Power Off Upon Lid Close
I noticed starting just a few days ago, that closing the lid for a while then opening it again I find my laptop turned off! (it happened once or twice long time back, but I didn’t pay attention) but over the past few days it happens whenever I close the lid for some time.
My power settings is “do nothing” whether on AC, Battery or Low Battery.
Just tested now, I closed the lid for 10 seconds and opened again, it was still on.
I do not understand why, what causes this.
How can I fix this?
There’s a lot of missing information to even vaguely be able to guess how to help. I know you’ve asked several questions, so you know we need more info to get started.
Sorry, here is my inxi:
[limo@asus ~]$ inxi -Fxxx
  Host: asus Kernel: 6.1.34-1-lts arch: x86_64 bits: 64 compiler: gcc
    v: 13.1.1 Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 1
    dm: SDDM Distro: EndeavourOS base: Arch Linux
  Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X415FAC_X415FA
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: X415FAC v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: X415FAC.202 date: 07/08/2021
Battery:
  ID-1: BAT0 charge: 34.2 Wh (100.0%) condition: 34.2/37.1 Wh (92.0%)
    volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: not charging cycles: 10
  Info: dual core model: Intel Core i3-10110U bits: 64 type: MT MCP
    smt: enabled arch: Comet/Whiskey Lake note: check rev: C cache: L1: 128 KiB
    L2: 512 KiB L3: 4 MiB
  Speed (MHz): avg: 3958 high: 4101 min/max: 400/4100 cores: 1: 3958 2: 4073
    3: 3700 4: 4101 bogomips: 20810
  Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
    v: kernel arch: Gen-9.5 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:9b41 class-ID: 0300
  Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-5:3 chip-ID: 13d3:56e6
    class-ID: 0e02 serial: 0000
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: intel unloaded: modesetting alternate: fbdev,vesa dri: i965
    gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31")
  Monitor-1: eDP-1 mapped: eDP1 model: ChiMei InnoLux 0x14d6 res: 1366x768
    hz: 60 dpi: 112 size: 310x170mm (12.2x6.69") diag: 354mm (13.9")
    modes: 1366x768
  API: OpenGL v: 4.6 Mesa 23.1.2 renderer: Mesa Intel UHD Graphics (CML GT2)
    direct-render: Yes
  Device-1: Intel Comet Lake PCH-LP cAVS vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0403
  API: ALSA v: k6.1.34-1-lts status: kernel-api
  Server-1: PipeWire v: 0.3.71 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin
  Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
  IF: wlan0 state: up mac: 7c:70:db:e2:29:ee
Bluetooth:
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 bus-ID: 1-10:5
    chip-ID: 8087:0aaa class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: disabled
  Local Storage: total: 244.54 GiB used: 163.57 GiB (66.9%)
  ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN530
    SDBPNPZ-256G-1002 size: 238.47 GiB speed: 31.6 Gb/s lanes: 4 tech: SSD
    serial: 2127HE443513 fw-rev: 21106000 temp: 33.9 C scheme: GPT
  ID-2: /dev/sda model: Kindle Internal Storage size: 6.07 GiB type: USB
    rev: 2.0 spd: 480 Mb/s lanes: 1 tech: N/A serial: G000WL05152409UM
    fw-rev: 0401
  ID-1: / size: 238.17 GiB used: 160.67 GiB (67.5%) fs: btrfs
    dev: /dev/nvme0n1p2
  ID-2: /home size: 238.17 GiB used: 160.67 GiB (67.5%) fs: btrfs
    dev: /dev/nvme0n1p2
  ID-3: /var/log size: 238.17 GiB used: 160.67 GiB (67.5%) fs: btrfs
    dev: /dev/nvme0n1p2
  System Temperatures: cpu: 70.0 C pch: 51.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 3800
  Processes: 228 Uptime: 1h 32m wakeups: 2 Memory: available: 19.38 GiB
  used: 3.77 GiB (19.4%) Init: systemd v: 253 default: graphical Compilers:
  gcc: 13.1.1 clang: 15.0.7 Packages: 3028 pm: pacman pkgs: 1514 pm: rpm
  pkgs: N/A note: see --rpm Shell: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.27
[limo@asus ~]$
Any other info required just let me know.
I appreciate your support.
Possibly related, but it shouldn’t.
If some running process(es) were power hungry and the battery went down, the system would die anyway.
You should check journal of your lost boot sessions for signs of the reason to shutdown. :person_shrugging:
That was my first red flag.
Do you have hybrid sleep or something to tell it to hibernate somewhere? It’s probably trying to hibernate and falling because there’s no swap.
Do I need swap? I have 20GB RAM.
My settings are not to hibernate nor sleep!
Lid close is set to “do nothing”
You need swap for hibernation. If your laptop tries to hibernate and there is no swap it will simply die, which will look like a regular poweroff.
What is the content of /etc/systemd/logind.conf and /etc/systemd/sleep.conf ?
What is the journal saying? When it happens and the laptop reboots, please show the log from the last boot"journalctl -b -1".
#  This file is part of systemd.
#  systemd is free software; you can redistribute it and/or modify it under the
#  terms of the GNU Lesser General Public License as published by the Free
#  Software Foundation; either version 2.1 of the License, or (at your option)
#  any later version.
# Entries in this file show the compile time defaults. Local configuration
# should be created by either modifying this file, or by creating "drop-ins" in
# the logind.conf.d/ subdirectory. The latter is generally recommended.
# Defaults can be restored by simply deleting this file and all drop-ins.
# Use 'systemd-analyze cat-config systemd/logind.conf' to display the full config.
# See logind.conf(5) for details.
[Login]
