So i’ve been reinstalling this package lately to update it (i didnt know i had to reinstall it for update as told in the comment, but now it failed because apparently mozilla changed the key, is there a way to install it for now ?
https://aur.archlinux.org/packages/firefox-nightly-bin
The PKGBUILD is already flagged as out-of date:
https://aur.archlinux.org/pkgbase/firefox-nightly-bin/flag-comment
As a temporary solution/workaround you might want to dowload it from:
Extract it in a directory under your home and run it as “portable” app.
That is what I do…been running it that way for several years now.
ok i’ll take a look and learn how to create a desktop entry so it shows in ‘internet’ category here on plasma
You could right-click (or double tap) on the app launcher (app menu) icon and choose edit application (or something similar). Create a new entry by pointing it to where you have the firefox’ binary.
ok i got it working, i created a shortcut using cairo-dock, in “Command to launch on click” i put:
/home/ramon/Firefox-nightly/firefox/firefox
working nice here, i’ll mark the topic as solved
i ended deleting the folder i created and installed back the aur package, i found the new key to import on this comment
https://aur.archlinux.org/packages/firefox-nightly-de-bin#comment-915296
