Problem oldroot/sys target is busy when shutdown or restart
Good, I’ve been having this problem for more or less a month, and I can’t find the solution. Previously it came from Pop os, and it didn’t have this problem, but it did have other problems, for example, when it suspended the computer, which in EndeavorOS doesn’t happen to me.
Error:
error
My pc is as follows
neo
The problem arises after restarting or shutting down the equipment, it stays between 2 to 5 minutes until the equipment is turned off, to start the equipment there is no problem.
What if I have noticed, that, for example, when there is a Kernel update or something in the system, if I reboot, the PC restarts or shuts down in normal time (5s approx), but then, if I restart or shut down again, it returns the error is fixed momentarily when there is an update.
This is the error log when I reboot/shutdown after update:
mar 18 18:45:22 federico alsactl[537]: alsa-lib main.c:1412:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -2
mar 18 18:45:22 federico kernel: nvidia-gpu 0000:06:00.3: i2c timeout error e0000000
mar 18 18:45:22 federico kernel: ucsi_ccg: probe of 0-0008 failed with error -110
mar 18 18:45:24 federico kcminit_startup[697]: QDBusConnection: error: could not send signal to service "" path "//home/federico/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/federico/.kde4/share/config/kdeglobals
mar 18 18:45:25 federico ksmserver[760]: Qt: Session management error: networkIdsList argument is NULL
mar 18 18:45:25 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 764, resource id: 10485765, major code: 18 (ChangeProperty), minor code: 0
mar 18 18:45:26 federico kwin_x11[707]: kwin_core: XCB error: 10 (BadAccess), sequence: 842, resource id: 477, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
mar 18 18:45:27 federico xembedsniproxy[783]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 458, resource id: 50331655, major code: 12 (ConfigureWindow), minor code: 0
mar 18 18:45:28 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2107, resource id: 4194328, major code: 18 (ChangeProperty), minor code: 0
mar 18 18:46:22 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6098, resource id: 46137426, major code: 15 (QueryTree), minor code: 0
mar 18 18:46:51 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23537, resource id: 46137444, major code: 15 (QueryTree), minor code: 0
mar 18 18:48:19 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29308, resource id: 46137501, major code: 18 (ChangeProperty), minor code: 0
mar 18 18:48:20 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 30541, resource id: 62914619, major code: 18 (ChangeProperty), minor code: 0
mar 18 18:58:52 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27180, resource id: 69206021, major code: 18 (ChangeProperty), minor code: 0
mar 18 18:58:59 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29230, resource id: 69206021, major code: 18 (ChangeProperty), minor code: 0
mar 18 18:59:26 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 40380, resource id: 14703855, major code: 3 (GetWindowAttributes), minor code: 0
mar 18 18:59:26 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 40381, resource id: 14703855, major code: 14 (GetGeometry), minor code: 0
mar 18 18:59:28 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41720, resource id: 46137503, major code: 18 (ChangeProperty), minor code: 0
mar 18 18:59:37 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 51760, resource id: 46137505, major code: 18 (ChangeProperty), minor code: 0
mar 18 18:59:42 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56084, resource id: 83886081, major code: 15 (QueryTree), minor code: 0
mar 18 18:59:42 federico kwin_x11[707]: kwin_core: XCB error: 152 (BadDamage), sequence: 56135, resource id: 14704658, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 18 19:00:49 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 25270, resource id: 46137506, major code: 15 (QueryTree), minor code: 0
mar 18 19:03:55 federico kioslave5[3668]: Qt: Session management error: networkIdsList argument is NULL
mar 18 19:06:56 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58482, resource id: 106954760, major code: 18 (ChangeProperty), minor code: 0
mar 18 19:16:08 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 896, resource id: 14725842, major code: 3 (GetWindowAttributes), minor code: 0
mar 18 19:16:08 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 897, resource id: 14725842, major code: 14 (GetGeometry), minor code: 0
mar 18 19:16:08 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 900, resource id: 14725842, major code: 3 (GetWindowAttributes), minor code: 0
mar 18 19:16:08 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 901, resource id: 14725842, major code: 14 (GetGeometry), minor code: 0
mar 18 19:17:04 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18023, resource id: 14722146, major code: 3 (GetWindowAttributes), minor code: 0
mar 18 19:17:04 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 18024, resource id: 14722146, major code: 14 (GetGeometry), minor code: 0
mar 18 19:17:11 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 20378, resource id: 14726826, major code: 3 (GetWindowAttributes), minor code: 0
mar 18 19:17:11 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 20379, resource id: 14726826, major code: 14 (GetGeometry), minor code: 0
mar 18 19:17:18 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27268, resource id: 46137545, major code: 19 (DeleteProperty), minor code: 0
mar 18 19:17:18 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27271, resource id: 46137545, major code: 19 (DeleteProperty), minor code: 0
mar 18 19:17:18 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27272, resource id: 46137545, major code: 18 (ChangeProperty), minor code: 0
mar 18 19:17:18 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27273, resource id: 46137545, major code: 19 (DeleteProperty), minor code: 0
