Thread] ERROR - at java.base/java.lang.Thread.run(Thread.java:833)
2022-12-09 13:20:36,345 [22226] [main] ERROR - Exception in thread “main”
2022-12-09 13:20:36,346 [22226] [main] ERROR - java.lang.RuntimeException: Exception in Application init method
2022-12-09 13:20:36,346 [22226] [main] ERROR - at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:896)
2022-12-09 13:20:36,346 [22226] [main] ERROR - at com.sun.javafx.application.LauncherImpl.lambda$launchApplication$2(LauncherImpl.java:196)
2022-12-09 13:20:36,347 [22226] [main] ERROR - at java.base/java.lang.Thread.run(Thread.java:833)
2022-12-09 13:20:36,347 [22226] [main] ERROR - Caused by: java.lang.NullPointerException: Cannot invoke “java.lang.Thread$UncaughtExceptionHandler.uncaughtException(java.lang.Thread, java.lang.Throwable)” because the return value of “java.lang.Thread.getDefaultUncaughtExceptionHandler()” is null
2022-12-09 13:20:36,347 [22226] [main] ERROR - at uk.co.screamingfrog.seospider.ui.b.init(SourceFile:163)
2022-12-09 13:20:36,348 [22226] [main] ERROR - at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:825)
2022-12-09 13:20:36,348 [22226] [main] ERROR - … 2 more
2022-12-09 13:20:36,350 [22226] [ShutdownHook] INFO - Shutting down: Logger
List of installed packages:
Summary
a52dec 0.7.4-11
aalib 1.4rc5-14
abseil-cpp 20220623.1-1
accountsservice 22.08.8-2
acl 2.3.1-2
adobe-source-code-pro-fonts 2.038ro+1.058it+1.018var-1
adobe-source-han-sans-cn-fonts 2.004-1
adobe-source-han-sans-jp-fonts 2.004-1
adobe-source-han-sans-kr-fonts 2.004-1
adwaita-cursors 43-2
adwaita-icon-theme 43-2
alsa-card-profiles 1:0.3.61-1
alsa-firmware 1.2.4-2
alsa-lib 1.2.8-1
alsa-plugins 1:1.2.7.1-1
alsa-topology-conf 1.2.5.1-1
alsa-ucm-conf 1.2.8-1
alsa-utils 1.2.8-1
amtk 5.6.1-1
aom 3.5.0-1
arc-gtk-theme-eos 20220405-1
archlinux-keyring 20221123-1
argon2 20190702-4
at-spi2-core 2.46.0-2
atkmm 2.28.3-1
attr 2.5.1-2
audit 3.0.8-1
autoconf 2.71-1
automake 1.16.5-1
avahi 0.8+22+gfd482a7-3
b43-fwcutter 019-3
babl 0.1.98-1
base 3-1
bash 5.1.016-1
bash-completion 2.11-3
bind 9.18.9-1
binutils 2.39-3
bison 3.8.2-4
blas 3.11.0-1
bluez 5.66-1
bluez-libs 5.66-1
bluez-utils 5.66-1
bolt 0.9.4-1
boost-libs 1.80.0-3
box2d 2.4.1-1
bridge-utils 1.7.1-1
brotli 1.0.9-9
btrfs-progs 6.0.2-1
bubblewrap 0.7.0-1
bzip2 1.0.8-5
c-ares 1.18.1-1
ca-certificates 20220905-1
ca-certificates-mozilla 3.85-1
ca-certificates-utils 20220905-1
cairo 1.17.6-2
cairomm 1.14.4-1
cantarell-fonts 1:0.303.1-1
cdparanoia 10.2-8
chromaprint 1.5.1-5
cifs-utils 7.0-1
clucene 2.3.3.4-12
code 1.73.1-1
colord 1.4.6-1
