Hello.
Yesterday, I was comfortably playing Transport Fever 2 (which runs under Vulkan) and wanted to quickly tab out to write something in Discord. I noticed that although I could see Discord, I couldn’t do anything in it. Then I tried to open a browser, which worked, but the browser remained invisible. This happened with everything… until the taskbar crashed.
I had to restart the PC and did a full system update (you never know). Anyway, I noticed that I suddenly had a new icon saying that my desktop was now running in software mode. No idea why.
I then tinkered with ChatGPT, and the command kwin_wayland --replace helped to remove the icon. But now, the desktop keeps crashing.
Occasionally, when I try to click something in the taskbar, the taskbar crashes briefly and then comes back. The system is currently barely usable, and I simply don’t know enough about it to fix it myself.
Attached are an Inxi and a Journalctl.
This is my machine:
Kernel: 6.13.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
clocksource: tsc avail: hpet,acpi_pm
parameters: initrd=\1b84d8b4717e4bffa8575f20f8f55d61\6.13.5-zen1-1-zen\initrd
nvme_load=YES nowatchdog rw root=UUID=296daed9-0f47-4863-8425-1c37a5785919
systemd.machine_id=1b84d8b4717e4bffa8575f20f8f55d61
Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A info: frameworks v: 6.11.0
wm: kwin_wayland vt: 1 dm: SDDM Distro: EndeavourOS base: Arch Linux
Type: Desktop System: Gigabyte product: Z170X-UD3 v: N/A
serial: <superuser required>
Mobo: Gigabyte model: Z170X-UD3-CF v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: F23g date: 03/09/2018
Info: model: Intel Core i7-6700 bits: 64 type: MT MCP arch: Skylake-S
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x5E (94) stepping: 3 microcode: 0xF0
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/4000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 54398
Vulnerabilities:
Type: gather_data_sampling status: Vulnerable: No microcode
Type: itlb_multihit status: KVM: Split huge pages
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT
vulnerable
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT vulnerable
Type: reg_file_data_sampling status: Not affected
Type: retbleed mitigation: IBRS
Type: spec_rstack_overflow status: Not affected
prctl
sanitization
Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: conditional;
RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Type: tsx_async_abort mitigation: TSX disabled
Device-1: NVIDIA TU104 [GeForce RTX 2060] driver: nvidia v: 570.124.04
alternate: nouveau,nvidia_drm non-free: 550/565.xx+ status: current (as of
2025-01; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: none off: HDMI-A-1 empty: DP-1,DP-2,DP-3
bus-ID: 01:00.0 chip-ID: 10de:1e89 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_wayland driver: X: loaded: nvidia unloaded: modesetting
alternate: fbdev,nouveau,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: HDMI-A-1 model: Asus VS248 serial: <filter> built: 2014 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 92 gamma: 1.2
size: 531x299mm (20.91x11.77") diag: 609mm (24") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 570.124.04 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
memory: 5.86 GiB display-ID: :1.0
API: Vulkan v: 1.4.304 layers: 6 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: N/A device-ID: 10de:1e89
surfaces: xcb,xlib,wayland
de: kscreen-console,kscreen-doctor gpu: nvidia-settings,nvidia-smi
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA TU104 HD Audio driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f8
class-ID: 0403
Device-3: C-Media CMI8788 [Oxygen HD Audio] vendor: ASUSTeK Virtuoso 100
driver: snd_virtuoso v: kernel bus-ID: 0f:04.0 chip-ID: 13f6:8788
class-ID: 0401
Device-4: Texas Instruments PCM2902 Audio Codec
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 08bb:2902 class-ID: 0300
API: ALSA v: k6.13.5-zen1-1-zen status: kernel-api
Server-1: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Info: services: NetworkManager,systemd-timesyncd
