I use systemctl suspend to manually suspend my laptop before closing, but very often I find that when I take my laptop out of my bag it has shut off (not hibernated, etc.).
My logind.conf is completely stock (all commented out), so I haven’t changed lid close behavior or anything like that.
I have included two journalctl logs that seem to show something like entering suspend mode and then the next entry is the first part of a boot. I’ve marked the shutdown times with <--- reboot happens below ---> so they can be found easily.
Other possibly important info (happy to provide more if needed):
Framework laptop (Intel 11th gen)
Using TLP for some power management
Log 1
Mar 23 13:27:04 schur tlp[784709]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Mar 23 13:27:04 schur tlp[784709]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Mar 23 13:27:04 schur tlp[784709]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Mar 23 13:27:04 schur tlp[784709]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Mar 23 13:27:04 schur tlp[784739]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Mar 23 13:27:04 schur tlp[784739]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Mar 23 13:27:04 schur tlp[784739]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Mar 23 13:27:04 schur tlp[784739]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Mar 23 13:27:04 schur tlp[784790]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Mar 23 13:27:04 schur tlp[784790]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Mar 23 13:27:04 schur tlp[784790]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Mar 23 13:27:04 schur tlp[784790]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Mar 23 13:27:14 schur systemd-logind[623]: Suspending...
Mar 23 13:27:14 schur NetworkManager[630]: <info> [1679596034.9112] manager: sleep: sleep requested (sleeping: no enabled: yes)
Mar 23 13:27:14 schur NetworkManager[630]: <info> [1679596034.9114] device (p2p-dev-wlan0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 23 13:27:14 schur NetworkManager[630]: <info> [1679596034.9119] manager: NetworkManager state is now ASLEEP
Mar 23 13:27:14 schur NetworkManager[630]: <info> [1679596034.9121] device (wlan0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Mar 23 13:27:14 schur dbus-daemon[621]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.7' (uid=0 pid=630 comm="/usr/bin/NetworkManager --no-daemon")
Mar 23 13:27:14 schur systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 23 13:27:14 schur dbus-daemon[621]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Mar 23 13:27:14 schur systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 23 13:27:14 schur kernel: wlan0: deauthenticating from d8:47:32:da:59:ca by local choice (Reason: 3=DEAUTH_LEAVING)
Mar 23 13:27:15 schur wpa_supplicant[760]: wlan0: CTRL-EVENT-DISCONNECTED bssid=d8:47:32:da:59:ca reason=3 locally_generated=1
Mar 23 13:27:15 schur wpa_supplicant[760]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Mar 23 13:27:15 schur NetworkManager[630]: <info> [1679596035.1159] device (wlan0): supplicant interface state: completed -> disconnected
Mar 23 13:27:15 schur NetworkManager[630]: <info> [1679596035.1163] device (wlan0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Mar 23 13:27:15 schur avahi-daemon[618]: Withdrawing address record for fe80::6318:aa1c:89ad:6e03 on wlan0.
Mar 23 13:27:15 schur avahi-daemon[618]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::6318:aa1c:89ad:6e03.
Mar 23 13:27:15 schur avahi-daemon[618]: Interface wlan0.IPv6 no longer relevant for mDNS.
Mar 23 13:27:15 schur NetworkManager[630]: <info> [1679596035.1380] dhcp4 (wlan0): canceled DHCP transaction
Mar 23 13:27:15 schur NetworkManager[630]: <info> [1679596035.1381] dhcp4 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Mar 23 13:27:15 schur NetworkManager[630]: <info> [1679596035.1381] dhcp4 (wlan0): state changed no lease
Mar 23 13:27:15 schur avahi-daemon[618]: Interface wlan0.IPv4 no longer relevant for mDNS.
Mar 23 13:27:15 schur avahi-daemon[618]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.0.103.
Mar 23 13:27:15 schur avahi-daemon[618]: Withdrawing address record for 192.168.0.103 on wlan0.
Mar 23 13:27:15 schur NetworkManager[630]: <info> [1679596035.1648] device (wlan0): set-hw-addr: set MAC address to 96:9F:0E:5F:E5:34 (scanning)
Mar 23 13:27:15 schur avahi-daemon[618]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.0.103.
Mar 23 13:27:15 schur avahi-daemon[618]: New relevant interface wlan0.IPv4 for mDNS.
Mar 23 13:27:15 schur avahi-daemon[618]: Registering new address record for 192.168.0.103 on wlan0.IPv4.
Mar 23 13:27:15 schur dnsmasq[793]: no servers found in /etc/resolv.conf, will retry
Mar 23 13:27:15 schur NetworkManager[630]: <info> [1679596035.1937] device (wlan0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 23 13:27:15 schur NetworkManager[630]: <info> [1679596035.3339] device (wlan0): set-hw-addr: reset MAC address to E4:A4:71:56:AB:D0 (unmanage)
Mar 23 13:27:15 schur systemd[1]: Reached target Sleep.
Mar 23 13:27:15 schur wpa_supplicant[760]: p2p-dev-wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Mar 23 13:27:15 schur wpa_supplicant[760]: nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
Mar 23 13:27:15 schur systemd[1]: Starting System Suspend...
Mar 23 13:27:15 schur wpa_supplicant[760]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Mar 23 13:27:15 schur systemd-sleep[785183]: Entering sleep state 'suspend'...
Mar 23 13:27:15 schur kernel: PM: suspend entry (s2idle)
Mar 23 13:27:15 schur kernel: Filesystems sync: 0.010 seconds
Mar 23 13:29:51 schur kernel: Freezing user space processes
Mar 23 13:29:51 schur kernel: Freezing user space processes completed (elapsed 0.004 seconds)
Mar 23 13:29:51 schur kernel: OOM killer disabled.
Mar 23 13:29:51 schur kernel: Freezing remaining freezable tasks
Mar 23 13:29:51 schur kernel: Freezing remaining freezable tasks completed (elapsed 0.129 seconds)
Mar 23 13:29:51 schur kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Mar 23 13:29:51 schur kernel: ACPI: EC: interrupt blocked
Mar 23 13:29:51 schur kernel: ACPI: EC: interrupt unblocked
Mar 23 13:29:51 schur kernel: nvme nvme0: 8/0/0 default/read/poll queues
Mar 23 13:29:51 schur kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
Mar 23 13:29:51 schur kernel: OOM killer enabled.
Mar 23 13:29:51 schur kernel: Restarting tasks ...
Mar 23 13:29:51 schur kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915])
Mar 23 13:29:51 schur kernel: done.
Mar 23 13:29:51 schur kernel: random: crng reseeded on system resumption
Mar 23 13:29:51 schur kernel: thermal thermal_zone5: failed to read out thermal zone (-61)
Mar 23 13:29:51 schur bluetoothd[711]: Controller resume with wake event 0x0
Mar 23 13:29:51 schur systemd-sleep[785183]: System returned from sleep state.
Mar 23 13:29:51 schur kernel: PM: suspend exit
Mar 23 13:29:51 schur systemd[1]: blueman-mechanism.service: Deactivated successfully.
Mar 23 13:29:51 schur systemd[1]: systemd-suspend.service: Deactivated successfully.
Mar 23 13:29:51 schur systemd[1]: Finished System Suspend.
Mar 23 13:29:51 schur systemd[1]: Stopped target Sleep.
Mar 23 13:29:51 schur systemd[1]: Reached target Suspend.
Mar 23 13:29:51 schur systemd[1]: Stopped target Suspend.
Mar 23 13:29:51 schur systemd-logind[623]: Operation 'sleep' finished.
Mar 23 13:29:51 schur NetworkManager[630]: <info> [1679596191.5136] manager: sleep: wake requested (sleeping: yes enabled: yes)
Mar 23 13:29:51 schur NetworkManager[630]: <info> [1679596191.5137] device (wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 23 13:29:51 schur NetworkManager[630]: <info> [1679596191.7741] device (p2p-dev-wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 23 13:29:51 schur NetworkManager[630]: <info> [1679596191.7746] manager: NetworkManager state is now CONNECTED_LOCAL
Mar 23 13:29:51 schur NetworkManager[630]: <info> [1679596191.8181] device (wlan0): supplicant interface state: internal-starting -> disconnected
Mar 23 13:29:51 schur NetworkManager[630]: <info> [1679596191.8182] device (p2p-dev-wlan0): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Mar 23 13:29:51 schur NetworkManager[630]: <info> [1679596191.8191] Wi-Fi P2P device controlled by interface wlan0 created
Mar 23 13:29:51 schur NetworkManager[630]: <info> [1679596191.8196] manager: (p2p-dev-wlan0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/38)
Mar 23 13:29:51 schur NetworkManager[630]: <info> [1679596191.8202] device (p2p-dev-wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 23 13:29:51 schur NetworkManager[630]: <info> [1679596191.8214] device (wlan0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Mar 23 13:29:51 schur NetworkManager[630]: <info> [1679596191.8223] device (p2p-dev-wlan0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 23 13:29:55 schur wpa_supplicant[760]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=US
Mar 23 13:29:58 schur systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mar 23 13:30:13 schur dunst[1670]: WARNING: No icon found in path: 'system-software-update'
Mar 23 13:30:15 schur dunst[1670]: WARNING: No icon found in path: 'appointment-soon'
Mar 23 13:30:18 schur systemd-logind[623]: Suspending...
Mar 23 13:30:18 schur NetworkManager[630]: <info> [1679596218.6879] manager: sleep: sleep requested (sleeping: no enabled: yes)
Mar 23 13:30:18 schur NetworkManager[630]: <info> [1679596218.6880] device (wlan0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 23 13:30:18 schur wpa_supplicant[760]: p2p-dev-wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Mar 23 13:30:18 schur wpa_supplicant[760]: nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
Mar 23 13:30:18 schur NetworkManager[630]: <info> [1679596218.7602] device (p2p-dev-wlan0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 23 13:30:18 schur NetworkManager[630]: <info> [1679596218.7605] manager: NetworkManager state is now ASLEEP
Mar 23 13:30:18 schur systemd[1]: Reached target Sleep.