#NAutoVTs=6
#ReserveVT=6
#KillUserProcesses=no
#KillOnlyUsers=
#KillExcludeUsers=root
#InhibitDelayMaxSec=5
#UserStopDelaySec=10
#HandlePowerKey=poweroff
#HandlePowerKeyLongPress=ignore
#HandleRebootKey=reboot
#HandleRebootKeyLongPress=poweroff
#HandleSuspendKey=suspend
#HandleSuspendKeyLongPress=hibernate
#HandleHibernateKey=hibernate
#HandleHibernateKeyLongPress=ignore
#HandleLidSwitch=suspend
#HandleLidSwitchExternalPower=suspend
#HandleLidSwitchDocked=ignore
#PowerKeyIgnoreInhibited=no
#SuspendKeyIgnoreInhibited=no
#HibernateKeyIgnoreInhibited=no
#LidSwitchIgnoreInhibited=yes
#RebootKeyIgnoreInhibited=no
#HoldoffTimeoutSec=30s
#IdleAction=ignore
#IdleActionSec=30min
#RuntimeDirectorySize=10%
#RuntimeDirectoryInodesMax=
#RemoveIPC=yes
#InhibitorsMax=8192
#SessionsMax=8192
#StopIdleSessionSec=infinity
# the sleep.conf.d/ subdirectory. The latter is generally recommended.
# See systemd-sleep.conf(5) for details.
[Sleep]
#AllowSuspend=yes
#AllowHibernation=yes
#AllowSuspendThenHibernate=yes
#AllowHybridSleep=yes
#SuspendMode=
#SuspendState=mem standby freeze
#HibernateMode=platform shutdown
#HibernateState=disk
#HybridSleepMode=suspend platform shutdown
#HybridSleepState=disk
#HibernateDelaySec=
#SuspendEstimationSec=60min
[limo@asus ~]$ journalctl -b -1
Jun 20 20:50:31 asus kernel: microcode: microcode updated early to revision 0xf6>
Jun 20 20:50:31 asus kernel: Linux version 6.1.34-1-lts (linux-lts@archlinux) (g>
Jun 20 20:50:31 asus kernel: Command line: initrd=\a9d690a5d1c144ee81cbb0b9de665>
Jun 20 20:50:31 asus kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 float>
Jun 20 20:50:31 asus kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE regis>
Jun 20 20:50:31 asus kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX regis>
Jun 20 20:50:31 asus kernel: x86/fpu: Supporting XSAVE feature 0x008: 'MPX bound>
Jun 20 20:50:31 asus kernel: x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
Jun 20 20:50:31 asus kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  >
Jun 20 20:50:31 asus kernel: x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:  >
Jun 20 20:50:31 asus kernel: x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:  >
Jun 20 20:50:31 asus kernel: x86/fpu: Enabled xstate features 0x1f, context size>
Jun 20 20:50:31 asus kernel: signal: max sigframe size: 2032
Jun 20 20:50:31 asus kernel: BIOS-provided physical RAM map:
Jun 20 20:50:31 asus kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009df>
Jun 20 20:50:31 asus kernel: BIOS-e820: [mem 0x000000000009e000-0x000000000009ef>
Jun 20 20:50:31 asus kernel: BIOS-e820: [mem 0x000000000009f000-0x000000000009ff>
Jun 20 20:50:31 asus kernel: BIOS-e820: [mem 0x00000000000a0000-0x00000000000fff>
Jun 20 20:50:31 asus kernel: BIOS-e820: [mem 0x0000000000100000-0x00000000975e8f>
Jun 20 20:50:31 asus kernel: BIOS-e820: [mem 0x00000000975e9000-0x00000000991dbf>
lines 1-20
Too many!
This is not enough. Specifically the end of the journal is of interest. Try journalctl -b -1 --no-pager
b://limo.local/limo/home/
Jun 21 01:45:41 asus kopia-ui[998]: 00:45:41.008 › error fetching status Internal Server Error
Jun 21 01:45:43 asus lsyncd[503]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 01:45:43 asus lsyncd[503]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 01:45:44 asus kopia-ui[998]: 00:45:44.011 › error fetching status Internal Server Error
Jun 21 01:45:44 asus kopia-ui[998]: 00:45:44.012 › error fetching status Internal Server Error
Jun 21 01:45:46 asus lsyncd[503]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 01:45:46 asus lsyncd[503]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 01:45:46 asus lsyncd[503]: Error, Cannot open status file "/var/log/lsyncd/status.log" :/var/log/lsyncd/status.log: No such file or directory
Jun 21 01:45:47 asus kopia-ui[998]: 00:45:47.011 › error fetching status Internal Server Error
Jun 21 01:45:47 asus kopia-ui[998]: 00:45:47.012 › error fetching status Internal Server Error
Jun 21 01:45:50 asus kopia-ui[998]: 00:45:50.015 › error fetching status Internal Server Error
Jun 21 01:45:50 asus lsyncd[503]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 01:45:50 asus lsyncd[503]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 01:45:53 asus kopia-ui[998]: 00:45:53.016 › error fetching status Internal Server Error
Jun 21 01:45:53 asus lsyncd[503]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 01:45:53 asus lsyncd[503]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 01:45:56 asus kopia-ui[998]: 00:45:56.019 › error fetching status Internal Server Error
Jun 21 01:45:56 asus lsyncd[503]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 01:45:56 asus lsyncd[503]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 01:45:59 asus kopia-ui[998]: 00:45:59.021 › error fetching status Internal Server Error
Jun 21 01:45:59 asus kopia-ui[998]: 00:45:59.022 › error fetching status Internal Server Error
Jun 21 01:45:59 asus lsyncd[503]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 01:45:59 asus lsyncd[503]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 01:46:02 asus kopia-ui[998]: 00:46:02.024 › error fetching status Internal Server Error
Jun 21 01:46:02 asus kopia-ui[998]: 00:46:02.025 › error fetching status Internal Server Error
Jun 21 01:46:03 asus lsyncd[503]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 01:46:03 asus lsyncd[503]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 01:46:03 asus lsyncd[503]: Error, Cannot open status file "/var/log/lsyncd/status.log" :/var/log/lsyncd/status.log: No such file or directory
Jun 21 01:46:05 asus kopia-ui[998]: 00:46:05.028 › error fetching status Internal Server Error
Jun 21 01:46:06 asus lsyncd[503]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 01:46:06 asus lsyncd[503]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 01:46:08 asus kopia-ui[998]: 00:46:08.028 › error fetching status Internal Server Error
Jun 21 01:46:09 asus lsyncd[503]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 01:46:09 asus lsyncd[503]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 01:46:11 asus kopia-ui[998]: 00:46:11.031 › error fetching status Internal Server Error
Jun 21 01:46:11 asus kopia-ui[998]: 00:46:11.032 › error fetching status Internal Server Error
Jun 21 01:46:13 asus lsyncd[503]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 01:46:13 asus lsyncd[503]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 01:46:14 asus kopia-ui[998]: 00:46:14.035 › error fetching status Internal Server Error
Jun 21 01:46:16 asus lsyncd[503]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 01:46:16 asus lsyncd[503]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 01:46:17 asus kopia-ui[998]: 00:46:17.038 › error fetching status Internal Server Error
Jun 21 01:46:19 asus lsyncd[503]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 01:46:19 asus lsyncd[503]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 01:46:19 asus lsyncd[503]: Error, Cannot open status file "/var/log/lsyncd/status.log" :/var/log/lsyncd/status.log: No such file or directory
Jun 21 01:46:20 asus kopia-ui[998]: 00:46:20.040 › error fetching status Internal Server Error
Jun 21 01:46:22 asus lsyncd[503]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 01:46:22 asus lsyncd[503]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 01:46:23 asus kopia-ui[998]: 00:46:23.041 › error fetching status Internal Server Error
Jun 21 01:46:26 asus kopia-ui[998]: 00:46:26.044 › error fetching status Internal Server Error
Jun 21 01:46:26 asus kopia-ui[998]: 00:46:26.045 › error fetching status Internal Server Error
Jun 21 01:46:26 asus lsyncd[503]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 01:46:26 asus lsyncd[503]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 01:46:29 asus kopia-ui[998]: 00:46:29.048 › error fetching status Internal Server Error
Jun 21 01:46:29 asus lsyncd[503]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 01:46:29 asus lsyncd[503]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 01:46:32 asus kopia-ui[998]: 00:46:32.051 › error fetching status Internal Server Error
Jun 21 01:46:32 asus lsyncd[503]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 01:46:32 asus lsyncd[503]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 01:46:36 asus lsyncd[503]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 01:46:36 asus lsyncd[503]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 01:46:36 asus lsyncd[503]: Error, Cannot open status file "/var/log/lsyncd/status.log" :/var/log/lsyncd/status.log: No such file or directory
[limo@asus ~]$
I see there are a lot of errors!
