Do I need to create a log? (https://0x0.st/H-e9.txt). This is just a copy of my terminal window:
[gabor@gabor-inspiron3847 ~]$ yay -S ventoy
:: Checking for conflicts...
:: Checking for inner conflicts...
[Aur:1] ventoy-1.0.89-1
1 ventoy (Build Files Exist)
==> Packages to cleanBuild?
:: PKGBUILD up to date, Skipping (1/0): ventoy
==> Diffs to show?
:: (1/1) Parsing SRCINFO: ventoy
==> Making package: ventoy 1.0.89-1 (Fri 17 Mar 2023 16:07:09 GMT)
==> Retrieving sources...
-> Found ventoy-1.0.89.tar.gz
-> Found grub-2.04.tar.xz
-> Found ventoy-grub-fix-build-with-binutils-2.36.patch
-> Updating ipxe git repo...
-> Found edk2-stable201911.zip
-> Found ventoy-fix-ucs-2-lookup-on-python-3.9.patch
-> Found ventoy-fix-array.array.tostring-removal-in-python-3.9.patch
-> Found dietlibc-0.34.tar.xz
-> Found dietlibc-headers-fix.patch
-> Found musl-1.2.3.tar.gz
-> Found kernel-headers-musl-4.19.88.tar.gz
-> Found fuse-2.9.9.tar.gz
-> Found exfat-1.3.0.tar.gz
-> Found zlib-1.2.13.tar.gz
-> Found squashfs-tools-4.4.tar.gz
-> Found device-mapper-1.02.28-2.el5.src.rpm
-> Found zstd-1.0.0.tar.gz
-> Found xz-embedded-20130513.tar.gz
-> Found busybox-1.32.0.tar.bz2
-> Found cryptsetup-1.7.5.tar.xz
-> Found wimboot-2.7.3.tar.gz
==> Validating source files with sha256sums...
ventoy-1.0.89.tar.gz ... Passed
grub-2.04.tar.xz ... Passed
ventoy-grub-fix-build-with-binutils-2.36.patch ... Passed
ipxe ... Skipped
edk2-stable201911.zip ... Passed
ventoy-fix-ucs-2-lookup-on-python-3.9.patch ... Passed
ventoy-fix-array.array.tostring-removal-in-python-3.9.patch ... FAILED
dietlibc-0.34.tar.xz ... Passed
dietlibc-headers-fix.patch ... Passed
musl-1.2.3.tar.gz ... Passed
kernel-headers-musl-4.19.88.tar.gz ... Passed
fuse-2.9.9.tar.gz ... Passed
exfat-1.3.0.tar.gz ... Passed
zlib-1.2.13.tar.gz ... Passed
squashfs-tools-4.4.tar.gz ... Passed
device-mapper-1.02.28-2.el5.src.rpm ... Passed
zstd-1.0.0.tar.gz ... Passed
xz-embedded-20130513.tar.gz ... Passed
busybox-1.32.0.tar.bz2 ... Passed
cryptsetup-1.7.5.tar.xz ... Passed
wimboot-2.7.3.tar.gz ... Passed
==> ERROR: One or more files did not pass the validity check!
-> error downloading sources: ventoy
context: exit status 1
==> Making package: ventoy 1.0.89-1 (Fri 17 Mar 2023 16:07:11 GMT)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
ipxe ... Skipped
-> error making: ventoy