Mar 23 13:30:18 schur systemd[1]: Starting System Suspend...
Mar 23 13:30:18 schur wpa_supplicant[760]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Mar 23 13:30:18 schur wpa_supplicant[760]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Mar 23 13:30:18 schur systemd-sleep[786276]: Entering sleep state 'suspend'...
Mar 23 13:30:18 schur kernel: PM: suspend entry (s2idle)
Mar 23 13:30:18 schur kernel: Filesystems sync: 0.002 seconds
Mar 23 13:32:50 schur kernel: Freezing user space processes
Mar 23 13:32:50 schur kernel: Freezing user space processes completed (elapsed 0.003 seconds)
Mar 23 13:32:50 schur kernel: OOM killer disabled.
Mar 23 13:32:50 schur kernel: Freezing remaining freezable tasks
Mar 23 13:32:50 schur kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
Mar 23 13:32:50 schur kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Mar 23 13:32:50 schur kernel: ACPI: EC: interrupt blocked
Mar 23 13:32:50 schur kernel: ACPI: EC: interrupt unblocked
Mar 23 13:32:50 schur kernel: nvme nvme0: 8/0/0 default/read/poll queues
Mar 23 13:32:50 schur kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
Mar 23 13:32:50 schur kernel: OOM killer enabled.
Mar 23 13:32:50 schur kernel: Restarting tasks ...
Mar 23 13:32:50 schur kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915])
Mar 23 13:32:50 schur kernel: done.
Mar 23 13:32:50 schur kernel: random: crng reseeded on system resumption
Mar 23 13:32:50 schur kernel: thermal thermal_zone5: failed to read out thermal zone (-61)
Mar 23 13:32:50 schur bluetoothd[711]: Controller resume with wake event 0x0
Mar 23 13:32:50 schur systemd-sleep[786276]: System returned from sleep state.
Mar 23 13:32:50 schur kernel: PM: suspend exit
Mar 23 13:32:50 schur systemd[1]: systemd-suspend.service: Deactivated successfully.
Mar 23 13:32:50 schur systemd[1]: Finished System Suspend.
Mar 23 13:32:50 schur systemd[1]: Stopped target Sleep.
Mar 23 13:32:50 schur systemd[1]: Reached target Suspend.
Mar 23 13:32:50 schur systemd[1]: Stopped target Suspend.
Mar 23 13:32:50 schur systemd-logind[623]: Operation 'sleep' finished.
Mar 23 13:32:50 schur NetworkManager[630]: <info> [1679596370.4668] manager: sleep: wake requested (sleeping: yes enabled: yes)
Mar 23 13:32:50 schur NetworkManager[630]: <info> [1679596370.4670] device (wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 23 13:32:50 schur NetworkManager[630]: <info> [1679596370.7609] device (wlan0): set-hw-addr: set MAC address to 86:86:FD:66:DC:15 (scanning)
Mar 23 13:32:51 schur NetworkManager[630]: <info> [1679596371.0254] device (p2p-dev-wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 23 13:32:51 schur NetworkManager[630]: <info> [1679596371.0258] manager: NetworkManager state is now CONNECTED_LOCAL
Mar 23 13:32:51 schur NetworkManager[630]: <info> [1679596371.0704] device (wlan0): supplicant interface state: internal-starting -> disconnected
Mar 23 13:32:51 schur NetworkManager[630]: <info> [1679596371.0705] device (p2p-dev-wlan0): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Mar 23 13:32:51 schur NetworkManager[630]: <info> [1679596371.0713] Wi-Fi P2P device controlled by interface wlan0 created
Mar 23 13:32:51 schur NetworkManager[630]: <info> [1679596371.0717] manager: (p2p-dev-wlan0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/39)
Mar 23 13:32:51 schur NetworkManager[630]: <info> [1679596371.0721] device (p2p-dev-wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 23 13:32:51 schur NetworkManager[630]: <info> [1679596371.0727] device (wlan0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Mar 23 13:32:51 schur NetworkManager[630]: <info> [1679596371.0735] device (p2p-dev-wlan0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 23 13:32:53 schur syncthing[1323]: [LT2WM] INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
Mar 23 13:32:53 schur syncthing[1323]: [LT2WM] INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) shutting down
Mar 23 13:32:53 schur syncthing[1323]: [LT2WM] INFO: listenerSupervisor@dynamic+https://relays.syncthing.net/endpoint: service dynamic+https://relays.syncthing.net/endpoint failed: Get "https://relays.syncthing.net/endpoint": dial tcp: lookup relays.syncthing.net on [::1]:53: read udp [::1]:35807->[::1]:53: read: connection refused
Mar 23 13:32:53 schur syncthing[1323]: [LT2WM] INFO: listenerSupervisor@dynamic+https://relays.syncthing.net/endpoint: service dynamic+https://relays.syncthing.net/endpoint failed: Get "https://relays.syncthing.net/endpoint": dial tcp: lookup relays.syncthing.net on [::1]:53: read udp [::1]:36319->[::1]:53: read: connection refused
Mar 23 13:32:53 schur syncthing[1323]: [LT2WM] INFO: listenerSupervisor@dynamic+https://relays.syncthing.net/endpoint: service dynamic+https://relays.syncthing.net/endpoint failed: Get "https://relays.syncthing.net/endpoint": dial tcp: lookup relays.syncthing.net on [::1]:53: read udp [::1]:50715->[::1]:53: read: connection refused
Mar 23 13:32:54 schur wpa_supplicant[760]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=US
Mar 23 13:33:01 schur rtkit-daemon[1476]: Supervising 0 threads of 0 processes of 0 users.
Mar 23 13:33:11 schur rtkit-daemon[1476]: Supervising 0 threads of 0 processes of 0 users.
Mar 23 13:33:12 schur systemd[1313]: Finished EOS update notifier service.
Mar 23 13:33:12 schur systemd[1313]: eos-update-notifier.service: Consumed 40.291s CPU time.
Mar 23 13:33:17 schur systemd-logind[623]: Suspending...
Mar 23 13:33:17 schur NetworkManager[630]: <info> [1679596397.8451] manager: sleep: sleep requested (sleeping: no enabled: yes)
Mar 23 13:33:17 schur NetworkManager[630]: <info> [1679596397.8453] device (wlan0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 23 13:33:17 schur NetworkManager[630]: <info> [1679596397.9000] device (wlan0): set-hw-addr: reset MAC address to E4:A4:71:56:AB:D0 (unmanage)
Mar 23 13:33:17 schur NetworkManager[630]: <info> [1679596397.9169] device (p2p-dev-wlan0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 23 13:33:17 schur NetworkManager[630]: <info> [1679596397.9176] manager: NetworkManager state is now ASLEEP
Mar 23 13:33:17 schur systemd[1]: Reached target Sleep.
Mar 23 13:33:17 schur wpa_supplicant[760]: p2p-dev-wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Mar 23 13:33:17 schur systemd[1]: Starting System Suspend...
Mar 23 13:33:17 schur wpa_supplicant[760]: nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
Mar 23 13:33:17 schur wpa_supplicant[760]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Mar 23 13:33:18 schur wpa_supplicant[760]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Mar 23 13:33:18 schur wpa_supplicant[760]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Mar 23 13:33:18 schur systemd-sleep[787087]: Entering sleep state 'suspend'...
Mar 23 13:33:18 schur kernel: PM: suspend entry (s2idle)
Mar 23 13:33:18 schur kernel: Filesystems sync: 0.003 seconds
Mar 23 13:33:28 schur kernel: Freezing user space processes
Mar 23 13:33:28 schur kernel: Freezing user space processes completed (elapsed 0.003 seconds)
Mar 23 13:33:28 schur kernel: OOM killer disabled.
Mar 23 13:33:28 schur kernel: Freezing remaining freezable tasks
Mar 23 13:33:28 schur kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
Mar 23 13:33:28 schur kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Mar 23 13:33:28 schur kernel: ACPI: EC: interrupt blocked
Mar 23 13:33:28 schur kernel: ACPI: EC: interrupt unblocked
Mar 23 13:33:28 schur kernel: nvme nvme0: 8/0/0 default/read/poll queues
Mar 23 13:33:28 schur kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
Mar 23 13:33:28 schur kernel: OOM killer enabled.
Mar 23 13:33:28 schur kernel: Restarting tasks ...
Mar 23 13:33:28 schur kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915])
Mar 23 13:33:28 schur kernel: done.
Mar 23 13:33:28 schur kernel: random: crng reseeded on system resumption
Mar 23 13:33:28 schur bluetoothd[711]: Controller resume with wake event 0x0
Mar 23 13:33:28 schur systemd-sleep[787087]: System returned from sleep state.
Mar 23 13:33:28 schur kernel: PM: suspend exit
Mar 23 13:33:28 schur systemd[1]: systemd-suspend.service: Deactivated successfully.
Mar 23 13:33:28 schur systemd[1]: Finished System Suspend.
Mar 23 13:33:28 schur systemd[1]: Stopped target Sleep.
Mar 23 13:33:28 schur systemd[1]: Reached target Suspend.
Mar 23 13:33:28 schur systemd[1]: Stopped target Suspend.
Mar 23 13:33:28 schur systemd-logind[623]: Operation 'sleep' finished.