Are these enough?
This is not the full journal. Please provide the full journal. You may need to run the command with sudo.
What we need to see is the journal at the point in time when you close the lid.
Sorry, I got it you care about the latest lines. Here is it in full:
Jun 21 11:28:36 asus lsyncd[623]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 11:28:36 asus lsyncd[623]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 11:28:37 asus lsyncd[623]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 11:28:37 asus lsyncd[623]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 11:28:38 asus lsyncd[623]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 11:28:38 asus lsyncd[623]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 11:28:38 asus kernel: usb 1-1: new high-speed USB device number 15 using xhci_hcd
Jun 21 11:28:38 asus kernel: usb 1-1: New USB device found, idVendor=ffff, idProduct=5678, bcdDevice= 2.00
Jun 21 11:28:38 asus kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jun 21 11:28:38 asus kernel: usb 1-1: Product: Disk 2.0
Jun 21 11:28:38 asus kernel: usb 1-1: Manufacturer: USB
Jun 21 11:28:38 asus kernel: usb 1-1: SerialNumber: 3592041143277418
Jun 21 11:28:38 asus kernel: usb-storage 1-1:1.0: USB Mass Storage device detected
Jun 21 11:28:38 asus kernel: scsi host3: usb-storage 1-1:1.0
Jun 21 11:28:38 asus mtp-probe[105348]: checking bus 1, device 15: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1"
Jun 21 11:28:38 asus mtp-probe[105348]: bus: 1, device: 15 was not an MTP device
Jun 21 11:28:38 asus mtp-probe[105360]: checking bus 1, device 15: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1"
Jun 21 11:28:38 asus mtp-probe[105360]: bus: 1, device: 15 was not an MTP device
Jun 21 11:28:38 asus lsyncd[623]: Error, Cannot open status file "/var/log/lsyncd/status.log" :/var/log/lsyncd/status.log: No such file or directory
Jun 21 11:28:39 asus lsyncd[623]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 11:28:39 asus lsyncd[623]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 11:28:39 asus kernel: scsi 3:0:0:0: Direct-Access     VendorCo ProductCode      2.00 PQ: 0 ANSI: 4
Jun 21 11:28:39 asus kernel: sd 3:0:0:0: [sdb] 30720000 512-byte logical blocks: (15.7 GB/14.6 GiB)
Jun 21 11:28:39 asus kernel: sd 3:0:0:0: [sdb] Write Protect is off
Jun 21 11:28:39 asus kernel: sd 3:0:0:0: [sdb] Mode Sense: 03 00 00 00
Jun 21 11:28:39 asus kernel: sd 3:0:0:0: [sdb] No Caching mode page found
Jun 21 11:28:39 asus kernel: sd 3:0:0:0: [sdb] Assuming drive cache: write through
Jun 21 11:28:39 asus kernel:  sdb: sdb1 sdb2
Jun 21 11:28:39 asus kernel: sd 3:0:0:0: [sdb] Attached SCSI removable disk
Jun 21 11:28:39 asus dbus-daemon[619]: [system] Activating service name='org.kde.kded.smart' requested by ':1.22' (uid=1000 pid=775 comm="/usr/bin/kded5") (using servicehelper)
Jun 21 11:28:39 asus dbus-daemon[619]: [system] Successfully activated service 'org.kde.kded.smart'
Jun 21 11:28:39 asus kernel: ISO 9660 Extensions: Microsoft Joliet Level 3
Jun 21 11:28:39 asus kernel: ISO 9660 Extensions: RRIP_1991A
Jun 21 11:28:39 asus udisksd[867]: Mounted /dev/sdb1 at /run/media/limo/SPARKY_64bit on behalf of uid 1000
Jun 21 11:28:39 asus plasmashell[832]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/DeviceItem.qml:36:5: Unable to assign [undefined] to bool
Jun 21 11:28:39 asus plasmashell[832]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/DeviceItem.qml:35:5: Unable to assign [undefined] to bool
Jun 21 11:28:40 asus lsyncd[623]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 11:28:40 asus lsyncd[623]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 11:28:41 asus lsyncd[623]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 11:28:41 asus lsyncd[623]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 11:28:42 asus lsyncd[623]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 11:28:42 asus lsyncd[623]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 11:28:43 asus lsyncd[623]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 11:28:43 asus lsyncd[623]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 11:28:44 asus lsyncd[623]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 11:28:44 asus lsyncd[623]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 11:28:45 asus lsyncd[623]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 11:28:45 asus lsyncd[623]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 11:28:46 asus lsyncd[623]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 11:28:46 asus lsyncd[623]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 11:28:47 asus lsyncd[623]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 11:28:47 asus lsyncd[623]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 11:28:47 asus dbus-daemon[737]: [session uid=1000 pid=737] Activating service name='org.kde.LogoutPrompt' requested by ':1.12' (uid=1000 pid=832 comm="/usr/bin/plasmashell --no-respawn")
Jun 21 11:28:48 asus dbus-daemon[737]: [session uid=1000 pid=737] Successfully activated service 'org.kde.LogoutPrompt'
Jun 21 11:28:48 asus lsyncd[623]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 11:28:48 asus lsyncd[623]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 11:28:49 asus lsyncd[623]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 11:28:49 asus lsyncd[623]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 11:28:49 asus lsyncd[623]: Error, Cannot open status file "/var/log/lsyncd/status.log" :/var/log/lsyncd/status.log: No such file or directory
Jun 21 11:28:49 asus dbus-daemon[737]: [session uid=1000 pid=737] Activating service name='org.kde.Shutdown' requested by ':1.190' (uid=1000 pid=105529 comm="/usr/lib/ksmserver-logout-greeter")
Jun 21 11:28:49 asus dbus-daemon[737]: [session uid=1000 pid=737] Successfully activated service 'org.kde.Shutdown'
Jun 21 11:28:50 asus pcloud[993]: GdkWindow 0x3400008 unexpectedly destroyed
Jun 21 11:28:50 asus polkitd[630]: Unregistered Authentication Agent for unix-session:1 (system bus name :1.36, object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_AG) (disconnected from bus)
Jun 21 11:28:50 asus kded5[775]: Service  ":1.37" unregistered
Jun 21 11:28:50 asus kded5[775]: Service  ":1.28" unregistered
Jun 21 11:28:50 asus systemd[721]: app-org.kde.kdeconnect.daemon@autostart.service: Consumed 1.007s CPU time.
Jun 21 11:28:50 asus systemd[721]: Stopped target plasma-workspace-x11.target.
Jun 21 11:28:50 asus systemd[721]: Stopped target KDE Plasma Workspace.
Jun 21 11:28:50 asus systemd[721]: Stopped KDE Session Management Server.
