Hi all, back again ! So, a few distros later,i came back to Endeavour/ Deepin BUT:
i’m struggling to install my printer …
HP Deskjet 2630 - cups is not working so i installed hplip & nothing !
Does anyone has a clue ?
I must say that a printer is quite useful these days…
AND i had no trouble with former distros !
Many thanks & have a nice day/night
Fred.
Have you already looked at EnOS Wiki:
https://endeavouros.com/docs/hardware-and-network/printers/
I normally use hp-setup for my hp printer. You can type hp-setup (ip address of printer) then it’ll pop up a box and you can follow instructions from there.
Make sure you have cups service enabled (reboot after)
Thanks @pebcak , i’ll have a good look !
Cups troublesouting ?
I’ll check !
Cheers
F.
Many thanks @OdiousImp but i wonder…
The link is physical so why should i use ip ?
Cant run hp-setup though…For the time beeing !
I have afternoon to find out !
Not that complicate ! Cups and/or Hplip running BUT they are not finding this {#^\¹¹printer !
Link ok, wifi ok…
Cheers
F.
Oh if its physical link you can just run hp-setup and pick to connect via cable.
@OdiousImp …I try & choose ! Guess it cant be both ?
usb & wifi ?
F.
@OdiousImp & @OdiousImp
A bit early but…Bon appetit !
(fr-FR/UTF8)
Fred.
The current version of the HPLIP solution is version 3.20.11
If you check the list of printers supported on hplip the Deskjet 2630 seems to not be in !
https://developers.hp.com/hp-linux-imaging-and-printing/supported_devices/index
Bonjour @FLVAL …strange !
I un-installed then re-install hplip & no way !
Nothing appears…
I even get an icon saying i’m offline !
How come i have access to the forum ???
OK, another tea might do
Most HP printers will use hplip, some may use hpojAUR, while for multifunction laser printers hpuldAUR might be required. Some laser printers are also supported by foo2zjs-nightlyAUR.
https://wiki.archlinux.org/index.php/CUPS/Printer-specific_problems#HP
@OdiousImp & @pebcak …
So this xlfpy)ç"printer is recognized by …Cups !!!
Thanks for help, in fact i added what was mentioned by @pebcak, so it might very well work !
(Tea might have been of some help ! Ahahahah)
I’ll check AUR as said by @OdiousImp …Just in case !
Best & take good care
Fred.
The cups enable command has changed. It is no longer org.cups.cupsd.service
. It is now sudo systemctl enable cups.service
Morning’ & thanks @davidw …I think its done…
For, i did not impress anything yet, but this printer
is now beeing seen.
So i just think it works ==> sudo systemctl enable cups.service
I dont care that much beeing quite sure that i’ll have to
print stuff quite soon…For a noble or compulsary cause i guess !
Nice day
Fred.
