Hello,
Recently I got the Acer XB270HU and I have run into some trouble setting the correct resolution for this monitor.
So far, I have pinned down the issue to incorrect EDID information from the monitor (this monitor uses G-SYNC), I have AMD hardware so it is not exactly compatible, you can see what hardware i have in Hardware
Hardware
Kernel: 6.5.7-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: Hyprland dm: SDDM Distro: Arch Linux
Type: Desktop Mobo: Gigabyte model: B550 AORUS ELITE AX V2 v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F16d
date: 07/20/2022
Info: 6-core model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 2682 high: 3545 min/max: 400/4464 cores: 1: 3154 2: 2992
3: 2993 4: 3053 5: 3231 6: 400 7: 3386 8: 2994 9: 2997 10: 3039 11: 3545
12: 400 bogomips: 93472
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT]
vendor: XFX driver: amdgpu v: kernel arch: RDNA-2 pcie: speed: 16 GT/s
lanes: 16 ports: active: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 03:00.0
chip-ID: 1002:73df
Device-2: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 3-1:2 chip-ID: 046d:085c
Display: wayland server: X.Org v: 23.2.1 with: Xwayland v: 23.2.1
compositor: Hyprland driver: X: loaded: amdgpu unloaded: modesetting,vesa
alternate: fbdev dri: radeonsi gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 2240x1080 s-dpi: 96
Monitor-1: DP-1 pos: primary,left res: 320x240 size: N/A
Monitor-2: HDMI-A-1 pos: right model: LG (GoldStar) FULL HD res: 1920x1080
dpi: 102 diag: 551mm (21.7")
API: EGL v: 1.5 platforms: device: 0 drv: radeonsi device: 1 drv: swrast
surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6750 XT (navi22 LLVM
16.0.6 DRM 3.54 6.5.7-arch1-1) device-ID: 1002:73df
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: speed: 8 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:1637
Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 09:00.6 chip-ID: 1022:15e3
Device-4: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
Device-5: AOKEO LCS_USB_Audio driver: snd-usb-audio type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 bus-ID: 5-1:2 chip-ID: 2e3c:4444
API: ALSA v: k6.5.7-arch1-1 status: kernel-api
Server-2: JACK v: 1.9.22 status: off
Server-3: PipeWire v: 0.3.82 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: speed: 5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0 chip-ID: 10ec:8125
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 14c3:0608
IF: wlp7s0 state: down mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Bluetooth:
Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 bus-ID: 1-5:2 chip-ID: 0e8d:0608
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11
Local Storage: total: 1.82 TiB used: 1.07 TiB (58.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB
size: 931.51 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> temp: 32.9 C
ID-2: /dev/sda vendor: Seagate model: ST1000DM003-1ER162 size: 931.51 GiB
speed: 6.0 Gb/s serial: <filter>
ID-1: / size: 915.32 GiB used: 732.24 GiB (80.0%) fs: ext4 dev: /dev/dm-0
mapped: cryptroot
ID-2: /boot size: 499 MiB used: 146.5 MiB (29.4%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: file size: 10 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 37.2 C mobo: 30.0 C gpu: amdgpu temp: 37.0 C
mem: 34.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Processes: 320 Uptime: 1m Memory: total: 16 GiB available: 15.47 GiB
used: 3.23 GiB (20.9%) Init: systemd v: 254 default: graphical Compilers:
gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman pkgs: 1363 Shell: Bash
v: 5.1.16 running-in: kitty inxi: 3.3.30
I’m running Hyprland and when I run hyprctl monitors I get the next output:
hyprctl monitors
Monitor DP-1 (ID 0):
640x480@59.94000 at 0x0
description: (null) (null) (DP-1)
make:
model:
serial:
active workspace: 1 (1)
special workspace: 0 ()
reserved: 0 30 0 0
scale: 2.00
transform: 0
focused: no
dpmsStatus: 1
vrr: 0
activelyTearing: false
Monitor HDMI-A-1 (ID 1):
1920x1080@74.97300 at 320x0
description: LG Electronics LG FULL HD 0x01010101 (HDMI-A-1)
make: LG Electronics
model: LG FULL HD
serial: 0x01010101
active workspace: 5 (5)
reserved: 0 30 0 0
scale: 1.00
transform: 0
focused: yes
dpmsStatus: 1
vrr: 0
I found this GitHub page that seems to solve the issue for a different distro using a script, I have no bash knowledge, so I haven’t been able to replicate it in an arch based system.
I also found this post on Reddit, that seems to have the same problem and the op says he solved the issue, however I haven’t been successful. When I do the same thing in grub, the monitor does not get recognized, and all I have is a black screen. (I have use the EDID information from the GitHub page, I can’t get edid from my monitor)
I’m stuck on how to fix this issue because:
- I can’t get edid from the monitor.
- I don’t know what my mistakes are.
If anyone knows a workaround, I’ll gladly appreciate it.
