I have two installations of EndeavourOS with (almost) identical packages, but the power-profiles do not show up in the battery icon of plasma panel for the AMD system (but works fine in the ). Is there any extra package/setting needed for the AMD system?
$ inxi -Fazy
Kernel: 6.6.32-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
clocksource: hpet avail: acpi_pm
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts
root=UUID=c010296d-3369-4f43-9aea-9fc986743fa2 rw rootflags=subvol=@
nowatchdog nvme_load=YES loglevel=3 zswap.enabled=0 amd_pstate=active
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
wm: kwin_wayland vt: 1 dm: SDDM Distro: EndeavourOS base: Arch Linux
Type: Laptop System: HP product: HP 245 G7 Notebook PC v: N/A
Mobo: HP model: 85B1 v: 84.54 serial: <superuser required>
part-nu: 2D8C6PA#ACJ uuid: <superuser required> UEFI: AMI v: F.70
date: 07/18/2023
Battery:
ID-1: BAT0 charge: 11.4 Wh (30.7%) condition: 37.1/37.1 Wh (100.0%)
volts: 10.9 min: 11.3 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: discharging
Device-1: hid-f4:73:35:1e:61:f1-battery model: Bluetooth Mouse
M336/M337/M535 serial: N/A charge: N/A status: discharging
Device-2: hidpp_battery_0 model: Logitech Wireless Keyboard
serial: <filter> charge: 55% (should be ignored) rechargeable: yes
status: discharging
Info: model: AMD Ryzen 3 3300U with Radeon Vega Mobile Gfx bits: 64 type: MCP
arch: Zen/Zen+ note: check gen: 1 level: v3 note: check built: 2019
process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
microcode: 0x8108109
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1414 high: 1621 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1238
3: 1400 4: 1621 bogomips: 16775
Vulnerabilities:
Type: gather_data_sampling status: Not affected
Type: reg_file_data_sampling status: Not affected
Type: retbleed mitigation: untrained return thunk; SMT disabled
Type: spec_rstack_overflow mitigation: SMT disabled
prctl
sanitization
Type: spectre_v2 mitigation: Retpolines; IBPB: conditional; STIBP:
disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 46.0 C
Device-2: Cheng Uei Precision Industry (Foxlink) HP TrueVision HD Camera
driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-4:3 chip-ID: 05c8:03d2 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_wayland driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 res: 1366x768 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi
device: 1 drv: swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 6 Graphics (radeonsi
raven LLVM 17.0.6 DRM 3.54 6.6.32-1-lts) device-ID: 1002:15d8
memory: 1.95 GiB unified: no display-ID: :1.0
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 04:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.6.32-1-lts status: kernel-api
Server-1: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: eno1 state: down mac: <filter>
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Hewlett-Packard driver: rtw_8822be v: N/A modules: rtw88_8822be pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
chip-ID: 10ec:b822 class-ID: 0280
Info: services: NetworkManager, systemd-timesyncd, wpa_supplicant
Bluetooth:
Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 0bda:b00b
class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.2
lmp-v: 8 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 1.14 TiB used: 9.32 GiB (0.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital
model: WD Blue SN570 250GB size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: 234110WD temp: 45.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-60Z10T0
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1A04 scheme: GPT
ID-1: / raw-size: 231.88 GiB size: 231.88 GiB (100.00%) used: 9.32 GiB (4.0%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 231.88 GiB size: 231.88 GiB (100.00%)
used: 9.32 GiB (4.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 231.88 GiB size: 231.88 GiB (100.00%)
Kernel: swappiness: 60 (default) cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: zram size: 5.7 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 4 dev: /dev/zram0
System Temperatures: cpu: 47.6 C mobo: N/A gpu: amdgpu temp: 47.0 C
Fan Speeds (rpm): N/A
Memory: total: 6 GiB note: est. available: 5.7 GiB used: 2.47 GiB (43.3%)
Processes: 241 Power: uptime: 11m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 2.27 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 255 default: graphical
tool: systemctl
Packages: pm: pacman pkgs: 1086 libs: 247 tools: yay Compilers: gcc: 14.1.1
Shell: Zsh v: 5.9 default: Bash v: 5.2.26 running-in: wezterm-gui
inxi: 3.3.34
