Hi everyone,
im new on EndevourOS and i have just installed it with gnome.
Till now i really love it, but i have a problem with apps that goes in background after closing them.
Apps like Discord or Prismatik, that goes in background after closing them, doesn’t show on the gnome panel. I did a top command on terminal and it gave me that they were running.
I also tried to disable all extensions, just to make shure that nothing conflicts with it. But it didn’t solve the problem.
Did someone have the same problem or know how to solve it?
Thanks.
mostly this is caused by apps using legacy tray mechanism to show up, and per default gnome does not provide that anymore.
You can bring it back by extension:
https://extensions.gnome.org/extension/2890/tray-icons-reloaded/
I’m not a gnome user, so I’m of no help with this, but I’m sure your issue will get resolved.
Welcome to the community
and yes sure:
Welcome on deck
Thank you very much!
Thank you!
I think it will be a long journey for me on this community, couse till now i really like Endevour.