colord-gtk-common 0.3.0-2
colord-gtk4 0.3.0-2
containerd 1.6.10-1
coreutils 9.1-3
cracklib 2.9.8-1
cryptsetup 2.6.0-1
cups-pk-helper 0.2.7-1
curl 7.86.0-4
dav1d 1.0.0-1
db 5.3.28-5
dbus 1.14.4-1
dbus-glib 0.112-2
dbus-python 1.2.18-3
dconf 0.40.0-2
debtap 3.5.1-1
debugedit 5.0-4
default-cursors 1-1
desktop-file-utils 0.26-2
device-mapper 2.03.17-1
dhclient 4.4.3.P1-1
dialog 1:1.3_20220728-1
diffutils 3.8-1
ding-libs 0.6.2-1
djvulibre 3.5.28-3
dkms 3.0.8-1
dmidecode 3.4-1
dmraid 1.0.0.rc16.3-14
dnsmasq 2.87-3
dnssec-anchors 20190629-3
docker 1:20.10.21-1
dosfstools 4.2-2
double-conversion 3.2.1-1
downgrade 11.2.1-1
duf 0.8.1-2
duktape 2.7.0-4
e2fsprogs 1.46.5-4
efibootmgr 18-1
efitools 1.9.2-5
efivar 38-2
electron19 19.1.4-3
elfutils 0.188-1
ell 0.54-1
enchant 2.3.3-2
endeavouros-keyring 20220614-1
endeavouros-mirrorlist 4.10-1
endeavouros-theming 22.09.3.2-1
eog 43.1-1
eos-apps-info 1.4-2
eos-bash-shared 1.35-1
eos-hooks 1.8-1
eos-log-tool 1.14-1
eos-packagelist 2.0-1
eos-qogir-icons 4-2
eos-quickstart 1.3-5
eos-rankmirrors 2.10-1
eos-translations 1.20-1
eos-update-notifier 1.17-1
ethtool 1:6.0-1
evince 43.1-1
exempi 2.6.2-1
exfatprogs 1.2.0-1
exiv2 0.27.5-3
expat 2.5.0-1
f2fs-tools 1.15.0-2
faac 1.30-3
faad2 2.10.1-1
fakeroot 1.30.1-1
ffmpeg 2:5.1.2-1
ffmpeg4.4 4.4.2-3
ffmpegthumbnailer 2.2.2-4
file 5.43-1
file-roller 43.0-1
filesystem 2022.10.18-1
findutils 4.9.0-1
firefox 107.0.1-1
firewalld 1.2.1-1
flac 1.4.2-1
flex 2.6.4-3
fluidsynth 2.3.0-2
fontconfig 2:2.14.1-2
freeglut 3.4.0-1
freetype2 2.12.1-1
fribidi 1.0.12-1
fsarchiver 0.8.6-1
fuse-common 3.12.0-1
fuse2 2.9.9-4
fuse3 3.12.0-1
fzf 0.35.1-1
gawk 5.2.1-1
gc 8.2.2-1
gcc 12.2.0-1
gcc-libs 12.2.0-1
gconf 3.2.6+11+g07808097-10
gcr 3.41.1-3
gcr-4 4.0.0-1
gd 2.3.3-5
gdbm 1.23-1
gdk-pixbuf2 2.42.10-1
gdm 43.0-1
gedit 43.2-2
gegl 0.4.40-1
geoclue 2.6.0-3
geocode-glib-2 3.26.4-2
geocode-glib-common 3.26.4-2
geoip 1.6.12-2
geoip-database 20221118-1
gettext 0.21.1-2
ghostscript 10.0.0-2
giflib 5.2.1-2
git 2.38.1-2
gjs 2:1.74.1-1
glances 3.3.0-1
glib-networking 1:2.74.0-1
glib2 2.74.2-2
glibc 2.36-6
glibmm 2.66.5-1
glibmm-2.68 2.74.0-1
glu 9.0.2-3
gmp 6.2.1-2
gnome-autoar 0.4.3-2
gnome-bluetooth-3.0 42.4-1
gnome-calculator 43.0.1-1
gnome-color-manager 3.36.0+r42+g90481514-1
gnome-control-center 43.1-2
gnome-desktop 1:43-1
gnome-desktop-4 1:43-1
gnome-desktop-common 1:43-1
gnome-disk-utility 43.0-1
gnome-keyring 1:42.1-2
gnome-nettool 42.0-1
gnome-online-accounts 3.46.0-1
gnome-power-manager 43.0-1
gnome-screenshot 41.0+r25+g45f08f0-1
gnome-session 43.0-1
gnome-settings-daemon 43.0-2
