I have encountered the “energy mode” problem again. If I try to use the command indicated by dzyndzla the mode actually changes to performance, but then there is no way to change it again, except with a reboot. However the behavior is different from the initial situation, where the switch changes for half a second and then returns to balanced, after running the command echo performance | sudo tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor the switch does not change position at all.
By default all the file /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor are setted to powersave.
I’m using the power-profiles-daemon package version 0.23-1, on Gnome 47.1 kernel 6.11.7-zen1-1-zen (the PC is an HP ENVY x360 2-in-1 Laptop)
What could be the problem?
Thanks
simdll
Note, this isn’t a duplicate of this, but the old topic is lock, so I have open a new one.