Mar 23 13:33:28 schur NetworkManager[630]: <info> [1679596408.4493] manager: sleep: wake requested (sleeping: yes enabled: yes)
Mar 23 13:33:28 schur NetworkManager[630]: <info> [1679596408.4496] device (wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 23 13:33:28 schur NetworkManager[630]: <info> [1679596408.4511] device (p2p-dev-wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 23 13:33:28 schur NetworkManager[630]: <info> [1679596408.4515] manager: NetworkManager state is now CONNECTED_LOCAL
Mar 23 13:33:28 schur NetworkManager[630]: <info> [1679596408.5114] device (wlan0): supplicant interface state: internal-starting -> disconnected
Mar 23 13:33:28 schur NetworkManager[630]: <info> [1679596408.5115] device (p2p-dev-wlan0): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Mar 23 13:33:28 schur NetworkManager[630]: <info> [1679596408.5122] Wi-Fi P2P device controlled by interface wlan0 created
Mar 23 13:33:28 schur NetworkManager[630]: <info> [1679596408.5126] manager: (p2p-dev-wlan0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/40)
Mar 23 13:33:28 schur NetworkManager[630]: <info> [1679596408.5130] device (p2p-dev-wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 23 13:33:28 schur NetworkManager[630]: <info> [1679596408.5137] device (wlan0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Mar 23 13:33:28 schur NetworkManager[630]: <info> [1679596408.5145] device (p2p-dev-wlan0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 23 13:33:31 schur wpa_supplicant[760]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=US
Mar 23 13:33:40 schur rtkit-daemon[1476]: Supervising 0 threads of 0 processes of 0 users.
Mar 23 13:33:55 schur systemd-logind[623]: Suspending...
Mar 23 13:33:55 schur NetworkManager[630]: <info> [1679596435.9404] manager: sleep: sleep requested (sleeping: no enabled: yes)
Mar 23 13:33:55 schur NetworkManager[630]: <info> [1679596435.9405] device (wlan0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 23 13:33:55 schur wpa_supplicant[760]: p2p-dev-wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Mar 23 13:33:55 schur wpa_supplicant[760]: nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
Mar 23 13:33:55 schur NetworkManager[630]: <info> [1679596435.9895] device (p2p-dev-wlan0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 23 13:33:55 schur NetworkManager[630]: <info> [1679596435.9899] manager: NetworkManager state is now ASLEEP
Mar 23 13:33:55 schur systemd[1]: Reached target Sleep.
Mar 23 13:33:56 schur systemd[1]: Starting System Suspend...
Mar 23 13:33:56 schur wpa_supplicant[760]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Mar 23 13:33:56 schur wpa_supplicant[760]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Mar 23 13:33:56 schur systemd-sleep[787861]: Entering sleep state 'suspend'...
Mar 23 13:33:56 schur kernel: PM: suspend entry (s2idle)
Mar 23 13:33:56 schur kernel: Filesystems sync: 0.002 seconds
Mar 23 13:35:37 schur kernel: Freezing user space processes
Mar 23 13:35:37 schur kernel: Freezing user space processes completed (elapsed 0.003 seconds)
Mar 23 13:35:37 schur kernel: OOM killer disabled.
Mar 23 13:35:37 schur kernel: Freezing remaining freezable tasks
Mar 23 13:35:37 schur kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
Mar 23 13:35:37 schur kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Mar 23 13:35:37 schur kernel: ACPI: EC: interrupt blocked
Mar 23 13:35:37 schur kernel: ACPI: EC: interrupt unblocked
Mar 23 13:35:37 schur kernel: nvme nvme0: 8/0/0 default/read/poll queues
Mar 23 13:35:37 schur kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
Mar 23 13:35:37 schur kernel: OOM killer enabled.
Mar 23 13:35:37 schur kernel: Restarting tasks ...
Mar 23 13:35:37 schur kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915])
Mar 23 13:35:37 schur kernel: done.
Mar 23 13:35:37 schur kernel: random: crng reseeded on system resumption
Mar 23 13:35:37 schur kernel: thermal thermal_zone5: failed to read out thermal zone (-61)
Mar 23 13:35:37 schur bluetoothd[711]: Controller resume with wake event 0x0
Mar 23 13:35:37 schur systemd-sleep[787861]: System returned from sleep state.
Mar 23 13:35:37 schur kernel: PM: suspend exit
Mar 23 13:35:37 schur tlp[787933]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Mar 23 13:35:37 schur tlp[787933]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Mar 23 13:35:37 schur tlp[787933]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Mar 23 13:35:37 schur tlp[787933]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Mar 23 13:35:37 schur systemd[1]: systemd-suspend.service: Deactivated successfully.
Mar 23 13:35:37 schur systemd[1]: Finished System Suspend.
Mar 23 13:35:37 schur systemd[1]: Stopped target Sleep.
Mar 23 13:35:37 schur systemd[1]: Reached target Suspend.
Mar 23 13:35:37 schur systemd[1]: Stopped target Suspend.
Mar 23 13:35:37 schur systemd-logind[623]: Operation 'sleep' finished.
Mar 23 13:35:37 schur NetworkManager[630]: <info> [1679596537.4525] manager: sleep: wake requested (sleeping: yes enabled: yes)
Mar 23 13:35:37 schur NetworkManager[630]: <info> [1679596537.4528] device (wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 23 13:35:37 schur NetworkManager[630]: <info> [1679596537.7166] device (p2p-dev-wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 23 13:35:37 schur NetworkManager[630]: <info> [1679596537.7172] manager: NetworkManager state is now CONNECTED_LOCAL
Mar 23 13:35:37 schur NetworkManager[630]: <info> [1679596537.7710] device (wlan0): supplicant interface state: internal-starting -> disconnected
Mar 23 13:35:37 schur NetworkManager[630]: <info> [1679596537.7711] device (p2p-dev-wlan0): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Mar 23 13:35:37 schur NetworkManager[630]: <info> [1679596537.7718] Wi-Fi P2P device controlled by interface wlan0 created
Mar 23 13:35:37 schur NetworkManager[630]: <info> [1679596537.7723] manager: (p2p-dev-wlan0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/41)
Mar 23 13:35:37 schur NetworkManager[630]: <info> [1679596537.7727] device (p2p-dev-wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 23 13:35:37 schur NetworkManager[630]: <info> [1679596537.7733] device (wlan0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Mar 23 13:35:37 schur NetworkManager[630]: <info> [1679596537.7740] device (p2p-dev-wlan0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 23 13:35:40 schur wpa_supplicant[760]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=US
Mar 23 13:35:49 schur rtkit-daemon[1476]: Supervising 0 threads of 0 processes of 0 users.
Mar 23 13:35:57 schur rtkit-daemon[1476]: Supervising 0 threads of 0 processes of 0 users.
Mar 23 13:35:58 schur syncthing[1323]: [LT2WM] INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
Mar 23 13:35:58 schur syncthing[1323]: [LT2WM] INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) shutting down
Mar 23 13:35:58 schur syncthing[1323]: [LT2WM] INFO: listenerSupervisor@dynamic+https://relays.syncthing.net/endpoint: service dynamic+https://relays.syncthing.net/endpoint failed: Get "https://relays.syncthing.net/endpoint": dial tcp: lookup relays.syncthing.net on [::1]:53: read udp [::1]:42866->[::1]:53: read: connection refused
Mar 23 13:35:58 schur syncthing[1323]: [LT2WM] INFO: listenerSupervisor@dynamic+https://relays.syncthing.net/endpoint: service dynamic+https://relays.syncthing.net/endpoint failed: Get "https://relays.syncthing.net/endpoint": dial tcp: lookup relays.syncthing.net on [::1]:53: read udp [::1]:46505->[::1]:53: read: connection refused
Mar 23 13:35:58 schur syncthing[1323]: [LT2WM] INFO: listenerSupervisor@dynamic+https://relays.syncthing.net/endpoint: service dynamic+https://relays.syncthing.net/endpoint failed: Get "https://relays.syncthing.net/endpoint": dial tcp: lookup relays.syncthing.net on [::1]:53: read udp [::1]:51404->[::1]:53: read: connection refused
Mar 23 13:36:03 schur systemd-logind[623]: Suspending...
Mar 23 13:36:03 schur NetworkManager[630]: <info> [1679596563.8967] manager: sleep: sleep requested (sleeping: no enabled: yes)
Mar 23 13:36:03 schur NetworkManager[630]: <info> [1679596563.8968] device (wlan0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 23 13:36:03 schur wpa_supplicant[760]: p2p-dev-wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Mar 23 13:36:03 schur wpa_supplicant[760]: nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
Mar 23 13:36:03 schur NetworkManager[630]: <info> [1679596563.9577] device (p2p-dev-wlan0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 23 13:36:03 schur NetworkManager[630]: <info> [1679596563.9581] manager: NetworkManager state is now ASLEEP
Mar 23 13:36:03 schur systemd[1]: Reached target Sleep.
Mar 23 13:36:03 schur systemd[1]: Starting System Suspend...
Mar 23 13:36:04 schur wpa_supplicant[760]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Mar 23 13:36:04 schur wpa_supplicant[760]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Mar 23 13:36:04 schur systemd-sleep[788651]: Entering sleep state 'suspend'...
< -- reboot happens below -->
Mar 23 15:25:16 schur kernel: microcode: microcode updated early to revision 0xa6, date = 2022-06-28
Mar 23 15:25:16 schur kernel: Linux version 6.2.7-arch1-1 (linux@archlinux) (gcc (GCC) 12.2.1 20230201, GNU ld (GNU Binutils) 2.40) #1 SMP PREEMPT_DYNAMIC Sat, 18 Mar 2023 01:06:36 +0000
Mar 23 15:25:16 schur kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=2a9459e2-9fde-4f0a-858d-7ed6f395a894 rw resume=UUID=15d901db-b4ce-46e9-a731-7c3e8a90dba0 resume_offset=31760384 quiet loglevel=3 nowatchdog nvme_load=YES
Mar 23 15:25:16 schur kernel: x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
Mar 23 15:25:16 schur kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Mar 23 15:25:16 schur kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Mar 23 15:25:16 schur kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Mar 23 15:25:16 schur kernel: x86/fpu: Supporting XSAVE feature 0x020: 'AVX-512 opmask'
Mar 23 15:25:16 schur kernel: x86/fpu: Supporting XSAVE feature 0x040: 'AVX-512 Hi256'
Mar 23 15:25:16 schur kernel: x86/fpu: Supporting XSAVE feature 0x080: 'AVX-512 ZMM_Hi256'
Mar 23 15:25:16 schur kernel: x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
Mar 23 15:25:16 schur kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
Mar 23 15:25:16 schur kernel: x86/fpu: xstate_offset[5]: 832, xstate_sizes[5]: 64
Mar 23 15:25:16 schur kernel: x86/fpu: xstate_offset[6]: 896, xstate_sizes[6]: 512
Mar 23 15:25:16 schur kernel: x86/fpu: xstate_offset[7]: 1408, xstate_sizes[7]: 1024
Mar 23 15:25:16 schur kernel: x86/fpu: xstate_offset[9]: 2432, xstate_sizes[9]: 8
Mar 23 15:25:16 schur kernel: x86/fpu: Enabled xstate features 0x2e7, context size is 2440 bytes, using 'compacted' format.