Jun 21 11:28:50 asus systemd[721]: Stopped KDE Plasma Workspace.
Jun 21 11:28:50 asus systemd[721]: plasma-plasmashell.service: Consumed 1min 16.632s CPU time.
Jun 21 11:28:50 asus systemd[721]: Stopped Proxies GTK DBus menus to a Plasma readable format.
Jun 21 11:28:50 asus systemd[721]: Stopped Track hardware statistics.
Jun 21 11:28:50 asus systemd[721]: plasma-ksystemstats.service: Consumed 16.801s CPU time.
Jun 21 11:28:50 asus systemd[721]: Stopped target Startup of XDG autostart applications.
Jun 21 11:28:50 asus systemd[721]: Stopping pcloud...
Jun 21 11:28:50 asus systemd[721]: Stopping Firewall Applet...
Jun 21 11:28:50 asus systemd[721]: Stopping Accessibility...
Jun 21 11:28:50 asus systemd[721]: Stopping kopia-ui...
Jun 21 11:28:50 asus systemd[721]: Stopping Recoll real time indexer...
Jun 21 11:28:50 asus systemd[721]: Stopping Accessibility services bus...
Jun 21 11:28:50 asus systemd[721]: Stopping KDE Global Shortcuts Server...
Jun 21 11:28:50 asus systemd[721]: Stopping KScreen...
Jun 21 11:28:50 asus systemd[721]: Stopping KDE Window Manager...
Jun 21 11:28:50 asus systemd[721]: Stopping Powerdevil...
Jun 21 11:28:50 asus systemd[721]: Stopped KDE Global Shortcuts Server.
Jun 21 11:28:50 asus systemd[721]: plasma-kglobalaccel.service: Consumed 2.130s CPU time.
Jun 21 11:28:50 asus systemd[721]: Stopped KScreen.
Jun 21 11:28:50 asus systemd[721]: Stopped Powerdevil.
Jun 21 11:28:50 asus systemd[721]: plasma-powerdevil.service: Consumed 1.144s CPU time.
Jun 21 11:28:50 asus systemd[721]: Stopped target KDE Plasma Workspace Core.
Jun 21 11:28:50 asus systemd[721]: Stopping KDE Daemon...
Jun 21 11:28:50 asus kopia-ui[1000]: [1000:0621/112850.117920:ERROR:network_service_instance_impl.cc(541)] Network service crashed, restarting service.
Jun 21 11:28:50 asus at-spi-bus-launcher[1682]: Failed to launch bus: Bus exited with code 0
Jun 21 11:28:50 asus systemd[721]: at-spi-dbus-bus.service: Main process exited, code=exited, status=1/FAILURE
Jun 21 11:28:50 asus systemd[721]: at-spi-dbus-bus.service: Failed with result 'exit-code'.
Jun 21 11:28:50 asus systemd[721]: Stopped Accessibility services bus.
Jun 21 11:28:50 asus kded5[775]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Jun 21 11:28:50 asus kopia-ui[1000]: [1000:0621/112850.147595:ERROR:zygote_communication_linux.cc(291)] Failed to send GetTerminationStatus message to zygote
Jun 21 11:28:50 asus systemd[721]: Stopped Firewall Applet.
Jun 21 11:28:50 asus systemd[721]: app-firewall\x2dapplet@autostart.service: Consumed 5.599s CPU time.
Jun 21 11:28:50 asus systemd[721]: Stopped Accessibility.
Jun 21 11:28:50 asus kopia-ui[1000]: [1000:0621/112850.165676:ERROR:gpu_process_host.cc(937)] GPU process launch failed: error_code=1002
Jun 21 11:28:50 asus systemd-logind[624]: The system will reboot now!
Jun 21 11:28:50 asus systemd-logind[624]: System is rebooting.
Jun 21 11:28:50 asus lsyncd[623]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 255
Jun 21 11:28:50 asus lsyncd[623]: Normal, recursive full rsync: /home/limo/ -> smb://limo.local/limo/home/
Jun 21 11:28:50 asus systemd[1]: Stopping Session 1 of User limo...
Jun 21 11:28:50 asus sddm[668]: Authentication error: "Process crashed"
Jun 21 11:28:50 asus sddm[668]: Auth: sddm-helper crashed (exit code 15)
Jun 21 11:28:50 asus sddm[668]: Auth: sddm-helper exited with 15
Jun 21 11:28:50 asus sddm[668]: Display server stopping...
Jun 21 11:28:50 asus kopia-ui[1000]: [1000:0621/112850.193005:ERROR:gpu_process_host.cc(937)] GPU process launch failed: error_code=1002
Jun 21 11:28:50 asus kopia-ui[1000]: [1000:0621/112850.201123:ERROR:gpu_process_host.cc(937)] GPU process launch failed: error_code=1002
Jun 21 11:28:50 asus plasmashell[1624]: [1624:1624:0621/112850.202593:ERROR:connection.cc(46)] X connection error received.
Jun 21 11:28:50 asus plasmashell[1624]: XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
Jun 21 11:28:50 asus plasmashell[1624]:       after 1185555 requests (1185555 known processed) with 0 events remaining.
Jun 21 11:28:50 asus kiod5[52504]: The X11 connection broke (error 1). Did the X11 server die?
Jun 21 11:28:50 asus kiod5[52504]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Jun 21 11:28:50 asus systemd[1]: Removed slice Slice /system/getty.
Jun 21 11:28:50 asus kactivitymanagerd[861]: The X11 connection broke (error 1). Did the X11 server die?
Jun 21 11:28:50 asus systemd[721]: app-org.kde.dolphin-dc139900f6424de1802a9e7a50ba124f.scope: Consumed 1.767s CPU time.
Jun 21 11:28:50 asus systemd[1]: Removed slice Slice /system/modprobe.
Jun 21 11:28:50 asus systemd[1]: Stopped target Bluetooth Support.
Jun 21 11:28:50 asus systemd[1]: Stopped target Graphical Interface.
Jun 21 11:28:50 asus systemd[1]: Stopped target Multi-User System.
Jun 21 11:28:50 asus systemd[1]: Stopped target Login Prompts.
Jun 21 11:28:50 asus systemd[1]: Stopped target Sound Card.
Jun 21 11:28:50 asus systemd[1]: Stopped target Timer Units.
Jun 21 11:28:50 asus systemd[1]: archlinux-keyring-wkd-sync.timer: Deactivated successfully.
Jun 21 11:28:50 asus systemd[1]: Stopped Refresh existing PGP keys of archlinux-keyring regularly.
Jun 21 11:28:50 asus systemd[1]: fstrim.timer: Deactivated successfully.
Jun 21 11:28:50 asus systemd[1]: Stopped Discard unused filesystem blocks once a week.
Jun 21 11:28:50 asus systemd[1]: logrotate.timer: Deactivated successfully.
Jun 21 11:28:50 asus systemd[1]: Stopped Daily rotation of log files.
Jun 21 11:28:50 asus systemd[1]: man-db.timer: Deactivated successfully.
Jun 21 11:28:50 asus systemd[1]: Stopped Daily man-db regeneration.