mar 18 19:17:18 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27274, resource id: 46137545, major code: 19 (DeleteProperty), minor code: 0
mar 18 19:17:18 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27275, resource id: 46137545, major code: 19 (DeleteProperty), minor code: 0
mar 18 19:17:18 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27276, resource id: 46137545, major code: 7 (ReparentWindow), minor code: 0
mar 18 19:17:18 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27277, resource id: 46137545, major code: 6 (ChangeSaveSet), minor code: 0
mar 18 19:17:18 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27278, resource id: 46137545, major code: 2 (ChangeWindowAttributes), minor code: 0
mar 18 19:17:18 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27279, resource id: 46137545, major code: 10 (UnmapWindow), minor code: 0
mar 18 19:26:42 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33816, resource id: 46137551, major code: 15 (QueryTree), minor code: 0
mar 18 19:29:35 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27029, resource id: 14740825, major code: 3 (GetWindowAttributes), minor code: 0
mar 18 19:29:35 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 27030, resource id: 14740825, major code: 14 (GetGeometry), minor code: 0
mar 18 19:37:04 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53758, resource id: 14743745, major code: 3 (GetWindowAttributes), minor code: 0
mar 18 19:37:04 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53759, resource id: 14743745, major code: 14 (GetGeometry), minor code: 0
mar 18 19:39:36 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7288, resource id: 46137559, major code: 15 (QueryTree), minor code: 0
mar 18 19:40:24 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34082, resource id: 14726781, major code: 3 (GetWindowAttributes), minor code: 0
mar 18 19:40:24 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 34083, resource id: 14726781, major code: 14 (GetGeometry), minor code: 0
mar 18 19:40:24 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34086, resource id: 14726781, major code: 3 (GetWindowAttributes), minor code: 0
mar 18 19:40:24 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 34087, resource id: 14726781, major code: 14 (GetGeometry), minor code: 0
mar 18 19:40:27 federico kwin_x11[707]: kwin_core: XCB error: 152 (BadDamage), sequence: 36178, resource id: 14763978, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 18 19:44:15 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3213, resource id: 46137565, major code: 15 (QueryTree), minor code: 0
mar 18 19:49:10 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 15117, resource id: 62914906, major code: 15 (QueryTree), minor code: 0
mar 18 19:50:19 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62397, resource id: 62914765, major code: 15 (QueryTree), minor code: 0
mar 18 19:50:22 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 64552, resource id: 14772348, major code: 3 (GetWindowAttributes), minor code: 0
mar 18 19:50:22 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 64553, resource id: 14772348, major code: 14 (GetGeometry), minor code: 0
mar 18 19:50:23 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 839, resource id: 46137572, major code: 18 (ChangeProperty), minor code: 0
mar 18 19:50:23 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1450, resource id: 106954753, major code: 18 (ChangeProperty), minor code: 0
mar 18 19:50:23 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1454, resource id: 106954755, major code: 18 (ChangeProperty), minor code: 0
mar 18 19:50:23 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1458, resource id: 46137573, major code: 18 (ChangeProperty), minor code: 0
mar 18 20:01:13 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 51403, resource id: 62914604, major code: 15 (QueryTree), minor code: 0
mar 18 20:01:19 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55253, resource id: 12582918, major code: 18 (ChangeProperty), minor code: 0
mar 18 20:01:19 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55258, resource id: 12582919, major code: 18 (ChangeProperty), minor code: 0
mar 18 20:02:55 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 94, resource id: 46137575, major code: 15 (QueryTree), minor code: 0
mar 18 20:03:16 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4838, resource id: 46137583, major code: 18 (ChangeProperty), minor code: 0
mar 18 20:03:18 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6622, resource id: 106954811, major code: 18 (ChangeProperty), minor code: 0
mar 18 20:05:40 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31086, resource id: 104857738, major code: 18 (ChangeProperty), minor code: 0
mar 18 20:05:40 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31103, resource id: 109051912, major code: 18 (ChangeProperty), minor code: 0
mar 18 20:05:40 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31107, resource id: 104857740, major code: 18 (ChangeProperty), minor code: 0
mar 18 20:05:42 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32088, resource id: 62914587, major code: 18 (ChangeProperty), minor code: 0
mar 18 20:05:42 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32092, resource id: 12582920, major code: 18 (ChangeProperty), minor code: 0
mar 18 20:05:46 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33759, resource id: 106954796, major code: 15 (QueryTree), minor code: 0
mar 18 20:05:46 federico kwin_x11[707]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34114, resource id: 46137586, major code: 18 (ChangeProperty), minor code: 0
mar 18 20:05:50 federico sddm[581]: Authentication error: "Process crashed"
mar 18 20:05:50 federico kded5[704]: The X11 connection broke: I/O error (code 1)
mar 18 20:05:50 federico kglobalaccel5[723]: The X11 connection broke (error 1). Did the X11 server die?
