After following this guide [https://wiki.archlinux.org/title/NVIDIA]
And using nvidia-xconfig
i’m unable to boot my system, after using Tty terminal i discovered my system can’t find any valid Xorg config, and so the loading Xorg to my Screen always fails. I would like to reset to default all my xorg.conf files but i don’t know how to do it
I already trying login to terminal and using Xorg :0 -configure
But this didn’t fixed my problem.
The files i would like to reconfigure to default are:
/etc/X11/xorg.conf
/etc/X11/xorg.conf.d
/usr/share/X11/xorg.conf.d
[ 23.505]
X.Org X Server 1.20.11
X Protocol Version 11, Revision 0
[ 23.505] Build Operating System: Linux Archlinux
[ 23.505] Current Operating System: Linux aspireE15 5.12.12-arch1-1 #1 SMP PREEMPT Fri, 18 Jun 2021 21:59:22 +0000 x86_64
[ 23.505] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=8e20e188-af2b-4833-9418-369a37447ae5 rw quiet resume=UUID=55c7d8bd-2ec5-4000-85ad-9aed2c4b1d61 loglevel=3 nowatchdog
[ 23.505] Build Date: 13 April 2021 03:12:10PM
[ 23.505]
[ 23.505] Current version of pixman: 0.40.0
[ 23.505] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 23.505] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 23.505] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Jun 21 13:35:05 2021
[ 23.505] (==) Using config file: "/etc/X11/xorg.conf"
[ 23.505] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 23.505] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 23.506] (==) ServerLayout "Layout0"
[ 23.506] (**) |-->Screen "Screen0" (0)
[ 23.506] (**) | |-->Monitor "Monitor0"
[ 23.506] (**) | |-->Device "Device0"
[ 23.506] (**) |-->Input Device "Keyboard0"
[ 23.506] (**) |-->Input Device "Mouse0"
[ 23.506] (==) Automatically adding devices
[ 23.506] (==) Automatically enabling devices
[ 23.506] (==) Automatically adding GPU devices
[ 23.506] (==) Automatically binding GPU devices
[ 23.506] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 23.506] (WW) The directory "/usr/share/fonts/misc" does not exist.
[ 23.506] Entry deleted from font path.
[ 23.506] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 23.506] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 23.506] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 23.506] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 23.506] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 23.506] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 23.506] (==) FontPath set to:
[ 23.506] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 23.506] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 23.506] (WW) Disabling Keyboard0
[ 23.506] (WW) Disabling Mouse0
[ 23.506] (II) Module ABI versions:
[ 23.506] X.Org ANSI C Emulation: 0.4
[ 23.506] X.Org Video Driver: 24.1
[ 23.506] X.Org XInput driver : 24.1
[ 23.506] X.Org Server Extension : 10.0
[ 23.507] (++) using VT number 7
[ 23.507] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 23.507] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 23.515] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 23.517] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 23.518] (--) PCI:*(0@0:2:0) 8086:1616:1025:0940 rev 9, Mem @ 0xc2000000/16777216, 0xd0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[ 23.518] (--) PCI: (4@0:0:0) 10de:1341:1025:0942 rev 162, Mem @ 0xc3000000/16777216, 0xb0000000/268435456, 0xc0000000/33554432, I/O @ 0x00003000/128
[ 23.518] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 23.518] (II) LoadModule: "glx"
[ 23.518] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 23.519] (II) Module glx: vendor="X.Org Foundation"
[ 23.519] compiled for 1.20.11, module version = 1.0.0
[ 23.519] ABI class: X.Org Server Extension, version 10.0
[ 23.519] (II) LoadModule: "nvidia"
[ 23.520] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 23.520] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 23.520] compiled for 1.6.99.901, module version = 1.0.0
[ 23.520] Module class: X.Org Video Driver
[ 23.520] (II) NVIDIA dlloader X Driver 465.31 Thu May 13 22:19:15 UTC 2021
[ 23.520] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 23.520] (II) Loading sub module "fb"
[ 23.520] (II) LoadModule: "fb"
[ 23.520] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 23.520] (II) Module fb: vendor="X.Org Foundation"
[ 23.520] compiled for 1.20.11, module version = 1.0.0
[ 23.520] ABI class: X.Org ANSI C Emulation, version 0.4
[ 23.520] (II) Loading sub module "wfb"
[ 23.520] (II) LoadModule: "wfb"
[ 23.520] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 23.521] (II) Module wfb: vendor="X.Org Foundation"
[ 23.521] compiled for 1.20.11, module version = 1.0.0
[ 23.521] ABI class: X.Org ANSI C Emulation, version 0.4
[ 23.521] (II) Loading sub module "ramdac"
[ 23.521] (II) LoadModule: "ramdac"
[ 23.521] (II) Module "ramdac" already built-in
[ 23.521] (EE) No devices detected.
[ 23.521] (EE)
Fatal server error:
[ 23.521] (EE) no screens found(EE)
[ 23.521] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 23.521] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 23.521] (EE)
[ 23.568] (EE) Server terminated with error (1). Closing log file.