gnome-shell 1:43.1+r6+g92e9689a4-1
gnome-terminal 3.46.6-1
gnome-themes-extra 3.28+r6+g45b1d457-1
gnome-tweaks 42beta+r14+g2d9d76c-2
gnome-usage 3.38.1-1
gnu-netcat 0.7.1-8
gnupg 2.2.40-1
gnutls 3.7.8-4
gobject-introspection-runtime 1.74.0-1
gpgme 1.18.0-1
gpm 1.20.7.r38.ge82d1a6-4
gptfdisk 1.0.9-2
graphene 1.10.8-1
graphicsmagick 1.3.38-5
graphite 1:1.3.14-2
graphviz 7.0.3-1
grep 3.8-2
grilo 0.3.15-2
groff 1.22.4-7
grub 2:2.06.r380.g151467888-1
gsettings-desktop-schemas 43.0-1
gsfonts 20200910-2
gsm 1.0.22-1
gsound 1.0.3-2
gspell 1.12.0-2
gssdp 1.6.2-1
gssproxy 0.9.1-2
gst-libav 1.20.4-3
gst-plugin-gtk 1.20.4-3
gst-plugin-pipewire 1:0.3.61-1
gst-plugins-bad 1.20.4-3
gst-plugins-bad-libs 1.20.4-3
gst-plugins-base 1.20.4-3
gst-plugins-base-libs 1.20.4-3
gst-plugins-good 1.20.4-3
gst-plugins-ugly 1.20.4-3
gstreamer 1.20.4-3
gtk-update-icon-cache 1:4.8.2-1
gtk2 2.24.33-2
gtk3 1:3.24.35-2
gtk4 1:4.8.2-1
gtkmm3 3.24.7-1
gtksourceview3 1:3.24.11+r28+g73e57b57-1
gtksourceview4 4.8.4-1
gtksourceview5 5.6.1-1
gts 0.7.6.121130-2
guile 3.0.8-3
gupnp 1:1.6.2-1
gupnp-dlna 0.12.0-2
gupnp-igd 1.2.0-3
gvfs 1.50.2-1
gvfs-afc 1.50.2-1
gvfs-gphoto2 1.50.2-1
gvfs-mtp 1.50.2-1
gvfs-nfs 1.50.2-1
gvfs-smb 1.50.2-1
gzip 1.12-1
harfbuzz 5.3.1-3
harfbuzz-icu 5.3.1-3
haveged 1.9.18-1
hdparm 9.65-1
hicolor-icon-theme 0.17-2
hidapi 0.12.0-1
htop 3.2.1-1
hunspell 1.7.1-1
hwdata 0.364-1
hwdetect 2022.11-1
hwinfo 22.1-1
hyphen 2.8.8-5
iana-etc 20221107-1
icu 72.1-2
ijs 0.35-5
imagemagick 7.1.0.52-1
imath 3.1.6-1
imlib2 1.9.1-2
inetutils 2.3-1
iniparser 4.1-4
intel-ucode 20221108-1
inxi 3.3.23.1-1
iproute2 6.0.0-1
iptables-nft 1:1.8.8-2
iputils 20221126-1
iso-codes 4.12.0-1
iw 5.19-1
iwd 2.0-1
jansson 2.14-2
jasper 3.0.6-1
java-environment-common 3-3
java-runtime-common 3-3
java17-openjfx 17.0.5.u1-1
jbig2dec 0.19-1
jdk8-openjdk 8.352.u08-2
jemalloc 1:5.3.0-1
jfsutils 1.1.15-8
jre11-openjdk 11.0.17.u1-1
jre11-openjdk-headless 11.0.17.u1-1
jre17-openjdk 17.0.5.u1-1
jre17-openjdk-headless 17.0.5.u1-1
jre8-openjdk 8.352.u08-2
jre8-openjdk-headless 8.352.u08-2
js102 102.4.0-1
json-c 0.16-1
json-glib 1.6.6-2
kbd 2.5.1-1
keyutils 1.6.3-1
kmod 30-3
krb5 1.20-3
l-smash 2.14.5-2
lame 3.100-4
lapack 3.11.0-1
lcms2 2.14-1
ldb 2:2.6.1-1
ldns 1.8.3-2
lensfun 1:0.3.3-1
less 1:608-1
libabw 0.1.3-3
libadwaita 1:1.2.0-1
libaio 0.3.113-1
libarchive 3.6.1-5
libass 0.16.0-1
libassuan 2.5.5-1
libasyncns 1:0.8+r3+g68cd5af-2
libatasmart 0.19-5
libatomic_ops 7.6.14-1
libavc1394 0.5.4-4
libavif 0.11.1-1
libavtp 0.2.0-1
libb2 0.98.1-2
libblockdev 2.28-1
libbluray 1.3.3-1
libbpf 1.0.1-1
libbs2b 3.1.0-8