Mar 23 15:25:16 schur kernel: signal: max sigframe size: 3632
Mar 23 15:25:16 schur kernel: BIOS-provided physical RAM map:
Mar 23 15:25:16 schur kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
Mar 23 15:25:16 schur kernel: BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
Mar 23 15:25:16 schur kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000039f98fff] usable
Mar 23 15:25:16 schur kernel: BIOS-e820: [mem 0x0000000039f99000-0x000000003a898fff] reserved
Mar 23 15:25:16 schur kernel: BIOS-e820: [mem 0x000000003a899000-0x00000000434aefff] usable
Mar 23 15:25:16 schur kernel: BIOS-e820: [mem 0x00000000434af000-0x000000004387efff] type 20
Mar 23 15:25:16 schur kernel: BIOS-e820: [mem 0x000000004387f000-0x00000000452fefff] reserved
Mar 23 15:25:16 schur kernel: BIOS-e820: [mem 0x00000000452ff000-0x0000000045b2efff] ACPI NVS
Mar 23 15:25:16 schur kernel: BIOS-e820: [mem 0x0000000045b2f000-0x0000000045bfefff] ACPI data
Mar 23 15:25:16 schur kernel: BIOS-e820: [mem 0x0000000045bff000-0x0000000045bfffff] usable
Mar 23 15:25:16 schur kernel: BIOS-e820: [mem 0x0000000045c00000-0x0000000049ffffff] reserved
Mar 23 15:25:16 schur kernel: BIOS-e820: [mem 0x000000004a200000-0x000000004a3fffff] reserved
Mar 23 15:25:16 schur kernel: BIOS-e820: [mem 0x000000004b000000-0x00000000503fffff] reserved
Mar 23 15:25:16 schur kernel: BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
Mar 23 15:25:16 schur kernel: BIOS-e820: [mem 0x00000000fe010000-0x00000000fe010fff] reserved
Mar 23 15:25:16 schur kernel: BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
Mar 23 15:25:16 schur kernel: BIOS-e820: [mem 0x00000000ff400000-0x00000000ffffffff] reserved
Mar 23 15:25:16 schur kernel: BIOS-e820: [mem 0x0000000100000000-0x00000005afbfffff] usable
Mar 23 15:25:16 schur kernel: NX (Execute Disable) protection: active
Mar 23 15:25:16 schur kernel: efi: EFI v2.70 by INSYDE Corp.
Mar 23 15:25:16 schur kernel: efi: ACPI=0x45bfe000 ACPI 2.0=0x45bfe014 TPMFinalLog=0x45ac5000 SMBIOS=0x439e3000 SMBIOS 3.0=0x439e1000 MEMATTR=0x3f932018 ESRT=0x3fba8698
Mar 23 15:25:16 schur kernel: efi: Remove mem75: MMIO range=[0xc0000000-0xcfffffff] (256MB) from e820 map
Mar 23 15:25:16 schur kernel: e820: remove [mem 0xc0000000-0xcfffffff] reserved
Mar 23 15:25:16 schur kernel: efi: Not removing mem76: MMIO range=[0xfe010000-0xfe010fff] (4KB) from e820 map
Mar 23 15:25:16 schur kernel: efi: Remove mem78: MMIO range=[0xff400000-0xffffffff] (12MB) from e820 map
Mar 23 15:25:16 schur kernel: e820: remove [mem 0xff400000-0xffffffff] reserved
Mar 23 15:25:16 schur kernel: SMBIOS 3.3.0 present.
Mar 23 15:25:16 schur kernel: DMI: Framework Laptop/FRANBMCP0A, BIOS 03.07 12/14/2021
Mar 23 15:25:16 schur kernel: tsc: Detected 2400.000 MHz processor
Mar 23 15:25:16 schur kernel: tsc: Detected 2419.200 MHz TSC
Mar 23 15:25:16 schur kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Mar 23 15:25:16 schur kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Mar 23 15:25:16 schur kernel: last_pfn = 0x5afc00 max_arch_pfn = 0x400000000
Mar 23 15:25:16 schur kernel: x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
Mar 23 15:25:16 schur kernel: last_pfn = 0x45c00 max_arch_pfn = 0x400000000
Mar 23 15:25:16 schur kernel: esrt: Reserving ESRT space from 0x000000003fba8698 to 0x000000003fba8720.
Mar 23 15:25:16 schur kernel: e820: update [mem 0x3fba8000-0x3fba8fff] usable ==> reserved
Mar 23 15:25:16 schur kernel: Using GB pages for direct mapping
Mar 23 15:25:16 schur kernel: Secure boot disabled
Mar 23 15:25:16 schur kernel: RAMDISK: [mem 0x36061000-0x37027fff]
Mar 23 15:25:16 schur kernel: ACPI: Early table checksum verification disabled
Mar 23 15:25:16 schur kernel: ACPI: RSDP 0x0000000045BFE014 000024 (v02 INSYDE)
Mar 23 15:25:16 schur kernel: ACPI: XSDT 0x0000000045BD1188 000104 (v01 INSYDE TGL-ULT 00000002 01000013)
Mar 23 15:25:16 schur kernel: ACPI: FACP 0x0000000045BD3000 00010C (v06 INSYDE TGL-ULT 00000002 ACPI 00040000)
Mar 23 15:25:16 schur kernel: ACPI: DSDT 0x0000000045B79000 056BD7 (v02 INSYDE TGL-ULT 00000002 ACPI 00040000)
Mar 23 15:25:16 schur kernel: ACPI: FACS 0x0000000045AA1000 000040
Mar 23 15:25:16 schur kernel: ACPI: UEFI 0x0000000045B2E000 000236 (v01 INSYDE TGL-ULT 00000001 ACPI 00040000)
Mar 23 15:25:16 schur kernel: ACPI: SSDT 0x0000000045BFA000 00255C (v02 CpuRef CpuSsdt 00003000 INTL 20160422)
Mar 23 15:25:16 schur kernel: ACPI: SSDT 0x0000000045BF6000 0033A6 (v02 DptfTb DptfTabl 00001000 INTL 20160422)
Mar 23 15:25:16 schur kernel: ACPI: SSDT 0x0000000045BF2000 003034 (v02 SaSsdt SaSsdt 00003000 INTL 20160422)
Mar 23 15:25:16 schur kernel: ACPI: SSDT 0x0000000045BEE000 003300 (v02 INTEL IgfxSsdt 00003000 INTL 20160422)
Mar 23 15:25:16 schur kernel: ACPI: SSDT 0x0000000045BE2000 00B30D (v02 INTEL TcssSsdt 00001000 INTL 20160422)
Mar 23 15:25:16 schur kernel: ACPI: SSDT 0x0000000045BE1000 00077B (v02 INSYDE Tpm2Tabl 00001000 INTL 20160422)
Mar 23 15:25:16 schur kernel: ACPI: TPM2 0x0000000045BE0000 00004C (v04 INSYDE TGL-ULT 00000002 ACPI 00040000)
Mar 23 15:25:16 schur kernel: ACPI: SSDT 0x0000000045BDE000 0008C1 (v02 INTEL xh_tudd4 00000000 INTL 20160422)
Mar 23 15:25:16 schur kernel: ACPI: NHLT 0x0000000045BDD000 00002D (v00 INSYDE TGL-ULT 00000002 ACPI 00040000)
Mar 23 15:25:16 schur kernel: ACPI: SSDT 0x0000000045BDB000 0011C3 (v02 INSYDE UsbCTabl 00001000 INTL 20160422)
Mar 23 15:25:16 schur kernel: ACPI: LPIT 0x0000000045BDA000 0000CC (v01 INSYDE TGL-ULT 00000002 ACPI 00040000)
Mar 23 15:25:16 schur kernel: ACPI: WSMT 0x0000000045BD9000 000028 (v01 INSYDE TGL-ULT 00000002 ACPI 00040000)
Mar 23 15:25:16 schur kernel: ACPI: SSDT 0x0000000045BD8000 000B2E (v02 INSYDE PtidDevc 00001000 INTL 20160422)
Mar 23 15:25:16 schur kernel: ACPI: SSDT 0x0000000045BD7000 00012A (v02 INSYDE TbtTypeC 00000000 INTL 20160422)
Mar 23 15:25:16 schur kernel: ACPI: DBGP 0x0000000045BD6000 000034 (v01 INSYDE TGL-ULT 00000002 ACPI 00040000)
Mar 23 15:25:16 schur kernel: ACPI: DBG2 0x0000000045BD5000 000054 (v00 INSYDE TGL-ULT 00000002 ACPI 00040000)
Mar 23 15:25:16 schur kernel: ACPI: ECDT 0x0000000045BD4000 000069 (v01 INSYDE TGL-ULT 00000002 ACPI 00040000)
Mar 23 15:25:16 schur kernel: ACPI: HPET 0x0000000045BD2000 000038 (v01 INSYDE TGL-ULT 00000002 ACPI 00040000)
Mar 23 15:25:16 schur kernel: ACPI: APIC 0x0000000045BFD000 00012C (v03 INSYDE TGL-ULT 00000002 ACPI 00040000)
Mar 23 15:25:16 schur kernel: ACPI: MCFG 0x0000000045BD0000 00003C (v01 INSYDE TGL-ULT 00000002 ACPI 00040000)
Mar 23 15:25:16 schur kernel: ACPI: SSDT 0x0000000045B72000 00661F (v02 INSYDE TGL-ULT 00000002 01000013)
Mar 23 15:25:16 schur kernel: ACPI: DMAR 0x0000000045B71000 0000E8 (v02 INSYDE TGL-ULT 00000002 ACPI 00040000)
Mar 23 15:25:16 schur kernel: ACPI: SSDT 0x0000000045B70000 0000F8 (v01 INSYDE PcdTabl 00001000 INTL 20160422)
Mar 23 15:25:16 schur kernel: ACPI: FPDT 0x0000000045B6F000 000044 (v01 INSYDE TGL-ULT 00000002 ACPI 00040000)
Mar 23 15:25:16 schur kernel: ACPI: PTDT 0x0000000045B6D000 000CFE (v00 INSYDE TGL-ULT 00000005 ACPI 00040000)
Mar 23 15:25:16 schur kernel: ACPI: BGRT 0x0000000045B6E000 000038 (v01 INSYDE TGL-ULT 00000001 ACPI 00040000)
Mar 23 15:25:16 schur kernel: ACPI: Reserving FACP table memory at [mem 0x45bd3000-0x45bd310b]
Mar 23 15:25:16 schur kernel: ACPI: Reserving DSDT table memory at [mem 0x45b79000-0x45bcfbd6]
Mar 23 15:25:16 schur kernel: ACPI: Reserving FACS table memory at [mem 0x45aa1000-0x45aa103f]
Mar 23 15:25:16 schur kernel: ACPI: Reserving UEFI table memory at [mem 0x45b2e000-0x45b2e235]
Mar 23 15:25:16 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45bfa000-0x45bfc55b]
Mar 23 15:25:16 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45bf6000-0x45bf93a5]
Mar 23 15:25:16 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45bf2000-0x45bf5033]
Mar 23 15:25:16 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45bee000-0x45bf12ff]
Mar 23 15:25:16 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45be2000-0x45bed30c]
Mar 23 15:25:16 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45be1000-0x45be177a]
