Hello everybody.
thanks for the help so far and I hope this question isn’t way too stupid, as I am still digging into Linux rights management.
After Windows recovery deleted my backup disk I was able to copy the deleted files with help from testdisk and recover them. After the process finished I formatted the old data grave, removing the last remains of Windows (pondering to switch became will to switch after that incident) and giving it a Linux file system. Then I copied all files back to the data grave HDD.
Now when I want to delete the recovered files from my documents folder (that’s where I copied them for easy finding) in Dolphin I get an “access denied to trash” error if I hit “del” or “can’t delete” error with “shift+del”. All files seem have root ownership (had to run testdisk with sudo, was that the cause?).
Where is the problem and what can I do? I’m running EOS with KDE.
Thanks in advance for the patience and pointers.
