Problem with Guake on KDE Plasma
I couldn’t get “Quick Open” work on my machine, is there anyone on the blog having a similar issue?
guake is gnome, should still work though :smiley:
Try yakuake, it is for KDE.
Hmmm cannot get it to run in KDE either.
Mine works. Try starting it with terminal and change the keyboard shortcut. After first logout/in it should start automatically or you can set it so.
https://wiki.archlinux.org/title/Yakuake
(Same for guake)
Edit: check the auto startup for guake here
https://wiki.archlinux.org/title/Guake
it seems I got this bug when I pressed ctrl and clicked on directory to open a file: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
KDE Bug Report on the Issue
@xircon may like to check this bug report.
Why are you using Guake on KDE Plasma? I’m pretty sure your problem is related to that… :rofl:
It’s a terminal, I open files with a file manger.
Because gnome is better than plasma of course.
The truth
Got ya :stuck_out_tongue_winking_eye: KDE is better than Gnome :grin:
Guake is easier to configure and looks fancier, Yakuake would be a nice fallback terminal just in case.
I use an alias:
alias op='xdg-open >/dev/null 2>&1'
I also recommend to use bash-complete-alias package, it’s a blessing.
bash-complete-alias by cykerway