Mar 23 15:25:16 schur kernel: ACPI: Reserving TPM2 table memory at [mem 0x45be0000-0x45be004b]
Mar 23 15:25:16 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45bde000-0x45bde8c0]
Mar 23 15:25:16 schur kernel: ACPI: Reserving NHLT table memory at [mem 0x45bdd000-0x45bdd02c]
Mar 23 15:25:16 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45bdb000-0x45bdc1c2]
Mar 23 15:25:16 schur kernel: ACPI: Reserving LPIT table memory at [mem 0x45bda000-0x45bda0cb]
Mar 23 15:25:16 schur kernel: ACPI: Reserving WSMT table memory at [mem 0x45bd9000-0x45bd9027]
Mar 23 15:25:16 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45bd8000-0x45bd8b2d]
Mar 23 15:25:16 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45bd7000-0x45bd7129]
Mar 23 15:25:16 schur kernel: ACPI: Reserving DBGP table memory at [mem 0x45bd6000-0x45bd6033]
Mar 23 15:25:16 schur kernel: ACPI: Reserving DBG2 table memory at [mem 0x45bd5000-0x45bd5053]
Mar 23 15:25:16 schur kernel: ACPI: Reserving ECDT table memory at [mem 0x45bd4000-0x45bd4068]
Mar 23 15:25:16 schur kernel: ACPI: Reserving HPET table memory at [mem 0x45bd2000-0x45bd2037]
Mar 23 15:25:16 schur kernel: ACPI: Reserving APIC table memory at [mem 0x45bfd000-0x45bfd12b]
Mar 23 15:25:16 schur kernel: ACPI: Reserving MCFG table memory at [mem 0x45bd0000-0x45bd003b]
Mar 23 15:25:16 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45b72000-0x45b7861e]
Mar 23 15:25:16 schur kernel: ACPI: Reserving DMAR table memory at [mem 0x45b71000-0x45b710e7]
Mar 23 15:25:16 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45b70000-0x45b700f7]
Mar 23 15:25:16 schur kernel: ACPI: Reserving FPDT table memory at [mem 0x45b6f000-0x45b6f043]
Mar 23 15:25:16 schur kernel: ACPI: Reserving PTDT table memory at [mem 0x45b6d000-0x45b6dcfd]
Mar 23 15:25:16 schur kernel: ACPI: Reserving BGRT table memory at [mem 0x45b6e000-0x45b6e037]
Mar 23 15:25:16 schur kernel: No NUMA configuration found
Mar 23 15:25:16 schur kernel: Faking a node at [mem 0x0000000000000000-0x00000005afbfffff]
Mar 23 15:25:16 schur kernel: NODE_DATA(0) allocated [mem 0x5afbfb000-0x5afbfffff]
Mar 23 15:25:16 schur kernel: Zone ranges:
Mar 23 15:25:16 schur kernel: DMA [mem 0x0000000000001000-0x0000000000ffffff]
Mar 23 15:25:16 schur kernel: DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
Mar 23 15:25:16 schur kernel: Normal [mem 0x0000000100000000-0x00000005afbfffff]
Mar 23 15:25:16 schur kernel: Device empty
Mar 23 15:25:16 schur kernel: Movable zone start for each node
Mar 23 15:25:16 schur kernel: Early memory node ranges
Mar 23 15:25:16 schur kernel: node 0: [mem 0x0000000000001000-0x000000000009efff]
Mar 23 15:25:16 schur kernel: node 0: [mem 0x0000000000100000-0x0000000039f98fff]
Mar 23 15:25:16 schur kernel: node 0: [mem 0x000000003a899000-0x00000000434aefff]
Mar 23 15:25:16 schur kernel: node 0: [mem 0x0000000045bff000-0x0000000045bfffff]
Mar 23 15:25:16 schur kernel: node 0: [mem 0x0000000100000000-0x00000005afbfffff]
Mar 23 15:25:16 schur kernel: Initmem setup node 0 [mem 0x0000000000001000-0x00000005afbfffff]
Mar 23 15:25:16 schur kernel: On node 0, zone DMA: 1 pages in unavailable ranges
Mar 23 15:25:16 schur kernel: On node 0, zone DMA: 97 pages in unavailable ranges
Mar 23 15:25:16 schur kernel: On node 0, zone DMA32: 2304 pages in unavailable ranges
Mar 23 15:25:16 schur kernel: On node 0, zone DMA32: 10064 pages in unavailable ranges
Mar 23 15:25:16 schur kernel: On node 0, zone Normal: 9216 pages in unavailable ranges
Mar 23 15:25:16 schur kernel: On node 0, zone Normal: 1024 pages in unavailable ranges
Mar 23 15:25:16 schur kernel: Reserving Intel graphics memory at [mem 0x4c800000-0x503fffff]
Mar 23 15:25:16 schur kernel: ACPI: PM-Timer IO Port: 0x1808
Mar 23 15:25:16 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Mar 23 15:25:16 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
Mar 23 15:25:16 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
Mar 23 15:25:16 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
Mar 23 15:25:16 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
Mar 23 15:25:16 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
Mar 23 15:25:16 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
Mar 23 15:25:16 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
Mar 23 15:25:16 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
Mar 23 15:25:16 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
Mar 23 15:25:16 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
Mar 23 15:25:16 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
Mar 23 15:25:16 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
Mar 23 15:25:16 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
Mar 23 15:25:16 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
Mar 23 15:25:16 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
Mar 23 15:25:16 schur kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
Mar 23 15:25:16 schur kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Mar 23 15:25:16 schur kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Mar 23 15:25:16 schur kernel: ACPI: Using ACPI (MADT) for SMP configuration information
Mar 23 15:25:16 schur kernel: ACPI: HPET id: 0x8086a201 base: 0xfed00000
Mar 23 15:25:16 schur kernel: e820: update [mem 0x3f933000-0x3f981fff] usable ==> reserved
Mar 23 15:25:16 schur kernel: TSC deadline timer available
Mar 23 15:25:16 schur kernel: smpboot: Allowing 8 CPUs, 0 hotplug CPUs
Mar 23 15:25:16 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Mar 23 15:25:16 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
Mar 23 15:25:16 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x39f99000-0x3a898fff]
Mar 23 15:25:16 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x3f933000-0x3f981fff]
Mar 23 15:25:16 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x3fba8000-0x3fba8fff]
Mar 23 15:25:16 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x434af000-0x4387efff]
Mar 23 15:25:16 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x4387f000-0x452fefff]
Mar 23 15:25:16 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x452ff000-0x45b2efff]
Mar 23 15:25:16 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x45b2f000-0x45bfefff]
Mar 23 15:25:16 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x45c00000-0x49ffffff]
Mar 23 15:25:16 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x4a000000-0x4a1fffff]
Mar 23 15:25:16 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x4a200000-0x4a3fffff]
Mar 23 15:25:16 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x4a400000-0x4affffff]
Mar 23 15:25:16 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x4b000000-0x503fffff]
Mar 23 15:25:16 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x50400000-0xfe00ffff]
Mar 23 15:25:16 schur kernel: PM: hibernation: Registered nosave memory: [mem 0xfe010000-0xfe010fff]
Mar 23 15:25:16 schur kernel: PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfed1ffff]
Mar 23 15:25:16 schur kernel: PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfed7ffff]
Mar 23 15:25:16 schur kernel: PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xffffffff]
Mar 23 15:25:16 schur kernel: [mem 0x50400000-0xfe00ffff] available for PCI devices
Mar 23 15:25:16 schur kernel: Booting paravirtualized kernel on bare hardware
Log 2
Apr 25 10:54:19 schur kernel: Freezing user space processes
Apr 25 10:54:19 schur kernel: Freezing user space processes completed (elapsed 0.001 seconds)
Apr 25 10:54:19 schur kernel: OOM killer disabled.
Apr 25 10:54:19 schur kernel: Freezing remaining freezable tasks
Apr 25 10:54:19 schur kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
Apr 25 10:54:19 schur kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Apr 25 10:54:19 schur kernel: ACPI: EC: interrupt blocked
Apr 25 10:54:19 schur kernel: ACPI: EC: interrupt unblocked
Apr 25 10:54:19 schur kernel: nvme nvme0: 8/0/0 default/read/poll queues
Apr 25 10:54:19 schur kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
Apr 25 10:54:19 schur kernel: OOM killer enabled.
