Problem opening files in DBeaver and VSCode
Hello. Please help me. When I try to open files in DBeaver or VSCode - programs just stop working and close. Previously they closed from time to time. But now I can’t open any file.
DBeaver and VSCode work just fine so a local issue - possibly a configuration gone haywire - this often happens when you run GUI apps with sudo.
Remove the related configuration files in ~/, ~/.config and ~/.local (the latter may not be needed but since you used Plasma tag)
