Hi I had problem with intel graphics sometimes it’s gets a littel bit freeze when i maximize or minimize a window i check the system mesa is enabled and i use plasma desktop down log show up when i do that
i915 0000:00:02.0: [drm] ERROR Atomic update failure on pipe B (start=384124 end=384125) time 179 us, min 894, max 899, scanline start 889, end 900
kwin_libinput: Libinput: event8 - Genius Optical Mouse: client bug: event processing lagging behind by 27ms, your system is too slow
my system spec:
intel i7 6500u with hd 520
and nvidia 940mx
thanks now it’s happened less than before. may i ask you what you mean about “prevents the CPU from dropping into a sleep state” I didn’t know that cpu can sleep i think only hard drive can do that
and i have another question what about this log i mention that before on top
that’s my mouse it’s not my mouse problem it’s happened with my touchpad too