Apr 25 10:54:19 schur kernel: Restarting tasks ...
Apr 25 10:54:19 schur kernel: usb 3-3: USB disconnect, device number 16
Apr 25 10:54:19 schur kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915])
Apr 25 10:54:19 schur rtkit-daemon[1332]: The canary thread is apparently starving. Taking action.
Apr 25 10:54:19 schur kernel: usb 3-4: USB disconnect, device number 9
Apr 25 10:54:19 schur kernel: done.
Apr 25 10:54:19 schur kernel: random: crng reseeded on system resumption
Apr 25 10:54:19 schur systemd-logind[506]: Lid closed.
Apr 25 10:54:19 schur syncthing[1150]: [LT2WM] INFO: Connection to IDG44HJ-YXXQGO7-52IAKYX-GJC5LYQ-IQW2WGD-SMQAWN3-ONG7SYY-2HTYEQF at 192.168.0.103:22000-192.168.0.101:22000/quic-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256 closed: reading length: INTERNAL_ERROR (local): write udp [::]:22000->192.168.0.101:22000: sendmsg: network is unreachable
Apr 25 10:54:19 schur rtkit-daemon[1332]: Demoting known real-time threads.
Apr 25 10:54:19 schur systemd[1140]: Starting EOS update notifier service...
Apr 25 10:54:19 schur rtkit-daemon[1332]: Successfully demoted thread 564101 of process 3568.
Apr 25 10:54:19 schur systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Apr 25 10:54:19 schur rtkit-daemon[1332]: Successfully demoted thread 220107 of process 219958.
Apr 25 10:54:19 schur (notifier)[2120444]: eos-update-notifier.service: Failed to locate executable /usr/bin/eos-update-notifier: No such file or directory
Apr 25 10:54:19 schur rtkit-daemon[1332]: Successfully demoted thread 2935 of process 2792.
Apr 25 10:54:19 schur (notifier)[2120444]: eos-update-notifier.service: Failed at step EXEC spawning /usr/bin/eos-update-notifier: No such file or directory
Apr 25 10:54:19 schur rtkit-daemon[1332]: Successfully demoted thread 1376 of process 1306.
Apr 25 10:54:19 schur systemd[1140]: eos-update-notifier.service: Main process exited, code=exited, status=203/EXEC
Apr 25 10:54:19 schur rtkit-daemon[1332]: Successfully demoted thread 1306 of process 1306.
Apr 25 10:54:19 schur systemd[1140]: eos-update-notifier.service: Failed with result 'exit-code'.
Apr 25 10:54:19 schur rtkit-daemon[1332]: Successfully demoted thread 1369 of process 1308.
Apr 25 10:54:19 schur systemd[1140]: Failed to start EOS update notifier service.
Apr 25 10:54:19 schur rtkit-daemon[1332]: Successfully demoted thread 1308 of process 1308.
Apr 25 10:54:19 schur rtkit-daemon[1332]: Successfully demoted thread 1373 of process 1311.
Apr 25 10:54:19 schur rtkit-daemon[1332]: Successfully demoted thread 1311 of process 1311.
Apr 25 10:54:19 schur rtkit-daemon[1332]: Demoted 9 threads.
Apr 25 10:54:19 schur systemd[1]: Rotate log files was skipped because of an unmet condition check (ConditionACPower=true).
Apr 25 10:54:19 schur systemd[1]: Daily man-db regeneration was skipped because of an unmet condition check (ConditionACPower=true).
Apr 25 10:54:19 schur systemd[1]: Started Verify integrity of password and group files.
Apr 25 10:54:19 schur systemd[1]: Starting Update locate database...
Apr 25 10:54:19 schur systemd-sleep[2120322]: System returned from sleep state.
Apr 25 10:54:19 schur bluetoothd[853]: Controller resume with wake event 0x0
Apr 25 10:54:19 schur kernel: PM: suspend exit
Apr 25 10:54:19 schur systemd[1]: shadow.service: Deactivated successfully.
Apr 25 10:54:19 schur tlp[2120507]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Apr 25 10:54:19 schur tlp[2120504]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Apr 25 10:54:19 schur tlp[2120507]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Apr 25 10:54:19 schur tlp[2120504]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Apr 25 10:54:19 schur tlp[2120507]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Apr 25 10:54:19 schur tlp[2120507]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Apr 25 10:54:19 schur tlp[2120504]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Apr 25 10:54:19 schur tlp[2120504]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Apr 25 10:54:19 schur tlp[2120600]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Apr 25 10:54:19 schur tlp[2120600]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Apr 25 10:54:19 schur tlp[2120600]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Apr 25 10:54:19 schur tlp[2120600]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Apr 25 10:54:20 schur tlp[2120628]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Apr 25 10:54:20 schur tlp[2120628]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Apr 25 10:54:20 schur tlp[2120628]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Apr 25 10:54:20 schur tlp[2120628]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Apr 25 10:54:20 schur tlp[2120709]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Apr 25 10:54:20 schur tlp[2120709]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Apr 25 10:54:20 schur tlp[2120709]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Apr 25 10:54:20 schur tlp[2120709]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Apr 25 10:54:20 schur systemd[1]: systemd-suspend.service: Deactivated successfully.
Apr 25 10:54:20 schur systemd[1]: Finished System Suspend.
Apr 25 10:54:20 schur systemd[1]: Stopped target Sleep.
Apr 25 10:54:20 schur systemd[1]: Reached target Suspend.
Apr 25 10:54:20 schur systemd[1]: Stopped target Suspend.
Apr 25 10:54:20 schur systemd-logind[506]: Operation 'sleep' finished.
Apr 25 10:54:20 schur NetworkManager[512]: <info> [1682438060.2423] manager: sleep: wake requested (sleeping: yes enabled: yes)
Apr 25 10:54:20 schur NetworkManager[512]: <info> [1682438060.2424] device (wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Apr 25 10:54:20 schur NetworkManager[512]: <info> [1682438060.2890] device (wlan0): set-hw-addr: set MAC address to A2:04:A5:E2:93:4A (scanning)
Apr 25 10:54:20 schur tlp[2120794]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Apr 25 10:54:20 schur tlp[2120794]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Apr 25 10:54:20 schur tlp[2120794]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Apr 25 10:54:20 schur tlp[2120794]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Apr 25 10:54:20 schur systemd[1]: updatedb.service: Deactivated successfully.
Apr 25 10:54:20 schur systemd[1]: Finished Update locate database.
Apr 25 10:54:20 schur tlp[2120829]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Apr 25 10:54:20 schur tlp[2120829]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Apr 25 10:54:20 schur tlp[2120829]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Apr 25 10:54:20 schur tlp[2120829]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Apr 25 10:54:20 schur NetworkManager[512]: <info> [1682438060.5532] device (p2p-dev-wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Apr 25 10:54:20 schur NetworkManager[512]: <info> [1682438060.5540] manager: NetworkManager state is now CONNECTED_LOCAL
Apr 25 10:54:20 schur NetworkManager[512]: <info> [1682438060.5994] device (wlan0): supplicant interface state: internal-starting -> disconnected
Apr 25 10:54:20 schur NetworkManager[512]: <info> [1682438060.5995] device (p2p-dev-wlan0): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Apr 25 10:54:20 schur NetworkManager[512]: <info> [1682438060.6002] Wi-Fi P2P device controlled by interface wlan0 created
Apr 25 10:54:20 schur NetworkManager[512]: <info> [1682438060.6007] manager: (p2p-dev-wlan0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/8)
Apr 25 10:54:20 schur NetworkManager[512]: <info> [1682438060.6011] device (p2p-dev-wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Apr 25 10:54:20 schur NetworkManager[512]: <info> [1682438060.6018] device (wlan0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Apr 25 10:54:20 schur NetworkManager[512]: <info> [1682438060.6025] device (p2p-dev-wlan0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Apr 25 10:54:20 schur tlp[2120863]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Apr 25 10:54:20 schur tlp[2120863]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Apr 25 10:54:20 schur tlp[2120863]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Apr 25 10:54:20 schur tlp[2120863]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Apr 25 10:54:20 schur tlp[2120895]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Apr 25 10:54:20 schur tlp[2120895]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Apr 25 10:54:20 schur tlp[2120895]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Apr 25 10:54:20 schur tlp[2120895]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Apr 25 10:54:20 schur tlp[2120927]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Apr 25 10:54:20 schur tlp[2120927]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Apr 25 10:54:20 schur tlp[2120927]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Apr 25 10:54:20 schur tlp[2120927]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Apr 25 10:54:23 schur wpa_supplicant[755]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=US
Apr 25 10:54:36 schur systemd-logind[506]: Suspending...
Apr 25 10:54:36 schur NetworkManager[512]: <info> [1682438076.1579] manager: sleep: sleep requested (sleeping: no enabled: yes)
Apr 25 10:54:36 schur NetworkManager[512]: <info> [1682438076.1580] device (wlan0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Apr 25 10:54:36 schur NetworkManager[512]: <info> [1682438076.2094] device (wlan0): set-hw-addr: reset MAC address to E4:A4:71:56:AB:D0 (unmanage)
Apr 25 10:54:36 schur NetworkManager[512]: <info> [1682438076.2209] device (p2p-dev-wlan0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Apr 25 10:54:36 schur NetworkManager[512]: <info> [1682438076.2212] manager: NetworkManager state is now ASLEEP
Apr 25 10:54:36 schur systemd[1]: Reached target Sleep.
Apr 25 10:54:36 schur wpa_supplicant[755]: p2p-dev-wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Apr 25 10:54:36 schur wpa_supplicant[755]: nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
Apr 25 10:54:36 schur systemd[1]: Starting System Suspend...
Apr 25 10:54:36 schur wpa_supplicant[755]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Apr 25 10:54:36 schur systemd-sleep[2121259]: Entering sleep state 'suspend'...