Jun 21 11:28:50 asus systemd[1]: paccache.timer: Deactivated successfully.
Jun 21 11:28:50 asus systemd[1]: Stopped Discard unused packages weekly.
Jun 21 11:28:50 asus systemd[1]: shadow.timer: Deactivated successfully.
Jun 21 11:28:50 asus systemd[1]: Stopped Daily verification of password and group files.
Jun 21 11:28:50 asus systemd[1]: snapper-boot.timer: Deactivated successfully.
Jun 21 11:28:50 asus systemd[1]: Stopped Take snapper snapshot of root on boot.
Jun 21 11:28:50 asus systemd[1]: snapper-cleanup.timer: Deactivated successfully.
Jun 21 11:28:50 asus systemd[1]: Stopped Daily Cleanup of Snapper Snapshots.
Jun 21 11:28:50 asus systemd[1]: snapper-timeline.timer: Deactivated successfully.
Jun 21 11:28:50 asus systemd[1]: Stopped Timeline of Snapper Snapshots.
Jun 21 11:28:50 asus systemd[1]: systemd-tmpfiles-clean.timer: Deactivated successfully.
Jun 21 11:28:50 asus systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Jun 21 11:28:50 asus systemd[1]: updatedb.timer: Deactivated successfully.
Jun 21 11:28:50 asus systemd[1]: Stopped Daily locate database update.
Jun 21 11:28:50 asus systemd[1]: Stopped target System Time Set.
Jun 21 11:28:50 asus systemd[1]: lvm2-lvmpolld.socket: Deactivated successfully.
Jun 21 11:28:50 asus systemd[721]: plasma-kactivitymanagerd.service: Main process exited, code=exited, status=1/FAILURE
Jun 21 11:28:50 asus systemd[721]: plasma-kactivitymanagerd.service: Failed with result 'exit-code'.
Jun 21 11:28:50 asus systemd[721]: Stopped KActivityManager Activity manager Service.
Jun 21 11:28:50 asus systemd[721]: plasma-kactivitymanagerd.service: Consumed 14.946s CPU time.
Jun 21 11:28:50 asus systemd[1]: Closed LVM2 poll daemon socket.
Jun 21 11:28:50 asus systemd[1]: systemd-rfkill.socket: Deactivated successfully.
Jun 21 11:28:50 asus systemd[721]: app-kopia\x2dui@autostart.service: Main process exited, code=exited, status=1/FAILURE
Jun 21 11:28:50 asus systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Jun 21 11:28:50 asus systemd[1]: Stopping Save/Restore Sound Card State...
Jun 21 11:28:50 asus avahi-daemon[618]: Got SIGTERM, quitting.
Jun 21 11:28:50 asus systemd[1]: Stopping Avahi mDNS/DNS-SD Stack...
Jun 21 11:28:50 asus avahi-daemon[618]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fdb4:f58e:15ed:a500:1076:b0f6:11b:6858.
Jun 21 11:28:50 asus systemd[1]: Stopping CUPS Scheduler...
Jun 21 11:28:50 asus avahi-daemon[618]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.1.103.
Jun 21 11:28:50 asus systemd[1]: Stopping Restore /run/initramfs on shutdown...
Jun 21 11:28:50 asus avahi-daemon[618]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1.
Jun 21 11:28:50 asus systemd[1]: Stopping synchronization daemon...
Jun 21 11:28:50 asus avahi-daemon[618]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Jun 21 11:28:50 asus systemd[1]: Stopping Power Profiles daemon...
Jun 21 11:28:50 asus avahi-daemon[618]: avahi-daemon 0.8 exiting.
Jun 21 11:28:50 asus systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
Jun 21 11:28:50 asus systemd[1]: Stopping Simple Desktop Display Manager...
Jun 21 11:28:50 asus systemd[1]: Stopping Disk Manager...
Jun 21 11:28:50 asus systemd[1]: Stopping Daemon for power management...
Jun 21 11:28:50 asus systemd[721]: app-kopia\x2dui@autostart.service: Failed with result 'exit-code'.
Jun 21 11:28:50 asus systemd[721]: Stopped kopia-ui.
Jun 21 11:28:50 asus systemd[721]: app-kopia\x2dui@autostart.service: Consumed 24.713s CPU time.
Jun 21 11:28:50 asus systemd[1]: tmp-.mount_pcloudUAkdKp.mount: Deactivated successfully.
Jun 21 11:28:50 asus lsyncd[623]: Normal, --- TERM signal, fading ---
Jun 21 11:28:50 asus lsyncd[623]: Normal, waiting for 1 more child processes.
Jun 21 11:28:50 asus udisksd[867]: udisks daemon version 2.9.4 exiting
Jun 21 11:28:50 asus systemd[1]: Unmounted /tmp/.mount_pcloudUAkdKp.
Jun 21 11:28:50 asus systemd[1]: avahi-daemon.service: Deactivated successfully.
Jun 21 11:28:50 asus systemd[721]: Stopped KDE Daemon.
Jun 21 11:28:50 asus systemd[721]: plasma-kded.service: Consumed 6.285s CPU time.
Jun 21 11:28:50 asus systemd[1]: Stopped Avahi mDNS/DNS-SD Stack.
Jun 21 11:28:50 asus systemd[1]: power-profiles-daemon.service: Deactivated successfully.
Jun 21 11:28:50 asus systemd[1]: Stopped Power Profiles daemon.
Jun 21 11:28:50 asus systemd[1]: cups.service: Deactivated successfully.
Jun 21 11:28:50 asus systemd[721]: Stopped KDE Window Manager.
Jun 21 11:28:50 asus systemd[721]: plasma-kwin_x11.service: Consumed 2min 38.290s CPU time.
Jun 21 11:28:50 asus systemd[1]: Stopped CUPS Scheduler.
Jun 21 11:28:50 asus systemd[1]: udisks2.service: Deactivated successfully.
Jun 21 11:28:50 asus systemd[1]: Stopped Disk Manager.
Jun 21 11:28:50 asus systemd[1]: upower.service: Deactivated successfully.
Jun 21 11:28:50 asus systemd[1]: Stopped Daemon for power management.
Jun 21 11:28:50 asus systemd[1]: rtkit-daemon.service: Deactivated successfully.
Jun 21 11:28:50 asus systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
Jun 21 11:28:50 asus systemd[1]: alsa-restore.service: Deactivated successfully.
Jun 21 11:28:50 asus systemd[1]: Stopped Save/Restore Sound Card State.
Jun 21 11:28:50 asus systemd[1]: dracut-shutdown.service: Deactivated successfully.
Jun 21 11:28:50 asus systemd[721]: app-chromium-4413ed67b800428685d91c93632d0c6c.scope: Consumed 40min 45.323s CPU time.
Jun 21 11:28:50 asus systemd[1]: Stopped Restore /run/initramfs on shutdown.
Jun 21 11:28:50 asus systemd[1]: session-1.scope: Deactivated successfully.
Jun 21 11:28:50 asus systemd[1]: Stopped Session 1 of User limo.