Local Storage: total: 2.27 TiB used: 199 GiB (8.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: MTFDDAV256TBN-1AR1ZABHA
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0014 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: SanDisk model: SD8SN8U256G1122
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0000 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1A02 scheme: GPT
ID-5: /dev/sde maj-min: 8:64 vendor: Crucial model: CT480BX200SSD1
size: 447.13 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: .6 scheme: GPT
ID-1: / raw-size: 225.5 GiB size: 220.9 GiB (97.96%) used: 198.56 GiB (89.9%)
fs: ext4 dev: /dev/sdc3 maj-min: 8:35
Kernel: swappiness: 60 (default) cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: partition size: 12 GiB used: 42.2 MiB (0.3%)
priority: -2 dev: /dev/sdc2 maj-min: 8:34
System Temperatures: cpu: 32.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 24 GiB available: 23.42 GiB used: 3.49 GiB (14.9%)
Processes: 238 Power: uptime: 1h 4m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 9.3 GiB services: power-profiles-daemon,upowerd
Init: systemd v: 257 default: graphical tool: systemctl
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 2045 libs: 431 tools: yay
Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 13 Shell: tim-inxi default: Bash
v: 5.2.37 running-in: konsole inxi: 3.3.37
and this is the post-crash journalctrl part, that is written in deepred and yellow:
Mär 09 00:54:29 Linux plasmashell[6635]: warning: queue 0x7bb69c004280 destroyed while proxies still attached:
Mär 09 00:54:29 Linux plasmashell[6635]: wl_callback#378 still attached
Mär 09 00:54:29 Linux plasmashell[6635]: wp_linux_drm_syncobj_timeline_v1#382 still attached
Mär 09 00:54:29 Linux plasmashell[6635]: wl_buffer#384 still attached
Mär 09 00:54:29 Linux plasmashell[6635]: wp_linux_drm_syncobj_timeline_v1#150 still attached
Mär 09 00:54:29 Linux plasmashell[6635]: wl_buffer#390 still attached
Mär 09 00:54:29 Linux plasmashell[6635]: wp_linux_drm_syncobj_timeline_v1#394 still attached
Mär 09 00:54:29 Linux plasmashell[6635]: wl_buffer#396 still attached
Mär 09 00:54:29 Linux plasmashell[6635]: wl_surface#141 still attached
Mär 09 00:54:29 Linux plasmashell[6635]: wp_linux_drm_syncobj_surface_v1#398 still attached
Mär 09 00:54:29 Linux plasmashell[6635]: wp_linux_drm_syncobj_manager_v1#400 still attached
Mär 09 00:54:29 Linux plasmashell[6635]: wp_tearing_control_v1#402 still attached
Mär 09 00:54:29 Linux plasmashell[6635]: Tried to add event to destroyed queue
Mär 09 00:54:29 Linux systemd-coredump[6948]: Process 6635 (plasmashell) of user 1000 terminated abnormally with signal 6/ABRT, processing...
Mär 09 00:54:29 Linux systemd[1]: Started Process Core Dump (PID 6948/UID 0).
Mär 09 00:54:31 Linux systemd-coredump[6949]: [🡕] Process 6635 (plasmashell) of user 1000 dumped core.
Module [dso] without build-id.
Stack trace of thread 6638:
#0 0x00007bb773ca5624 n/a (n/a + 0x0)
#1 0x00007bb773c4bba0 n/a (n/a + 0x0)
#2 0x00007bb773c33582 n/a (n/a + 0x0)
#3 0x00007bb776dd4734 n/a (n/a + 0x0)
#4 0x00007bb776dd6d86 n/a (n/a + 0x0)
#5 0x00007bb77536d5f1 n/a (n/a + 0x0)
#6 0x00007bb7744d8a9b n/a (n/a + 0x0)
#7 0x00007bb773ca370a n/a (n/a + 0x0)
#8 0x00007bb773d27aac n/a (n/a + 0x0)
ELF object binary architecture: AMD x86-64
Mär 09 00:54:31 Linux systemd[1]: systemd-coredump@14-6948-0.service: Deactivated successfully.
Mär 09 00:54:31 Linux systemd[1]: systemd-coredump@14-6948-0.service: Consumed 1.525s CPU time, 724.3M memory peak.
Mär 09 00:54:31 Linux systemd[1073]: plasma-plasmashell.service: Main process exited, code=dumped, status=6/ABRT
Mär 09 00:54:31 Linux systemd[1073]: plasma-plasmashell.service: Failed with result 'core-dump'.
Mär 09 00:54:31 Linux systemd[1073]: plasma-plasmashell.service: Consumed 21.684s CPU time, 346.2M memory peak.
Mär 09 00:54:31 Linux systemd[1073]: plasma-plasmashell.service: Scheduled restart job, restart counter is at 3.
Mär 09 00:54:31 Linux systemd[1073]: Starting KDE Plasma Workspace...