libbsd 0.11.7-1
libbytesize 2.7-1
libcaca 0.99.beta20-1
libcamera 0.0.2-1
libcanberra 1:0.30+r2+gc0620e4-2
libcap 2.66-1
libcap-ng 0.8.3-1
libcdio 2.1.0-3
libcdio-paranoia 10.2+2.0.1-2
libcdr 0.1.7-5
libcloudproviders 0.3.1+r8+g3a229ee-1
libcolord 1.4.6-1
libcue 2.2.1-2
libcups 1:2.4.2-3
libdaemon 0.14-5
libdatrie 0.2.13-2
libdazzle 3.44.0-1
libdc1394 2.2.6-2
libdca 0.0.7-1
libde265 1.0.9-1
libdispatch 5.5.0-1
libdrm 2.4.114-1
libdv 1.0.0-9
libdvdcss 1.4.3-1
libdvdnav 6.1.1-1
libdvdread 6.1.3-1
libe-book 0.1.3-13
libedit 20210910_3.1-2
libelf 0.188-1
libepoxy 1.5.10-1
libepubgen 0.1.1-4
libetonyek 0.1.10-2
libevdev 1.13.0-1
libevent 2.1.12-4
libexif 0.6.24-1
libexttextcat 3.4.6-1
libfdk-aac 2.0.2-1
libffi 3.4.4-1
libfontenc 1.1.6-1
libfreeaptx 0.1.1-1
libfreehand 0.1.2-4
libgcrypt 1.10.1-2
libgdm 43.0-1
libgee 0.20.6-1
libgexiv2 0.14.0-3
libglvnd 1.5.0-1
libgme 0.6.3-1
libgnomekbd 1:3.28.1-1
libgpg-error 1.46-2
libgphoto2 2.5.30-1
libgrss 0.7.0+16+g971c421-3
libgsf 1.14.50-1
libgtop 2.40.0+2+g31db82ef-2
libgudev 237-2
libgusb 0.4.2-1
libgweather-4 4.2.0-1
libgxps 0.3.2-2
libhandy 1.8.0-1
libheif 1.14.0-1
libibus 1.5.27-1
libical 3.0.16-2
libice 1.0.10-4
libidn 1.41-1
libidn2 2.3.4-3
libiec61883 1.2.0-6
libimobiledevice 1.3.0-5
libinih 56-1
libinput 1.22.0-1
libinstpatch 1.1.6-1
libiptcdata 1.0.5-1
libisl 0.25-1
libixion 0.17.0-3
libjpeg-turbo 2.1.4-2
libkate 0.4.1-8
libksba 1.6.2-1
liblangtag 0.6.4-1
libldac 2.0.2.3-1
libldap 2.6.3-2
liblqr 0.4.2-3
liblrdf 0.6.1-4
libltc 1.3.2-1
libmalcontent 0.11.0-1
libmanette 0.2.6-3
libmaxminddb 1.7.1-1
libmbim 1.28.2-1
libmd 1.0.4-1
libmfx 22.4.4-1
libmicrodns 0.2.0-1
libmm-glib 1.20.2-1
libmng 2.0.3-3
libmnl 1.0.5-1
libmodplug 0.8.9.0-3
libmpc 1.2.1-2
libmpcdec 1:0.1+r475-3
libmpeg2 0.5.1-7
libmspub 0.1.4-13
libmtp 1.1.20-1
libmwaw 0.3.21-3
libmypaint 1.6.1-1
libnautilus-extension 43.0-1
libndp 1.8-1
libnet 1:1.1.6-1
libnetfilter_conntrack 1.0.9-1
libnewt 0.52.23-1
libnfnetlink 1.0.2-1
libnfs 5.0.2-1
libnftnl 1.2.4-1
libnghttp2 1.51.0-1
libnice 0.1.19-1
libnl 3.7.0-1
libnm 1.40.6-1
libnma 1.10.4-3
libnma-common 1.10.4-3
libnma-gtk4 1.10.4-3
libnotify 0.8.1-1
libnsl 2.0.0-2
libnumbertext 1.0.11-1
liboauth 1:1.0.3+r16+gc26f038-1
libodfgen 0.1.8-2
libogg 1.3.5-1
libomxil-bellagio 0.9.3-3
libopenmpt 0.6.6-2
libopenraw 0.3.2-1
liborcus 0.17.2-3
libosinfo 1.10.0-2
libp11-kit 0.24.1-1
libpagemaker 0.0.4-3
libpaper 1.1.28-2
libpcap 1.10.1-2
libpciaccess 0.17-1
libpeas 1.34.0-1
libpgm 5.3.128-2
libpipeline 1.5.7-1
libplist 2.2.0-5
libpng 1.6.39-1
libportal 0.6-1
libportal-gtk3 0.6-1
libportal-gtk4 0.6-1