<--- reboot happens below --->
Apr 25 11:20:48 schur kernel: microcode: microcode updated early to revision 0xa6, date = 2022-06-28
Apr 25 11:20:48 schur kernel: Linux version 6.2.11-arch1-1 (linux@archlinux) (gcc (GCC) 12.2.1 20230201, GNU ld (GNU Binutils) 2.40) #1 SMP PREEMPT_DYNAMIC Thu, 13 Apr 2023 16:59:24 +0000
Apr 25 11:20:48 schur kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=2a9459e2-9fde-4f0a-858d-7ed6f395a894 rw resume=UUID=15d901db-b4ce-46e9-a731-7c3e8a90dba0 resume_offset=31760384 quiet loglevel=3 nowatchdog nvme_load=YES
Apr 25 11:20:48 schur kernel: x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
Apr 25 11:20:48 schur kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Apr 25 11:20:48 schur kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Apr 25 11:20:48 schur kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Apr 25 11:20:48 schur kernel: x86/fpu: Supporting XSAVE feature 0x020: 'AVX-512 opmask'
Apr 25 11:20:48 schur kernel: x86/fpu: Supporting XSAVE feature 0x040: 'AVX-512 Hi256'
Apr 25 11:20:48 schur kernel: x86/fpu: Supporting XSAVE feature 0x080: 'AVX-512 ZMM_Hi256'
Apr 25 11:20:48 schur kernel: x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
Apr 25 11:20:48 schur kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
Apr 25 11:20:48 schur kernel: x86/fpu: xstate_offset[5]: 832, xstate_sizes[5]: 64
Apr 25 11:20:48 schur kernel: x86/fpu: xstate_offset[6]: 896, xstate_sizes[6]: 512
Apr 25 11:20:48 schur kernel: x86/fpu: xstate_offset[7]: 1408, xstate_sizes[7]: 1024
Apr 25 11:20:48 schur kernel: x86/fpu: xstate_offset[9]: 2432, xstate_sizes[9]: 8
Apr 25 11:20:48 schur kernel: x86/fpu: Enabled xstate features 0x2e7, context size is 2440 bytes, using 'compacted' format.
Apr 25 11:20:48 schur kernel: signal: max sigframe size: 3632
Apr 25 11:20:48 schur kernel: BIOS-provided physical RAM map:
Apr 25 11:20:48 schur kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
Apr 25 11:20:48 schur kernel: BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
Apr 25 11:20:48 schur kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000039f98fff] usable
Apr 25 11:20:48 schur kernel: BIOS-e820: [mem 0x0000000039f99000-0x000000003a898fff] reserved
Apr 25 11:20:48 schur kernel: BIOS-e820: [mem 0x000000003a899000-0x00000000434aefff] usable
Apr 25 11:20:48 schur kernel: BIOS-e820: [mem 0x00000000434af000-0x000000004387efff] type 20
Apr 25 11:20:48 schur kernel: BIOS-e820: [mem 0x000000004387f000-0x00000000452fefff] reserved
Apr 25 11:20:48 schur kernel: BIOS-e820: [mem 0x00000000452ff000-0x0000000045b2efff] ACPI NVS
Apr 25 11:20:48 schur kernel: BIOS-e820: [mem 0x0000000045b2f000-0x0000000045bfefff] ACPI data
Apr 25 11:20:48 schur kernel: BIOS-e820: [mem 0x0000000045bff000-0x0000000045bfffff] usable
Apr 25 11:20:48 schur kernel: BIOS-e820: [mem 0x0000000045c00000-0x0000000049ffffff] reserved
Apr 25 11:20:48 schur kernel: BIOS-e820: [mem 0x000000004a200000-0x000000004a3fffff] reserved
Apr 25 11:20:48 schur kernel: BIOS-e820: [mem 0x000000004b000000-0x00000000503fffff] reserved
Apr 25 11:20:48 schur kernel: BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
Apr 25 11:20:48 schur kernel: BIOS-e820: [mem 0x00000000fe010000-0x00000000fe010fff] reserved
Apr 25 11:20:48 schur kernel: BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
Apr 25 11:20:48 schur kernel: BIOS-e820: [mem 0x00000000ff400000-0x00000000ffffffff] reserved
Apr 25 11:20:48 schur kernel: BIOS-e820: [mem 0x0000000100000000-0x00000005afbfffff] usable
Apr 25 11:20:48 schur kernel: NX (Execute Disable) protection: active
Apr 25 11:20:48 schur kernel: efi: EFI v2.70 by INSYDE Corp.
Apr 25 11:20:48 schur kernel: efi: ACPI=0x45bfe000 ACPI 2.0=0x45bfe014 TPMFinalLog=0x45ac5000 SMBIOS=0x439e3000 SMBIOS 3.0=0x439e1000 MEMATTR=0x3f931018 ESRT=0x3fba7818
Apr 25 11:20:48 schur kernel: efi: Remove mem75: MMIO range=[0xc0000000-0xcfffffff] (256MB) from e820 map
Apr 25 11:20:48 schur kernel: e820: remove [mem 0xc0000000-0xcfffffff] reserved
Apr 25 11:20:48 schur kernel: efi: Not removing mem76: MMIO range=[0xfe010000-0xfe010fff] (4KB) from e820 map
Apr 25 11:20:48 schur kernel: efi: Remove mem78: MMIO range=[0xff400000-0xffffffff] (12MB) from e820 map
Apr 25 11:20:48 schur kernel: e820: remove [mem 0xff400000-0xffffffff] reserved
Apr 25 11:20:48 schur kernel: SMBIOS 3.3.0 present.
Apr 25 11:20:48 schur kernel: DMI: Framework Laptop/FRANBMCP0A, BIOS 03.07 12/14/2021
Apr 25 11:20:48 schur kernel: tsc: Detected 2400.000 MHz processor
Apr 25 11:20:48 schur kernel: tsc: Detected 2419.200 MHz TSC
Apr 25 11:20:48 schur kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Apr 25 11:20:48 schur kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Apr 25 11:20:48 schur kernel: last_pfn = 0x5afc00 max_arch_pfn = 0x400000000
Apr 25 11:20:48 schur kernel: x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
Apr 25 11:20:48 schur kernel: last_pfn = 0x45c00 max_arch_pfn = 0x400000000
Apr 25 11:20:48 schur kernel: esrt: Reserving ESRT space from 0x000000003fba7818 to 0x000000003fba78a0.
Apr 25 11:20:48 schur kernel: e820: update [mem 0x3fba7000-0x3fba7fff] usable ==> reserved
Apr 25 11:20:48 schur kernel: Using GB pages for direct mapping
Apr 25 11:20:48 schur kernel: Secure boot disabled
Apr 25 11:20:48 schur kernel: RAMDISK: [mem 0x36061000-0x37027fff]
Apr 25 11:20:48 schur kernel: ACPI: Early table checksum verification disabled
Apr 25 11:20:48 schur kernel: ACPI: RSDP 0x0000000045BFE014 000024 (v02 INSYDE)
Apr 25 11:20:48 schur kernel: ACPI: XSDT 0x0000000045BD1188 000104 (v01 INSYDE TGL-ULT 00000002 01000013)
Apr 25 11:20:48 schur kernel: ACPI: FACP 0x0000000045BD3000 00010C (v06 INSYDE TGL-ULT 00000002 ACPI 00040000)
Apr 25 11:20:48 schur kernel: ACPI: DSDT 0x0000000045B79000 056BD7 (v02 INSYDE TGL-ULT 00000002 ACPI 00040000)
Apr 25 11:20:48 schur kernel: ACPI: FACS 0x0000000045AA1000 000040
Apr 25 11:20:48 schur kernel: ACPI: UEFI 0x0000000045B2E000 000236 (v01 INSYDE TGL-ULT 00000001 ACPI 00040000)
Apr 25 11:20:48 schur kernel: ACPI: SSDT 0x0000000045BFA000 00255C (v02 CpuRef CpuSsdt 00003000 INTL 20160422)
Apr 25 11:20:48 schur kernel: ACPI: SSDT 0x0000000045BF6000 0033A6 (v02 DptfTb DptfTabl 00001000 INTL 20160422)
Apr 25 11:20:48 schur kernel: ACPI: SSDT 0x0000000045BF2000 003034 (v02 SaSsdt SaSsdt 00003000 INTL 20160422)
Apr 25 11:20:48 schur kernel: ACPI: SSDT 0x0000000045BEE000 003300 (v02 INTEL IgfxSsdt 00003000 INTL 20160422)
Apr 25 11:20:48 schur kernel: ACPI: SSDT 0x0000000045BE2000 00B30D (v02 INTEL TcssSsdt 00001000 INTL 20160422)
Apr 25 11:20:48 schur kernel: ACPI: SSDT 0x0000000045BE1000 00077B (v02 INSYDE Tpm2Tabl 00001000 INTL 20160422)
Apr 25 11:20:48 schur kernel: ACPI: TPM2 0x0000000045BE0000 00004C (v04 INSYDE TGL-ULT 00000002 ACPI 00040000)
Apr 25 11:20:48 schur kernel: ACPI: SSDT 0x0000000045BDE000 0008C1 (v02 INTEL xh_tudd4 00000000 INTL 20160422)
Apr 25 11:20:48 schur kernel: ACPI: NHLT 0x0000000045BDD000 00002D (v00 INSYDE TGL-ULT 00000002 ACPI 00040000)
Apr 25 11:20:48 schur kernel: ACPI: SSDT 0x0000000045BDB000 0011C3 (v02 INSYDE UsbCTabl 00001000 INTL 20160422)
Apr 25 11:20:48 schur kernel: ACPI: LPIT 0x0000000045BDA000 0000CC (v01 INSYDE TGL-ULT 00000002 ACPI 00040000)
Apr 25 11:20:48 schur kernel: ACPI: WSMT 0x0000000045BD9000 000028 (v01 INSYDE TGL-ULT 00000002 ACPI 00040000)
Apr 25 11:20:48 schur kernel: ACPI: SSDT 0x0000000045BD8000 000B2E (v02 INSYDE PtidDevc 00001000 INTL 20160422)
Apr 25 11:20:48 schur kernel: ACPI: SSDT 0x0000000045BD7000 00012A (v02 INSYDE TbtTypeC 00000000 INTL 20160422)
Apr 25 11:20:48 schur kernel: ACPI: DBGP 0x0000000045BD6000 000034 (v01 INSYDE TGL-ULT 00000002 ACPI 00040000)
Apr 25 11:20:48 schur kernel: ACPI: DBG2 0x0000000045BD5000 000054 (v00 INSYDE TGL-ULT 00000002 ACPI 00040000)
Apr 25 11:20:48 schur kernel: ACPI: ECDT 0x0000000045BD4000 000069 (v01 INSYDE TGL-ULT 00000002 ACPI 00040000)
Apr 25 11:20:48 schur kernel: ACPI: HPET 0x0000000045BD2000 000038 (v01 INSYDE TGL-ULT 00000002 ACPI 00040000)
Apr 25 11:20:48 schur kernel: ACPI: APIC 0x0000000045BFD000 00012C (v03 INSYDE TGL-ULT 00000002 ACPI 00040000)
