Hi all, I have a problem in my gnome control center. In sharing settings I have only “remote access” voice like in the screenshot below…
Someone can tell me wich packages I have to install for the other voices?
Thanks in advance
First make sure your system is up to date:
sudo pacman -Syu
and then:
sudo pacman -S gnome-user-share gnome-remote-desktop
problem solved. Thank you!
Prego!
If the problem is solved to your satisfaction, please mark the post leading to the solution as such.
You can do so by clicking on ... and check the box for solution.
Grazie in anticipo!