libproxy 0.4.18-1
libpsl 0.21.1-3
libpulse 16.1-3
libpwquality 1.4.5-1
libqmi 1.32.2-1
libqrtr-glib 1.2.2-2
libqxp 0.0.2-9
libraqm 0.9.0-1
libraw 0.20.2-2
libraw1394 2.1.2-3
libreoffice-still 7.3.7-1
librest 0.9.1-2
librevenge 0.0.4-5
librsvg 2:2.55.1-1
libsamplerate 0.2.2-1
libsasl 2.1.28-3
libseccomp 2.5.4-1
libsecret 0.20.5-2
libshout 1:2.4.6-2
libsidplay 1.36.59-10
libsigc++ 2.10.8-1
libsigc+±3.0 3.2.0-1
libsm 1.2.3-3
libsndfile 1.1.0-3
libsodium 1.0.18-2
libsoup 2.74.3-1
libsoup3 3.2.2-1
libsoxr 0.1.3-2
libspectre 0.2.11-1
libspiro 1:20221101-1
libsrtp 1:2.4.2-1
libssh 0.10.4-3
libssh2 1.10.0-3
libstaroffice 0.0.7-2
libstemmer 2.2.0-2
libsynctex 2022.62885-3
libsysprof-capture 3.46.0-1
libtasn1 4.19.0-1
libteam 1.31-7
libthai 0.1.29-2
libtheora 1.1.1-5
libtiff 4.4.0-4
libtirpc 1.3.3-2
libtommath 1.2.0-3
libtool 2.4.7-5
libunistring 1.1-2
libunwind 1.6.2-2
liburcu 0.13.2-1
libusb 1.0.26-1
libusbmuxd 2.0.2-1
libutempter 1.2.1-3
libuv 1.44.2-1
libva 2.16.0-1
libvdpau 1.5-1
libverto 0.3.2-4
libvisio 0.1.7-8
libvisual 0.4.0-8
libvorbis 1.3.7-3
libvpx 1.12.0-2
libwacom 2.5.0-1
libwebp 1.2.4-1
libwireplumber 0.4.12-2
libwmf 0.2.12-2
libwnck3 43.0-3
libwpd 0.10.3-4
libwpe 1.14.0-1
libwpg 0.3.3-4
libwps 0.4.13-1
libx11 1.8.2-2
libx86emu 3.5-2
libxau 1.0.10-2
libxaw 1.0.14-1
libxcb 1.15-2
libxcomposite 0.4.5-4
libxcrypt 4.4.33-1
libxcursor 1.2.1-3
libxcvt 0.1.2-1
libxdamage 1.1.5-5
libxdmcp 1.1.4-1
libxext 1.3.5-1
libxfixes 6.0.0-2
libxfont2 2.0.6-1
libxft 2.3.7-1
libxi 1.8-2
libxinerama 1.1.5-1
libxkbcommon 1.4.1-2
libxkbcommon-x11 1.4.1-2
libxkbfile 1.1.1-1
libxklavier 5.4-3
libxml2 2.10.3-2
libxmu 1.1.4-1
libxpm 3.5.14-1
libxrandr 1.5.3-1
libxrender 0.9.11-1
libxres 1.2.1-1
libxshmfence 1.3.1-1
libxslt 1.1.37-2
libxss 1.2.3-4
libxt 1.2.1-1
libxtst 1.2.4-1
libxv 1.0.11-5
libxvmc 1.0.13-1
libxxf86vm 1.1.5-1
libyaml 0.2.5-1
libyuv r2322+3aebf69d-1
libzmf 0.0.2-13
licenses 20220125-1
lilv 0.24.20-1
linux 6.0.10.arch2-1
linux-api-headers 5.18.15-1
linux-firmware 20221109.60310c2-2
linux-firmware-whence 20221109.60310c2-2
linux-headers 6.0.10.arch2-1
llvm-libs 14.0.6-4
lm_sensors 1:3.6.0.r41.g31d1f125-2
lmdb 0.9.29-1
logrotate 3.20.1-1
lpsolve 5.5.2.11-2
lsb-release 2.0.r48.3cf5103-1
lsscsi 0.32-1
lua 5.4.4-2
lua53 5.3.6-1
luajit 2.1.0.beta3.r457.g637721d0-1
luit 20221028-1
lv2 1.18.10-1
lvm2 2.03.17-1
lz4 1:1.9.4-1
lzo 2.10-4
m4 1.4.19-1
mailcap 2.1.53-1
make 4.3-5
man-db 2.11.1-1
man-pages 6.01-1
md4c 0.4.8-1
mdadm 4.2-2
meld 3.22.0-1
mesa 22.2.3-1
mesa-utils 8.5.0-2
minizip 1:1.2.13-2
mjpegtools 2.2.1-1
mkinitcpio 33-1
mkinitcpio-busybox 1.35.0-1
