Printer HP does not want to work after EOS crash
Perhaps it’s the Firewall now causing a problem?..
https://discovery.endeavouros.com/applications/firewalld/2022/03/
For the whole thing to work, of course (!) - next to installing drivers, and system-config-printer, what is basic for all to function? - This:
sudo pacman -S cups
sudo systemctl enable cups.service
sudo systemctl start --now cups.service
Hope this helps!
No, 99,99%
sudo pacman -S cups
It was done.
I did all once again.
The same problem. This is mini PC.
And - the same by notebook.
I needed EOS install - because Grub Update Causing Unbootable OS On UEFI Systems
Before that, everything was working without any problems.
if firewalld is the issue one thing to find out:
sudo systemctl stop firewalld
sudo systemctl restart cups.service
I think, first you need to reboot after that step before you can continue to set the printer-config up further.
Also, take a look here:
https://wiki.archlinux.org/title/CUPS#Network
Djivili ! :clinking_glasses:
Yes, it is made.
I have added second printer …
Status by HP1 (first HP) is now “Unable to locate printer “hostname””
no “Rendering completed”, as by HP.
And one more thing:
I have second notebook.
Instead of EOS is Manjaro recently installed.
There is no problem. PRINTING is OK!
To discover, make use of discovered or share printers using DNS-SD/mDNS, setup .local hostname resolution with Avahi and restart cups.service.
Note: DNS-SD is only supported when using Avahi. CUPS does not support using systemd-resolved for DNS-SD, see CUPS issue 5452.
To share printers with Samba, e.g. if the system is to be a print server for Windows clients, the samba package will be required.
pacman -Qs nss-mdns
https://discovery.endeavouros.com/printers/printers/2021/03/
and Firewall is blocking avahi per default … if firewall does not allow ipp and ipp-client to path you can not get network printer working over avahi…
and avahi needs local hostname resolution enabled to be able to … get the hostname :wink:
Then, edit the file /etc/nsswitch.conf and change the hosts line to include mdns_minimal [NOTFOUND=return] before resolve and dns
thats comparing apples and pears :slight_smile:
if its blocks then printer not works.
Edit - is made.
hosts: mymachines mdns_minimal [NOTFOUND=return]resolve [!UNAVAIL=return] files myhostname dns
networks: files
Und -
vlm@dh370 ~]$ pacman -Qs nss-mdns
local/nss-mdns 0.15.1-1
glibc plugin providing host name resolution via mDNS
[vlm@dh370 ~]$ sudo chmod 757 /etc/nsswitch.conf
Nevertheless …
NoPr2022-09-11 23-32-59
Did that?
See again, under…
“Firewall is blocking…:”
at 2022-09-12 00-00-35
Status - Unable to locate printer "hostname
Do not want----
Futher tomorrow.
Thanks very much
I think the problem is clear, partially
Two pictures.
I change item “enable” - do check, then click “Apply” and Ok.
Scrat 2022-09-12 20-36-20
In 2-4 sec. is again without “check”!!!
myself, I do nothing at all. !!!
Screenshot2 at 2022-09-12 20-36-50
You can n times check, but system do it back!!!
Have , it is a pity, no idea… :sob:
2022-09-12_21-11
you miss the space there ?
this is not applied nor setup permanently if you do not save and restart the firewall…
  1. Yes, space missing.
    I have corrected.
  2. this is not applied nor setup permanently if you do nor save and restart the firewa
    It is saved and restarted.
  3. No changes, “enable” is becoming again unchecked.
just disable firewall complely…sudo systemdctl stop firewalld , if that stil not work then should be the firewall … stop or disable --now … you may choose
[vlm@dh370 ~]$ systemctl disable firewalld
Removed “/etc/systemd/system/dbus-org.fedoraproject.FirewallD1.service”.
Removed “/etc/systemd/system/multi-user.target.wants/firewalld.service”.
[vlm@dh370 ~]$
Is this OK?
Here no changes
systemctl disable --now firewalld
now systemctl stop firewalld
only disable is for next boot