Jun 21 11:28:50 asus systemd[1]: Stopping User Manager for UID 1000...
Jun 21 11:28:50 asus systemd-logind[624]: Session 1 logged out. Waiting for processes to exit.
Jun 21 11:28:50 asus systemd[721]: Activating special unit Exit the Session...
Jun 21 11:28:50 asus systemd[721]: Removed slice User Background Tasks Slice.
Jun 21 11:28:50 asus systemd[721]: background.slice: Consumed 37.725s CPU time.
Jun 21 11:28:50 asus systemd[721]: Stopped target Bluetooth.
Jun 21 11:28:50 asus systemd[721]: Stopped target Main User Target.
Jun 21 11:28:50 asus systemd[721]: Stopped target Sound Card.
Jun 21 11:28:50 asus systemd-logind[624]: Removed session 1.
Jun 21 11:28:50 asus systemd[721]: Stopping D-Bus User Message Bus...
Jun 21 11:28:50 asus systemd[721]: Stopping User preferences database...
Jun 21 11:28:50 asus systemd[721]: Stopping Bluetooth OBEX service...
Jun 21 11:28:50 asus systemd[721]: Stopping PipeWire PulseAudio...
Jun 21 11:28:50 asus obexd[938]: Terminating
Jun 21 11:28:50 asus wireplumber[1236]: Error releasing name org.freedesktop.ReserveDevice1.Audio0: The connection is closed
Jun 21 11:28:50 asus systemd[721]: Stopped Bluetooth OBEX service.
Jun 21 11:28:50 asus systemd[721]: Stopped User preferences database.
Jun 21 11:28:50 asus systemd[721]: Stopped PipeWire PulseAudio.
Jun 21 11:28:50 asus systemd[721]: pipewire-pulse.service: Consumed 5.806s CPU time.
Jun 21 11:28:50 asus systemd[721]: Stopping Multimedia Service Session Manager...
Jun 21 11:28:50 asus wireplumber[1236]: stopped by signal: Terminated
Jun 21 11:28:50 asus systemd[721]: Stopped D-Bus User Message Bus.
Jun 21 11:28:50 asus systemd[721]: dbus.service: Consumed 3.924s CPU time.
Jun 21 11:28:50 asus wireplumber[1236]: disconnected from pipewire
Jun 21 11:28:50 asus systemd[721]: Stopped Multimedia Service Session Manager.
Jun 21 11:28:50 asus systemd[721]: wireplumber.service: Consumed 1.899s CPU time.
Jun 21 11:28:50 asus systemd[721]: Stopping PipeWire Multimedia Service...
Jun 21 11:28:50 asus systemd[721]: Stopped PipeWire Multimedia Service.
Jun 21 11:28:50 asus systemd[721]: pipewire.service: Consumed 5.410s CPU time.
Jun 21 11:28:50 asus systemd[721]: Removed slice User Core Session Slice.
Jun 21 11:28:50 asus systemd[721]: session.slice: Consumed 4min 19.456s CPU time.
Jun 21 11:28:50 asus sddm[668]: Display server stopped.
Jun 21 11:28:50 asus sddm[668]: Running display stop script  "/usr/share/sddm/scripts/Xstop"
Jun 21 11:28:50 asus sddm[668]: Removing display ":0" ...
Jun 21 11:28:50 asus sddm[668]: Adding new display on vt 1 ...
Jun 21 11:28:50 asus sddm[668]: Loading theme configuration from ""
Jun 21 11:28:50 asus sddm[668]: Display server starting...
Jun 21 11:28:50 asus sddm[668]: Adding cookie to "/var/run/sddm/{94ec3706-98c4-408d-b2b0-436e0c1b7983}"
Jun 21 11:28:50 asus sddm[668]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{94ec3706-98c4-408d-b2b0-436e0c1b7983} -noreset -displayfd 18
Jun 21 11:28:50 asus systemd[721]: Stopped Recoll real time indexer.
Jun 21 11:28:50 asus systemd[721]: app-recollindex@autostart.service: Consumed 1min 2.574s CPU time.
Jun 21 11:28:50 asus lsyncd[623]: Normal, Retrying startup of /home/limo/ -> smb://limo.local/limo/home/: 20
Jun 21 11:28:50 asus systemd[1]: lsyncd.service: Main process exited, code=exited, status=143/n/a
Jun 21 11:28:50 asus systemd[1]: lsyncd.service: Failed with result 'exit-code'.
Jun 21 11:28:50 asus systemd[1]: Stopped synchronization daemon.
Jun 21 11:28:50 asus systemd[1]: lsyncd.service: Consumed 2h 4min 52.899s CPU time.
Jun 21 11:28:50 asus systemd[1]: home-limo-pCloudDrive.mount: Deactivated successfully.
Jun 21 11:28:50 asus systemd[1]: Unmounted /home/limo/pCloudDrive.
Jun 21 11:28:51 asus systemd[721]: Stopped pcloud.
Jun 21 11:28:51 asus systemd[721]: app-appimagekit\x2dpcloud@autostart.service: Consumed 19.956s CPU time.
Jun 21 11:28:51 asus systemd[721]: Stopped target Current graphical user session.
Jun 21 11:28:51 asus systemd[721]: Stopped target Session services which should run early before the graphical session is brought up.
Jun 21 11:28:51 asus systemd[721]: Stopped target Basic System.
Jun 21 11:28:51 asus systemd[721]: Stopped target Paths.
Jun 21 11:28:51 asus systemd[721]: Stopped target Sockets.
Jun 21 11:28:51 asus systemd[721]: Stopped target Timers.
Jun 21 11:28:51 asus systemd[721]: Stopped EOS update notifier runs periodically (weekly) and soon after a reboot.
Jun 21 11:28:51 asus systemd[721]: Closed D-Bus User Message Bus Socket.
Jun 21 11:28:51 asus systemd[721]: Closed GnuPG network certificate management daemon.
Jun 21 11:28:51 asus systemd[721]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jun 21 11:28:51 asus systemd[721]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Jun 21 11:28:51 asus systemd[721]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Jun 21 11:28:51 asus systemd[721]: Closed GnuPG cryptographic agent and passphrase cache.
Jun 21 11:28:51 asus systemd[721]: Closed p11-kit server.
Jun 21 11:28:51 asus systemd[721]: Closed PipeWire PulseAudio.
Jun 21 11:28:51 asus systemd[721]: Closed PipeWire Multimedia System Socket.
Jun 21 11:28:51 asus systemd[721]: Removed slice User Application Slice.
Jun 21 11:28:51 asus systemd[721]: app.slice: Consumed 49min 35.274s CPU time.
Jun 21 11:28:51 asus systemd[721]: Reached target Shutdown.
Jun 21 11:28:51 asus systemd[721]: Finished Exit the Session.
Jun 21 11:28:51 asus systemd[721]: Reached target Exit the Session.
Jun 21 11:28:51 asus (sd-pam)[722]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[limo] ruser=[<unknown>] rhost=[<unknown>]
Jun 21 11:28:51 asus systemd[1]: user@1000.service: Deactivated successfully.