mkinitcpio-nfs-utils 0.3-7
mkinitcpio-openswap 0.1.0-3
mlocate 0.26.git.20170220-7
mobile-broadband-provider-info 20221107-1
modemmanager 1.20.2-1
mpfr 4.1.1.p1-1
mpg123 1.31.1-1
mtdev 1.1.6-2
mtools 1:4.0.42-1
mutter 43.1+r2+g6a962803e-2
mypaint-brushes1 1.3.1-1
nano 7.0-1
nano-syntax-highlighting 2020.10.10-1
nautilus 43.0-1
nautilus-sendto 3.8.6+28+gc87aac4-1
nawk 20220912-1
nbd 3.24-1
ncurses 6.3-3
ndctl 74-1
ndisc6 1.0.6-1
neofetch 7.1.0-2
neon 0.32.4-2
netctl 1.28-1
netpbm 10.73.41-1
nettle 3.8.1-1
networkmanager 1.40.6-1
networkmanager-openvpn 1.10.2-1
nfs-utils 2.6.2-1
nfsidmap 2.6.2-1
nftables 1:1.0.5-1
nilfs-utils 2.2.9-1
nmap 7.93-1
nomachine 8.2.3-1
noto-fonts 20220810-1
noto-fonts-emoji 20220920-1
npth 1.6-3
nspr 4.35-1
nss 3.85-1
nss-mdns 0.15.1-1
ntfs-3g 2022.10.3-1
ntp 4.2.8.p15-2
oath-toolkit 2.6.7-1
ocl-icd 2.3.1-1
openal 1.22.2-1
openconnect 1:9.01-2
opencore-amr 0.1.6-1
openexr 3.1.5-1
openjpeg2 2.5.0-1
openresolv 3.12.0-1
openssh 9.1p1-3
openssl 3.0.7-2
openssl-1.1 1.1.1.s-2
openvpn 2.5.8-2
opera 93.0.4585.37-1
opus 1.3.1-3
orc 0.4.33-1
os-prober 1.81-1
osinfo-db 20221018-1
p11-kit 0.24.1-1
pacman 6.0.2-5
pacman-contrib 1.8.0-1
pacman-mirrorlist 20221016-1
pacutils 0.11.1-1
pahole 1:1.24-1
pam 1.5.2-1
pambase 20221020-1
pango 1:1.50.12-1
pangomm 2.46.3-1
parallel 20221122-1
parted 3.5-1
patch 2.7.6-8
pavucontrol 1:5.0+r61+gee77d86-2
pciutils 3.9.0-1
pcre 8.45-3
pcre2 10.40-3
pcsclite 1.9.9-1
perl 5.36.0-1
perl-clone 0.45-4
perl-encode-locale 1.05-9
perl-error 0.17029-4
perl-file-listing 6.15-2
perl-html-parser 3.80-1
perl-html-tagset 3.20-12
perl-http-cookies 6.10-3
perl-http-daemon 6.14-2
perl-http-date 6.05-5
perl-http-message 6.44-1
perl-http-negotiate 6.01-10
perl-io-html 1.004-3
perl-libwww 6.67-1
perl-lwp-mediatypes 6.04-2
perl-mailtools 2.21-6
perl-net-http 6.22-2
perl-timedate 2.33-4
perl-try-tiny 0.31-2
perl-uri 5.17-1
perl-www-robotrules 6.02-10
perl-xml-parser 2.46-4
perl-xml-writer 0.900-1
photoflare 1.6.11-1
pinentry 1.2.1-1
pipewire 1:0.3.61-1
pipewire-alsa 1:0.3.61-1
pipewire-audio 1:0.3.61-1
pipewire-jack 1:0.3.61-1
pipewire-pulse 1:0.3.61-1
pixman 0.42.2-1
pkcs11-helper 1.29.0-2
pkgconf 1.8.0-1
pkgfile 21-2
polkit 122-1
poppler 22.11.0-1
poppler-data 0.4.11-3
poppler-glib 22.11.0-1
popt 1.19-1
portaudio 1:19.7.0-1
power-profiles-daemon 0.12-1
ppp 2.4.9-3
pptpclient 1.10.0-2
procps-ng 3.3.17-1
protobuf 21.10-1
psmisc 23.5-1
pv 1.6.20-2
python 3.10.8-3
python-cairo 1.23.0-1
python-capng 0.8.3-1
python-colorama 0.4.6-1
python-defusedxml 0.7.1-4
python-future 0.18.2-7
python-gobject 3.42.2-1