mar 18 20:05:50 federico kactivitymanagerd[827]: The X11 connection broke (error 1). Did the X11 server die?
mar 18 20:05:50 federico kwin_x11[707]: The X11 connection broke: I/O error (code 1)
mar 18 20:05:50 federico kscreen_backend_launcher[914]: The X11 connection broke (error 1). Did the X11 server die?
This is the error log when I restart / shutdown with the updated equipment:
mar 18 20:06:15 federico alsactl[547]: alsa-lib main.c:1412:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -2
mar 18 20:06:16 federico kernel: nvidia-gpu 0000:06:00.3: i2c timeout error e0000000
mar 18 20:06:16 federico kernel: ucsi_ccg: probe of 0-0008 failed with error -110
mar 18 20:06:17 federico kcminit_startup[707]: QDBusConnection: error: could not send signal to service "" path "//home/federico/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/federico/.kde4/share/config/kdeglobals
mar 18 20:06:18 federico ksmserver[763]: Qt: Session management error: networkIdsList argument is NULL
mar 18 20:06:19 federico kwin_x11[717]: kwin_core: XCB error: 10 (BadAccess), sequence: 822, resource id: 477, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
mar 18 20:06:23 federico xembedsniproxy[790]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 459, resource id: 56623111, major code: 12 (ConfigureWindow), minor code: 0
mar 18 20:06:25 federico kwin_x11[717]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2272, resource id: 4194328, major code: 18 (ChangeProperty), minor code: 0
mar 18 20:06:42 federico kwin_x11[717]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9679, resource id: 12582919, major code: 18 (ChangeProperty), minor code: 0
mar 18 20:08:05 federico kwin_x11[717]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 21959, resource id: 62914566, major code: 18 (ChangeProperty), minor code: 0
mar 18 20:08:06 federico kwin_x11[717]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22117, resource id: 60817434, major code: 18 (ChangeProperty), minor code: 0
mar 18 20:08:06 federico kwin_x11[717]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22123, resource id: 12582920, major code: 18 (ChangeProperty), minor code: 0
mar 18 20:08:10 federico sddm[597]: Authentication error: "Process crashed"
mar 18 20:08:10 federico kglobalaccel5[733]: The X11 connection broke (error 1). Did the X11 server die?
mar 18 20:08:10 federico kded5[714]: The X11 connection broke: I/O error (code 1)
mar 18 20:08:10 federico kwin_x11[717]: The X11 connection broke: I/O error (code 1)
mar 18 20:08:10 federico kscreen_backend_launcher[847]: The X11 connection broke (error 1). Did the X11 server die?
mar 18 20:08:10 federico kactivitymanagerd[849]: The X11 connection broke (error 1). Did the X11 server die?
I have tried some solutions that I have found here in the forum, such as the following:
[Unit]
Description=Remove nvidia modules before shutdown
DefaultDependencies=no
After=sddm.service
[Service]
Type=oneshot
ExecStart=/usr/bin/modprobe -r nvidia_drm nvidia_modeset nvidia_uvm nvidia
[Install]
WantedBy=shutdown.target
But it didn’t work for me, moreover, after an update directly, the PC didn’t even start, so I had to deactivate this fix.
I understand that the other error, from parse_torblock, has to do with the partitions of my hard drive, but that is not the problem for which I consult, the issue is the shutdown, which is driving me crazy. If anyone can think of or had a similar situation that could be solved, I would greatly appreciate it.
I hope I can stick with EndeavorOS as the rest works great for me.
Greetings
Have you disabled watchdogs?
If this does not solve it, then it may be nvidia.
Posting text info in images does not help your helpers. Please, don’t.
The posted logs seem to show the results of the actual problem, not the source.