Mär 09 00:54:32 Linux systemd[1073]: Started KDE Plasma Workspace.
Mär 09 00:54:32 Linux plasmashell[6964]: kf.plasma.quick: Applet preload policy set to 1
Mär 09 00:54:32 Linux plasmashell[6964]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property>
file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:201:9
Mär 09 00:54:32 Linux plasmashell[6964]: Toolbox not loading, toolbox package is either invalid or disabled.
Mär 09 00:54:33 Linux systemd[1073]: Started dbus-:1.2-org.kde.KSplash@10.service.
Mär 09 00:54:33 Linux plasmashell[6964]: qt.svg: <input>:303:256: Could not add child element to parent element because the types are incorrect.
Mär 09 00:54:33 Linux plasmashell[6964]: qt.svg: <input>:303:461: Could not add child element to parent element because the types are incorrect.
Mär 09 00:54:33 Linux plasmashell[6964]: qt.svg: <input>:303:657: Could not add child element to parent element because the types are incorrect.
Mär 09 00:54:33 Linux plasmashell[6964]: qt.svg: <input>:303:911: Could not add child element to parent element because the types are incorrect.
Mär 09 00:54:33 Linux plasmashell[6964]: qt.svg: <input>:303:1047: Could not add child element to parent element because the types are incorrect.
Mär 09 00:54:33 Linux plasmashell[6964]: qt.svg: <input>:303:1249: Could not add child element to parent element because the types are incorrect.
Mär 09 00:54:33 Linux plasmashell[6964]: qt.svg: <input>:303:1451: Could not add child element to parent element because the types are incorrect.
Mär 09 00:54:33 Linux plasmashell[6964]: qt.svg: <input>:303:1629: Could not add child element to parent element because the types are incorrect.
Mär 09 00:54:33 Linux plasmashell[6964]: qt.svg: <input>:303:1737: Could not add child element to parent element because the types are incorrect.
Mär 09 00:54:33 Linux plasmashell[6964]: qt.svg: <input>:303:1978: Could not add child element to parent element because the types are incorrect.
Mär 09 00:54:33 Linux plasmashell[6964]: qt.svg: <input>:303:2221: Could not add child element to parent element because the types are incorrect.
Mär 09 00:54:33 Linux plasmashell[6964]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/main.qml:310:13: QML Image: Cannot open: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/start-here-kd>
Mär 09 00:54:33 Linux plasmashell[6964]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:50:9: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
Mär 09 00:54:33 Linux plasmashell[6964]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
Mär 09 00:54:34 Linux plasmashell[6964]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Mär 09 00:54:34 Linux plasmashell[6964]: qt.svg: <input>:303:256: Could not add child element to parent element because the types are incorrect.
Mär 09 00:54:34 Linux plasmashell[6964]: qt.svg: <input>:303:461: Could not add child element to parent element because the types are incorrect.
Mär 09 00:54:34 Linux plasmashell[6964]: qt.svg: <input>:303:657: Could not add child element to parent element because the types are incorrect.
Mär 09 00:54:34 Linux plasmashell[6964]: qt.svg: <input>:303:911: Could not add child element to parent element because the types are incorrect.
Mär 09 00:54:34 Linux plasmashell[6964]: qt.svg: <input>:303:1047: Could not add child element to parent element because the types are incorrect.
Mär 09 00:54:34 Linux plasmashell[6964]: qt.svg: <input>:303:1249: Could not add child element to parent element because the types are incorrect.
Mär 09 00:54:34 Linux plasmashell[6964]: qt.svg: <input>:303:1451: Could not add child element to parent element because the types are incorrect.
Mär 09 00:54:34 Linux plasmashell[6964]: qt.svg: <input>:303:1629: Could not add child element to parent element because the types are incorrect.
Mär 09 00:54:34 Linux plasmashell[6964]: qt.svg: <input>:303:1737: Could not add child element to parent element because the types are incorrect.
Mär 09 00:54:34 Linux plasmashell[6964]: qt.svg: <input>:303:1978: Could not add child element to parent element because the types are incorrect.
Mär 09 00:54:34 Linux plasmashell[6964]: qt.svg: <input>:303:2221: Could not add child element to parent element because the types are incorrect.
I hope that someone can see the problem and know how to solve it.
Thank you.