python-packaging 21.3-1
python-ply 3.11-10
python-psutil 5.9.4-1
python-pyaml 21.10.1-1
python-pyparsing 3.0.9-1
python-pyqt5 5.15.7-3
python-pyqt5-sip 12.11.0-1
python-shtab 1.5.8-1
python-termcolor 2.1.0-1
python-yaml 6.0-1
qrencode 4.1.1-1
qt5-base 5.15.7+kde+r176-1
qt5-imageformats 5.15.7+kde+r6-1
qt5-translations 5.15.7-1
qt6-5compat 6.4.1-1
qt6-base 6.4.1-1
qt6-declarative 6.4.1-1
qt6-imageformats 6.4.1-1
qt6-svg 6.4.1-1
qt6-translations 6.4.1-1
qt6-wayland 6.4.1-1
r8168 8.051.02-1
raptor 2.0.15-21
rasqal 1:0.9.33-5
rav1e 0.5.1-2
re2 1:20220601-1
readline 8.2.001-1
rebuild-detector 4.4.1-2
redland 1:1.0.17-8
reflector 2021.11-5
reflector-simple 2022.09.01-1
reiserfsprogs 3.6.27-3
ripgrep 13.0.0-2
rnnoise 0.4.1-1
rp-pppoe 3.15-2
rpcbind 1.2.6-3
rpm-tools 4.18.0-1
rsync 3.2.7-2
rtkit 0.13-2
rtmpdump 1:2.4.r99.f1b83c1-2
run-parts 5.5-1
runc 1.1.4-1
s-nail 14.9.24-2
sbc 2.0-1
screamingfrogseospider 18.0-1
sdl2 2.26.0-1
sed 4.9-1
serd 0.30.16-1
sg3_utils 1.47-1
shadow 4.12.3-2
shared-mime-info 2.0+155+gf4e7cbc-1
slang 2.3.3-1
smartmontools 7.3-1
smbclient 4.17.3-1
snappy 1.1.9-2
sof-firmware 2.2.2-1
sord 0.16.14-1
sound-theme-freedesktop 0.8-5
soundtouch 2.3.2-1
spandsp 0.0.6-3
speex 1.2.1-1
speexdsp 1.2.1-1
sqlite 3.40.0-1
sratom 0.6.14-1
srt 1.5.1-3
sshfs 3.7.3-1
startup-notification 0.12-7
stoken 0.92-4
sudo 1.9.12.p1-1
suitesparse 6.0.1-1
sushi 43.0-1
svt-av1 1.3.0-1
svt-hevc 1.5.1-2
sysfsutils 2.1.1-1
systemd 252.2-2
systemd-libs 252.2-2
systemd-sysvcompat 252.2-2
taglib 1.13-1
talloc 2.3.4-1
tar 1.34-1
tcl 8.6.13-1
tdb 1.4.7-1
telegram-desktop 4.3.4-1
tepl 1:6.2.0-3
tevent 1:0.13.0-1
texinfo 7.0-1
thin-provisioning-tools 0.9.0-1
tldr 3.1.0-2
totem 43.0-2
totem-pl-parser 3.26.6-2
tpm2-tss 3.2.0-3
tracker3 3.4.1-1
tracker3-miners 3.4.1-1
tslib 1.22-1
ttf-bitstream-vera 1.10-14
ttf-dejavu 2.37+18+g9b5d1b2f-3
ttf-liberation 2.1.5-1
ttf-opensans 1.101-2
twolame 0.4.0-2
tzdata 2022g-1
uchardet 0.0.7-1
udisks2 2.9.4-1
unrar 1:6.2.2-1
unzip 6.0-19
upower 1.90.0-1
usb_modeswitch 2.6.1-3
usbmuxd 1.1.1-1
usbutils 015-1
util-linux 2.38.1-1
util-linux-libs 2.38.1-1
v4l-utils 1.22.1-1
vi 1:070224-6
vid.stab 1.1-3
vmaf 2.3.1-1
volume_key 0.3.12-7
vpnc 1:0.5.3.r506.r204-2
vte-common 0.70.1-1
vte3 0.70.1-1
vulkan-headers 1:1.3.235-1
vulkan-icd-loader 1.3.235-1
wavpack 5.5.0-1
wayland 1.21.0-2
webkit2gtk 2.38.2-2
webkit2gtk-4.1 2.38.2-2
webp-pixbuf-loader 0.0.7-1
webrtc-audio-processing 0.3.1-3
welcome 3.43-1
wget 1.21.3-1
which 2.21-5
whois 5.5.14-1
wildmidi 0.4.4-1
wireless-regdb 2022.08.12-1
wireless_tools 30.pre9-3
woff2 1.0.2-4