When posting logs, always include the command you used to get them, or it will definitely include useless info messages.
Did you try another kernel?
Yes, the deafult kernel, and the result is the same
Hi petsam, thanks for replying.
The commands I use are the following:
  • Update the pc, yay -Syu.
  • Reboot
  • After reboot, journalctl -b -1 | grep error
These are the commands from the first log.
Then again:
  • Restart pc (here the error happens)
  • After reboot, journalctl -b -1 | grep error, since it is the previous boot, the log before this would be -b -2, if I am not mistaken.
The Nvidia issue, I tried the solutions, but none of them solved the problem, in addition, I had to deactivate the solutions, since after an update the system did not work.
I’ll try disabling watchdog and post the results.
Can you post a link that suggests this command to get errors?
Have you read man journalctl, or Archwiki on journal? It helps…
This was 1st.
Here is my grub
# GRUB boot loader configuration
GRUB_DEFAULT=0
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="EndeavourOS"
GRUB_CMDLINE_LINUX_DEFAULT="quiet loglevel=3 nowatchdog nvme_load=YES nvidia-drm.modeset=1"
GRUB_CMDLINE_LINUX=""
GRUB_DISABLE_OS_PROBER=false
# Preload both GPT and MBR modules so that they are not missed
GRUB_PRELOAD_MODULES="part_gpt part_msdos"
# Uncomment to enable booting from LUKS encrypted devices
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'hidden' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=menu
# Uncomment to use basic console
GRUB_TERMINAL_INPUT=console
# Uncomment to disable graphical terminal
#GRUB_TERMINAL_OUTPUT=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
GRUB_GFXMODE=auto
# Uncomment to allow the kernel use the same resolution used by grub
GRUB_GFXPAYLOAD_LINUX=keep
# Uncomment if you want GRUB to pass to the Linux kernel the old parameter
# format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
#GRUB_COLOR_NORMAL="light-blue/black"
#GRUB_COLOR_HIGHLIGHT="light-cyan/blue"
# Uncomment one of them for the gfx desired, a image background or a gfxtheme
#GRUB_BACKGROUND="/path/to/wallpaper"
GRUB_THEME=/boot/grub/themes/EndeavourOS/theme.txt
# Uncomment to get a beep at GRUB start
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
#GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
GRUB_DISABLE_SUBMENU=y
From what I see, watch dogs is already disabled, right?
Have you read the link I posted? It explains and answers your question.
Sorry if I don’t understand well, my native language is Spanish, and the google translator is not very friendly.
What I understood from the link that passed me, is that it says that I must add the parameter:
append nowatchdog to your boot parameters.
Searching my grub config, I see that on the line:
the parameter is added.
Regarding the log, here is the complete log. I just took this log, restart the pc and run journalctl -b 1
sudo wdctl
[sudo] contraseña para federico:
Dispositivo:   /dev/watchdog0
Identidad:     SP5100 TCO timer [versión 0]
Tiempo de espera: 60 segundos
Tiempo de espera preliminar:  0 segundos
Tiempo restante: 600 segundos
FLAG           DESCRIPTION               STATUS BOOT-STATUS
KEEPALIVEPING  Keep alive ping reply          1           0
MAGICCLOSE     Supports magic close char      0           0
SETTIMEOUT     Set timeout (in seconds)       0           0
There I tried the other method, to add the blacklist iTCO_wdt line to the blacklist.conf file, restart 1 time, and I did not throw the error, but in the wdctl command I did not notice that there was a change. I will try with the days if it has been solved, although this would not solve the problem, right? It will only deactivate the function that it stays waiting?
iTCO_wdt is an Intel module; I would not expect it to be present on your AMD Ryzen system.
If you want to blacklist a watchdog module, figure out what module is in use on your system (Intel systems frequently have multiple modules that need to be blacklisted, but with AMD it’s usually just one module, sp5100_tco). Run:
lsmod | grep -e dog -e wdt -e tco
That should tell you what module(s) you need to blacklist.
That said, I don’t think this is a watchdog issue.
One small correction:
Thank you, corrected!
I do drink a lot. :laughing:
The output is:
sp5100_tco             20480  0
Although, I have to say, by blocking iTCO_wdt the problem hasn’t appeared anymore, for now. Restart the pc, turn off, turn on, 0, no more problem, it’s weird, could it be that the intel module was the problem?, because the only change I made now was that, nothing more. I will see if with the following days, in some kernel update it happens again, in that case, I will add the AMD Ryzen watchdog, but for now I will leave it that way, if everything works correctly.
The problem came back, I’ll try disabling amd’s watch dogs.