Jun 21 11:28:51 asus systemd[1]: Stopped User Manager for UID 1000.
Jun 21 11:28:51 asus systemd[1]: user@1000.service: Consumed 54min 33.008s CPU time.
Jun 21 11:28:51 asus systemd[1]: Stopping User Runtime Directory /run/user/1000...
Jun 21 11:28:51 asus systemd[1]: run-user-1000.mount: Deactivated successfully.
Jun 21 11:28:51 asus systemd[1]: Unmounted /run/user/1000.
Jun 21 11:28:51 asus systemd[1]: user-runtime-dir@1000.service: Deactivated successfully.
Jun 21 11:28:51 asus systemd[1]: Stopped User Runtime Directory /run/user/1000.
Jun 21 11:28:51 asus systemd[1]: Removed slice User Slice of UID 1000.
Jun 21 11:28:51 asus systemd[1]: user-1000.slice: Consumed 54min 33.401s CPU time.
Jun 21 11:28:51 asus sddm[668]: Setting default cursor
Jun 21 11:28:51 asus sddm[668]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Jun 21 11:28:51 asus sddm[668]: Display server started.
Jun 21 11:28:51 asus sddm[668]: Socket server starting...
Jun 21 11:28:51 asus sddm[668]: Socket server started.
Jun 21 11:28:51 asus sddm[668]: Loading theme configuration from "/usr/share/sddm/themes/breeze/theme.conf"
Jun 21 11:28:51 asus sddm[668]: Greeter starting...
Jun 21 11:28:51 asus sddm[668]: Signal received: SIGTERM
Jun 21 11:28:51 asus sddm[668]: Socket server stopping...
Jun 21 11:28:51 asus sddm[668]: Socket server stopped.
Jun 21 11:28:51 asus sddm[668]: Display server stopping...
Jun 21 11:28:51 asus sddm-helper[105627]: [PAM] Starting...
Jun 21 11:28:51 asus sddm-helper[105627]: [PAM] Authenticating...
Jun 21 11:28:51 asus sddm-helper[105627]: [PAM] returning.
Jun 21 11:28:51 asus sddm[668]: Display server stopped.
Jun 21 11:28:51 asus sddm[668]: Running display stop script  "/usr/share/sddm/scripts/Xstop"
Jun 21 11:28:51 asus sddm[668]: QProcess: Destroyed while process ("/usr/lib/sddm/sddm-helper") is still running.
Jun 21 11:28:51 asus systemd[1]: sddm.service: Deactivated successfully.
Jun 21 11:28:51 asus systemd[1]: Stopped Simple Desktop Display Manager.
Jun 21 11:28:51 asus systemd[1]: sddm.service: Consumed 2min 25.249s CPU time.
Jun 21 11:28:51 asus systemd[1]: Stopping User Login Management...
Jun 21 11:28:51 asus systemd[1]: Stopping Permit User Sessions...
Jun 21 11:28:51 asus systemd[1]: systemd-user-sessions.service: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Stopped Permit User Sessions.
Jun 21 11:28:52 asus systemd[1]: systemd-logind.service: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Stopped User Login Management.
Jun 21 11:28:52 asus systemd[1]: Stopped target Network.
Jun 21 11:28:52 asus systemd[1]: Stopped target Remote File Systems.
Jun 21 11:28:52 asus systemd[1]: Stopping Network Manager...
Jun 21 11:28:52 asus NetworkManager[650]: <info>  [1687336132.0309] caught SIGTERM, shutting down normally.
Jun 21 11:28:52 asus NetworkManager[650]: <info>  [1687336132.0312] device (wlan0): state change: activated -> deactivating (reason 'unmanaged', sys-iface-state: 'managed')
Jun 21 11:28:52 asus NetworkManager[650]: <info>  [1687336132.0314] manager: NetworkManager state is now DISCONNECTING
Jun 21 11:28:52 asus systemd[1]: Stopping WPA supplicant...
Jun 21 11:28:52 asus wpa_supplicant[713]: p2p-dev-wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Jun 21 11:28:52 asus wpa_supplicant[713]: nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
Jun 21 11:28:52 asus dbus-daemon[619]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.9' (uid=0 pid=650 comm="/usr/bin/NetworkManager --no-daemon")
Jun 21 11:28:52 asus dbus-daemon[619]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus is shutting down.
Jun 21 11:28:52 asus NetworkManager[650]: <warn>  [1687336132.0322] dispatcher: (8) failed (after 0.000 sec): Refusing activation, D-Bus is shutting down.
Jun 21 11:28:52 asus NetworkManager[650]: <info>  [1687336132.0324] device (wlan0): state change: deactivating -> unmanaged (reason 'removed', sys-iface-state: 'managed')
Jun 21 11:28:52 asus NetworkManager[650]: <info>  [1687336132.0325] dhcp4 (wlan0): canceled DHCP transaction
Jun 21 11:28:52 asus NetworkManager[650]: <info>  [1687336132.0325] dhcp4 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Jun 21 11:28:52 asus NetworkManager[650]: <info>  [1687336132.0325] dhcp4 (wlan0): state changed no lease
Jun 21 11:28:52 asus NetworkManager[650]: <info>  [1687336132.0326] dhcp6 (wlan0): canceled DHCP transaction
Jun 21 11:28:52 asus NetworkManager[650]: <info>  [1687336132.0326] dhcp6 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Jun 21 11:28:52 asus NetworkManager[650]: <info>  [1687336132.0327] dhcp6 (wlan0): state changed no lease
Jun 21 11:28:52 asus wpa_supplicant[713]: p2p-dev-wlan0: CTRL-EVENT-TERMINATING
Jun 21 11:28:52 asus kernel: wlan0: deauthenticating from 5c:a6:e6:67:eb:eb by local choice (Reason: 3=DEAUTH_LEAVING)
Jun 21 11:28:52 asus wpa_supplicant[713]: wlan0: CTRL-EVENT-DISCONNECTED bssid=5c:a6:e6:67:eb:eb reason=3 locally_generated=1
Jun 21 11:28:52 asus wpa_supplicant[713]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Jun 21 11:28:52 asus NetworkManager[650]: <info>  [1687336132.1793] manager: NetworkManager state is now DISCONNECTED
Jun 21 11:28:52 asus NetworkManager[650]: <info>  [1687336132.1803] device (p2p-dev-wlan0): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Jun 21 11:28:52 asus NetworkManager[650]: <info>  [1687336132.1845] exiting (success)
Jun 21 11:28:52 asus systemd[1]: NetworkManager.service: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Stopped Network Manager.
Jun 21 11:28:52 asus systemd[1]: NetworkManager.service: Consumed 10.799s CPU time.
Jun 21 11:28:52 asus systemd[1]: Stopped target Preparation for Network.
Jun 21 11:28:52 asus systemd[1]: Stopping firewalld - dynamic firewall daemon...
Jun 21 11:28:52 asus wpa_supplicant[713]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Jun 21 11:28:52 asus wpa_supplicant[713]: wlan0: CTRL-EVENT-TERMINATING
Jun 21 11:28:52 asus systemd[1]: wpa_supplicant.service: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Stopped WPA supplicant.