wpa_supplicant 2:2.10-7
wpebackend-fdo 1.14.0-1
x264 3:0.164.r3095.baee400-4
x265 3.5-3
xbitmaps 1.1.2-3
xcb-proto 1.15.2-2
xcb-util 0.4.0-4
xcb-util-cursor 0.1.4-1
xcb-util-image 0.4.1-2
xcb-util-keysyms 0.4.1-4
xcb-util-renderutil 0.3.10-1
xcb-util-wm 0.4.2-1
xdg-dbus-proxy 0.1.4-1
xdg-desktop-portal 1.15.0-1
xdg-desktop-portal-gnome 43.1-1
xdg-desktop-portal-gtk 1.14.1-1
xdg-user-dirs 0.18-1
xdg-user-dirs-gtk 0.11-1
xdg-utils 1.1.3+25+g8ae0263-1
xf86-input-libinput 1.2.1-1
xf86-video-amdgpu 22.0.0-1
xf86-video-ati 1:19.1.0.r15.g7a6a34af-1
xf86-video-intel 1:2.99.917+916+g31486f40-2
xfsprogs 6.0.0-1
xkeyboard-config 2.37-1
xl2tpd 1.3.18-1
xmlsec 1.2.37-1
xorg-fonts-encodings 1.0.6-1
xorg-server 21.1.4-1
xorg-server-common 21.1.4-1
xorg-setxkbmap 1.3.3-1
xorg-xauth 1.1.2-1
xorg-xdpyinfo 1.3.3-4
xorg-xhost 1.0.8-3
xorg-xinit 1.4.1-3
xorg-xinput 1.6.3-3
xorg-xkbcomp 1.4.5-1
xorg-xkill 1.0.6-1
xorg-xmodmap 1.0.11-1
xorg-xprop 1.2.5-1
xorg-xrandr 1.5.1-2
xorg-xrdb 1.2.1-1
xorg-xset 1.2.4-3
xorg-xwayland 22.1.5-1
xorgproto 2022.2-1
xterm 377-1
xvidcore 1.3.7-2
xxhash 0.8.1-3
xz 5.2.8-1
yad-eos 12.1-1.1
yay 11.3.1-1
zbar 0.23.90-1
zenity 3.43.0-1
zeromq 4.3.4-2
zimg 3.0.4-1
zip 3.0-10
zlib 1:1.2.13-2
zstd 1.5.2-7
zvbi 0.2.37-1
zxing-cpp 1.4.0-1
What I’ve tried already:
  • Uninstalling the Screaming Frog and installing it again via yay -S screamingfrogseospider
  • Updating all other packages
  • Running it on a Virtual Machine with Manjaro (fresh install & updated all packages) - worked fine. Tried the same again on EOS (on a VM as well) - same error
  • As far as I can tell, it comes with its own JRE (I’m not 100% sure though). I’ve tried switching the default JRE via archlinux-java set to Java 8, Java 11, Java 17
  • Copying the .ScreamingFrogSEOSpider folder from root on the Manjaro to my system. I thought that some configs are missing or invalid because error tells it has issues with “getLinuxDistro”
Hello,
The Screaming Frog fails to start because it expects the PRETTY_NAME from /etc/os-release to be quoted, but it will not handle the case when it isn’t and it will fail.
To fix the issue, edit os-release file and add double quotes to PRETTY_NAME value:
sudoedit /usr/lib/os-release
PRETTY_NAME="EndeavourOS"
Anyway, you should report this bug to ScreamingFrog upstream.
Thank you so much. It works now.
Actually, I tried a bit dumb approach and kinda wrong direction - I’ve copied the whole arch-release file from Manjaro to EOS. It didn’t work, and I gave up on that.
Thanks again. I will definitely share this solution in the AUR for others
