Problem with GRUB using dual boot with Windows 11
Hello! I am experiencing an issue with launching GRUB after using Windows. After I shut down/restart the system in Windows, it does not display my grub and immediately returns to Windows. The only solution is to press F12 (i.e., select UEFI).
There is no such issue with Linux.
Hibernation and fast startup are disabled in Windows 11.
In Windows 11, I wrote the command bcdedit /set {bootmgr}, but that doesn’t help either.
~ sudo efibootmgr -v
[sudo] password for tok:
BootCurrent: 0002
Timeout: 5 seconds
BootOrder: 0002,0000,0001,2002,2001,2003
Boot0000* Windows Boot Manager HD(1,GPT,ae1bfb66-90e7-4f20-be5d-222a3125a330,0x800,0x32000)/\EFI\Microsoft\Boot\bootmgfw.efiRC
dp: 04 01 2a 00 01 00 00 00 00 08 00 00 00 00 00 00 00 20 03 00 00 00 00 00 66 fb 1b ae e7 90 20 4f be 5d 22 2a 31 25 a3 30 02 02 / 04 04 46 00 5c 00 45 00 46 00 49 00 5c 00 4d 00 69 00 63 00 72 00 6f 00 73 00 6f 00 66 00 74 00 5c 00 42 00 6f 00 6f 00 74 00 5c 00 62 00 6f 00 6f 00 74 00 6d 00 67 00 66 00 77 00 2e 00 65 00 66 00 69 00 00 00 / 7f ff 04 00
data: 52 43
Boot0001* EFI Hard Drive (5MCAN00151030AN21-SKHynix_HFS512GEJ4X112N) PciRoot(0x0)/Pci(0x6,0x0)/Pci(0x0,0x0)/NVMe(0x1,AC-E4-2E-00-31-48-5A-32)/HD(8,GPT,b4d02e57-432d-4808-9f07-052284ee9c2c,0x141fe800,0x115800)RC
dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 00 06 / 01 01 06 00 00 00 / 03 17 10 00 01 00 00 00 ac e4 2e 00 31 48 5a 32 / 04 01 2a 00 08 00 00 00 00 e8 1f 14 00 00 00 00 00 58 11 00 00 00 00 00 57 2e d0 b4 2d 43 08 48 9f 07 05 22 84 ee 9c 2c 02 02 / 7f ff 04 00
data: 52 43
Boot0002* endeavouros HD(8,GPT,b4d02e57-432d-4808-9f07-052284ee9c2c,0x141fe800,0x115800)/\EFI\endeavouros\grubx64.efi
dp: 04 01 2a 00 08 00 00 00 00 e8 1f 14 00 00 00 00 00 58 11 00 00 00 00 00 57 2e d0 b4 2d 43 08 48 9f 07 05 22 84 ee 9c 2c 02 02 / 04 04 3e 00 5c 00 45 00 46 00 49 00 5c 00 65 00 6e 00 64 00 65 00 61 00 76 00 6f 00 75 00 72 00 6f 00 73 00 5c 00 67 00 72 00 75 00 62 00 78 00 36 00 34 00 2e 00 65 00 66 00 69 00 00 00 / 7f ff 04 00
Boot0003* EFI PXE 0 for IPv4 (BC-EC-A0-4D-27-47) PciRoot(0x0)/Pci(0x1c,0x0)/Pci(0x0,0x0)/MAC(bceca04d2747,0)/IPv4(0.0.0.0,0,DHCP,0.0.0.0,0.0.0.0,0.0.0.0)RC
dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 00 1c / 01 01 06 00 00 00 / 03 0b 25 00 bc ec a0 4d 27 47 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 / 03 0c 1b 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 / 7f ff 04 00
data: 52 43
Boot0005* EFI PXE 0 for IPv6 (BC-EC-A0-4D-27-47) PciRoot(0x0)/Pci(0x1c,0x0)/Pci(0x0,0x0)/MAC(bceca04d2747,0)/IPv6([::],0,Static,[::],[::],64)RC
dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 00 1c / 01 01 06 00 00 00 / 03 0b 25 00 bc ec a0 4d 27 47 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 / 03 0d 3c 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 / 7f ff 04 00
data: 52 43
Boot2001* EFI USB Device RC
dp: 7f ff 04 00
data: 52 43
Boot2002* EFI DVD/CDROM RC
dp: 7f ff 04 00
data: 52 43
Boot2003* EFI Network RC
dp: 7f ff 04 00
data: 52 43
➜ ~ 84;6u
zsh: command not found: 84
zsh: command not found: 6u
yo jolian, i do not update windows 11, in fact i did a clean setup of Linux with cleaning old grubs via Bootice utility and etc so its cleany. Fast Startup as i said was turned off but still no impact.
What my problem is: Whenever i boot in Windows and then shut down or reboot it, its going to fcking windows 11 again. Which means windows 11 somehow go straight to his grub but not to linux grub.
Linux is placed first in fcking UEFI order. Thank you very much.