Jun 21 11:28:52 asus systemd[1]: firewalld.service: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Stopped firewalld - dynamic firewall daemon.
Jun 21 11:28:52 asus polkitd[630]: Lost the name org.freedesktop.PolicyKit1 - exiting
Jun 21 11:28:52 asus systemd[1]: Stopping D-Bus System Message Bus...
Jun 21 11:28:52 asus systemd[1]: Stopping Authorization Manager...
Jun 21 11:28:52 asus systemd[1]: dbus.service: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Stopped D-Bus System Message Bus.
Jun 21 11:28:52 asus systemd[1]: dbus.service: Consumed 8.880s CPU time.
Jun 21 11:28:52 asus systemd[1]: polkit.service: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Stopped Authorization Manager.
Jun 21 11:28:52 asus systemd[1]: Stopped target Basic System.
Jun 21 11:28:52 asus systemd[1]: Stopped target Path Units.
Jun 21 11:28:52 asus systemd[1]: cups.path: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Stopped CUPS Scheduler.
Jun 21 11:28:52 asus systemd[1]: Stopped target Slice Units.
Jun 21 11:28:52 asus systemd[1]: Removed slice User and Session Slice.
Jun 21 11:28:52 asus systemd[1]: user.slice: Consumed 54min 33.401s CPU time.
Jun 21 11:28:52 asus systemd[1]: Stopped target Socket Units.
Jun 21 11:28:52 asus systemd[1]: avahi-daemon.socket: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
Jun 21 11:28:52 asus systemd[1]: cups.socket: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Closed CUPS Scheduler.
Jun 21 11:28:52 asus systemd[1]: dbus.socket: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Closed D-Bus System Message Bus Socket.
Jun 21 11:28:52 asus systemd[1]: Stopped target System Initialization.
Jun 21 11:28:52 asus systemd[1]: proc-sys-fs-binfmt_misc.automount: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Unset automount Arbitrary Executable File Formats File System Automount Point.
Jun 21 11:28:52 asus systemd[1]: Stopped target Local Encrypted Volumes.
Jun 21 11:28:52 asus systemd[1]: systemd-ask-password-console.path: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
Jun 21 11:28:52 asus systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Jun 21 11:28:52 asus systemd[1]: Stopped target Local Integrity Protected Volumes.
Jun 21 11:28:52 asus systemd[1]: Stopped target Local Verity Protected Volumes.
Jun 21 11:28:52 asus systemd[1]: Stopping Load/Save Screen Backlight Brightness of backlight:intel_backlight...
Jun 21 11:28:52 asus systemd[1]: systemd-boot-random-seed.service: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Stopped Update Boot Loader Random Seed.
Jun 21 11:28:52 asus systemd[1]: Stopping Load/Save OS Random Seed...
Jun 21 11:28:52 asus systemd[1]: systemd-sysctl.service: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Stopped Apply Kernel Variables.
Jun 21 11:28:52 asus systemd[1]: systemd-coredump.socket: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Closed Process Core Dump Socket.
Jun 21 11:28:52 asus systemd[1]: systemd-modules-load.service: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Stopped Load Kernel Modules.
Jun 21 11:28:52 asus systemd[1]: Stopping Network Time Synchronization...
Jun 21 11:28:52 asus systemd[1]: systemd-update-done.service: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Stopped Update is Completed.
Jun 21 11:28:52 asus systemd[1]: ldconfig.service: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Stopped Rebuild Dynamic Linker Cache.
Jun 21 11:28:52 asus systemd[1]: systemd-journal-catalog-update.service: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Stopped Rebuild Journal Catalog.
Jun 21 11:28:52 asus systemd[1]: Stopping Record System Boot/Shutdown in UTMP...
Jun 21 11:28:52 asus systemd[1]: run-credentials-systemd\x2dsysctl.service.mount: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Unmounted /run/credentials/systemd-sysctl.service.
Jun 21 11:28:52 asus systemd[1]: systemd-timesyncd.service: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Stopped Network Time Synchronization.
Jun 21 11:28:52 asus systemd[1]: systemd-backlight@backlight:intel_backlight.service: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Stopped Load/Save Screen Backlight Brightness of backlight:intel_backlight.
Jun 21 11:28:52 asus systemd[1]: systemd-random-seed.service: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Stopped Load/Save OS Random Seed.
Jun 21 11:28:52 asus systemd[1]: Removed slice Slice /system/systemd-backlight.
Jun 21 11:28:52 asus systemd[1]: systemd-update-utmp.service: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
Jun 21 11:28:52 asus systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
Jun 21 11:28:52 asus systemd[1]: Stopped Create Volatile Files and Directories.
Jun 21 11:28:52 asus systemd[1]: Stopped target Local File Systems.
Jun 21 11:28:52 asus systemd[1]: Unmounting /efi...
Jun 21 11:28:52 asus systemd[1]: Unmounting /home...
Jun 21 11:28:52 asus systemd[1]: Unmounting /run/credentials/systemd-sysusers.service...
Jun 21 11:28:52 asus systemd[1]: Unmounting /run/credentials/systemd-tmpfiles-setup.service...
Jun 21 11:28:52 asus umount[105647]: umount: /run/credentials/systemd-tmpfiles-setup.service: no mount point specified.
Jun 21 11:28:52 asus systemd[1]: Unmounting /run/credentials/systemd-tmpfiles-setup-dev.service...
Jun 21 11:28:52 asus systemd[1]: Unmounting /run/media/limo/SPARKY_64bit...
Jun 21 11:28:52 asus systemd[1]: Unmounting Temporary Directory /tmp...
Jun 21 11:28:52 asus systemd[1]: Unmounting /var/cache...
Jun 21 11:28:52 asus systemd[1]: Stopping Flush Journal to Persistent Storage...
Jun 21 11:28:52 asus systemd[1]: efi.mount: Deactivated successfully.
Are you sure this log is from an unattended shutdown after LidClose?
It seems it starts from here:
Can you find (in the same log) what is the process with pid=832 ?
pastebin exist …
I do not know what you are showing here. Is this a relevant journal with a “lid close” activity?
What I can see here is a normal shutdown activity which stops all relevant services.
And I see a login manager (sddm) with issues:
I do not think so, as I see the dates and time are so recent not after 10:00 PM last night
Yes, I manually rebooted actually.
I will close the lid now for a few minutes and see what happens. If it switched off I will post again the log.
By the way, I uninstalled lsyncd as I don’t need it for now.
Sorry, I never used it. I will appreciate if you guide me how to use it, I honestly saw some posts using it but… sorry, I don’t know how to!
Update: Closing lid 14:13
Back:14:23 (didn’t shut down!)
I will wait till it does it again and post.
Closing lid again 14:32
Opened lid: 19:03 (didn’t shut down!)
:man_facepalming:
A journal of a regular shutdown has nothing to do with your issue and is useless. I specifically requested: “What we need to see is the journal at the point in time when you close the lid.”
This is strange?!!!
I think more than 4 hours are supposed to be enough!
Google is pretty simple.