Apr 25 11:20:48 schur kernel: ACPI: MCFG 0x0000000045BD0000 00003C (v01 INSYDE TGL-ULT 00000002 ACPI 00040000)
Apr 25 11:20:48 schur kernel: ACPI: SSDT 0x0000000045B72000 00661F (v02 INSYDE TGL-ULT 00000002 01000013)
Apr 25 11:20:48 schur kernel: ACPI: DMAR 0x0000000045B71000 0000E8 (v02 INSYDE TGL-ULT 00000002 ACPI 00040000)
Apr 25 11:20:48 schur kernel: ACPI: SSDT 0x0000000045B70000 0000F8 (v01 INSYDE PcdTabl 00001000 INTL 20160422)
Apr 25 11:20:48 schur kernel: ACPI: FPDT 0x0000000045B6F000 000044 (v01 INSYDE TGL-ULT 00000002 ACPI 00040000)
Apr 25 11:20:48 schur kernel: ACPI: PTDT 0x0000000045B6D000 000CFE (v00 INSYDE TGL-ULT 00000005 ACPI 00040000)
Apr 25 11:20:48 schur kernel: ACPI: BGRT 0x0000000045B6E000 000038 (v01 INSYDE TGL-ULT 00000001 ACPI 00040000)
Apr 25 11:20:48 schur kernel: ACPI: Reserving FACP table memory at [mem 0x45bd3000-0x45bd310b]
Apr 25 11:20:48 schur kernel: ACPI: Reserving DSDT table memory at [mem 0x45b79000-0x45bcfbd6]
Apr 25 11:20:48 schur kernel: ACPI: Reserving FACS table memory at [mem 0x45aa1000-0x45aa103f]
Apr 25 11:20:48 schur kernel: ACPI: Reserving UEFI table memory at [mem 0x45b2e000-0x45b2e235]
Apr 25 11:20:48 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45bfa000-0x45bfc55b]
Apr 25 11:20:48 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45bf6000-0x45bf93a5]
Apr 25 11:20:48 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45bf2000-0x45bf5033]
Apr 25 11:20:48 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45bee000-0x45bf12ff]
Apr 25 11:20:48 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45be2000-0x45bed30c]
Apr 25 11:20:48 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45be1000-0x45be177a]
Apr 25 11:20:48 schur kernel: ACPI: Reserving TPM2 table memory at [mem 0x45be0000-0x45be004b]
Apr 25 11:20:48 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45bde000-0x45bde8c0]
Apr 25 11:20:48 schur kernel: ACPI: Reserving NHLT table memory at [mem 0x45bdd000-0x45bdd02c]
Apr 25 11:20:48 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45bdb000-0x45bdc1c2]
Apr 25 11:20:48 schur kernel: ACPI: Reserving LPIT table memory at [mem 0x45bda000-0x45bda0cb]
Apr 25 11:20:48 schur kernel: ACPI: Reserving WSMT table memory at [mem 0x45bd9000-0x45bd9027]
Apr 25 11:20:48 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45bd8000-0x45bd8b2d]
Apr 25 11:20:48 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45bd7000-0x45bd7129]
Apr 25 11:20:48 schur kernel: ACPI: Reserving DBGP table memory at [mem 0x45bd6000-0x45bd6033]
Apr 25 11:20:48 schur kernel: ACPI: Reserving DBG2 table memory at [mem 0x45bd5000-0x45bd5053]
Apr 25 11:20:48 schur kernel: ACPI: Reserving ECDT table memory at [mem 0x45bd4000-0x45bd4068]
Apr 25 11:20:48 schur kernel: ACPI: Reserving HPET table memory at [mem 0x45bd2000-0x45bd2037]
Apr 25 11:20:48 schur kernel: ACPI: Reserving APIC table memory at [mem 0x45bfd000-0x45bfd12b]
Apr 25 11:20:48 schur kernel: ACPI: Reserving MCFG table memory at [mem 0x45bd0000-0x45bd003b]
Apr 25 11:20:48 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45b72000-0x45b7861e]
Apr 25 11:20:48 schur kernel: ACPI: Reserving DMAR table memory at [mem 0x45b71000-0x45b710e7]
Apr 25 11:20:48 schur kernel: ACPI: Reserving SSDT table memory at [mem 0x45b70000-0x45b700f7]
Apr 25 11:20:48 schur kernel: ACPI: Reserving FPDT table memory at [mem 0x45b6f000-0x45b6f043]
Apr 25 11:20:48 schur kernel: ACPI: Reserving PTDT table memory at [mem 0x45b6d000-0x45b6dcfd]
Apr 25 11:20:48 schur kernel: ACPI: Reserving BGRT table memory at [mem 0x45b6e000-0x45b6e037]
Apr 25 11:20:48 schur kernel: No NUMA configuration found
Apr 25 11:20:48 schur kernel: Faking a node at [mem 0x0000000000000000-0x00000005afbfffff]
Apr 25 11:20:48 schur kernel: NODE_DATA(0) allocated [mem 0x5afbfb000-0x5afbfffff]
Apr 25 11:20:48 schur kernel: Zone ranges:
Apr 25 11:20:48 schur kernel: DMA [mem 0x0000000000001000-0x0000000000ffffff]
Apr 25 11:20:48 schur kernel: DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
Apr 25 11:20:48 schur kernel: Normal [mem 0x0000000100000000-0x00000005afbfffff]
Apr 25 11:20:48 schur kernel: Device empty
Apr 25 11:20:48 schur kernel: Movable zone start for each node
Apr 25 11:20:48 schur kernel: Early memory node ranges
Apr 25 11:20:48 schur kernel: node 0: [mem 0x0000000000001000-0x000000000009efff]
Apr 25 11:20:48 schur kernel: node 0: [mem 0x0000000000100000-0x0000000039f98fff]
Apr 25 11:20:48 schur kernel: node 0: [mem 0x000000003a899000-0x00000000434aefff]
Apr 25 11:20:48 schur kernel: node 0: [mem 0x0000000045bff000-0x0000000045bfffff]
Apr 25 11:20:48 schur kernel: node 0: [mem 0x0000000100000000-0x00000005afbfffff]
Apr 25 11:20:48 schur kernel: Initmem setup node 0 [mem 0x0000000000001000-0x00000005afbfffff]
Apr 25 11:20:48 schur kernel: On node 0, zone DMA: 1 pages in unavailable ranges
Apr 25 11:20:48 schur kernel: On node 0, zone DMA: 97 pages in unavailable ranges
Apr 25 11:20:48 schur kernel: On node 0, zone DMA32: 2304 pages in unavailable ranges
Apr 25 11:20:48 schur kernel: On node 0, zone DMA32: 10064 pages in unavailable ranges
Apr 25 11:20:48 schur kernel: On node 0, zone Normal: 9216 pages in unavailable ranges
Apr 25 11:20:48 schur kernel: On node 0, zone Normal: 1024 pages in unavailable ranges
Apr 25 11:20:48 schur kernel: Reserving Intel graphics memory at [mem 0x4c800000-0x503fffff]
Apr 25 11:20:48 schur kernel: ACPI: PM-Timer IO Port: 0x1808
Apr 25 11:20:48 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Apr 25 11:20:48 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
Apr 25 11:20:48 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
Apr 25 11:20:48 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
Apr 25 11:20:48 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
Apr 25 11:20:48 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
Apr 25 11:20:48 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
Apr 25 11:20:48 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
Apr 25 11:20:48 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
Apr 25 11:20:48 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
Apr 25 11:20:48 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
Apr 25 11:20:48 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
Apr 25 11:20:48 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
Apr 25 11:20:48 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
Apr 25 11:20:48 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
Apr 25 11:20:48 schur kernel: ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
Apr 25 11:20:48 schur kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
Apr 25 11:20:48 schur kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Apr 25 11:20:48 schur kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Apr 25 11:20:48 schur kernel: ACPI: Using ACPI (MADT) for SMP configuration information
Apr 25 11:20:48 schur kernel: ACPI: HPET id: 0x8086a201 base: 0xfed00000
Apr 25 11:20:48 schur kernel: e820: update [mem 0x3f932000-0x3f980fff] usable ==> reserved
Apr 25 11:20:48 schur kernel: TSC deadline timer available
Apr 25 11:20:48 schur kernel: smpboot: Allowing 8 CPUs, 0 hotplug CPUs
Apr 25 11:20:48 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Apr 25 11:20:48 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
Apr 25 11:20:48 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x39f99000-0x3a898fff]
Apr 25 11:20:48 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x3f932000-0x3f980fff]
Apr 25 11:20:48 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x3fba7000-0x3fba7fff]
Apr 25 11:20:48 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x434af000-0x4387efff]
Apr 25 11:20:48 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x4387f000-0x452fefff]
Apr 25 11:20:48 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x452ff000-0x45b2efff]
Apr 25 11:20:48 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x45b2f000-0x45bfefff]
Apr 25 11:20:48 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x45c00000-0x49ffffff]
Apr 25 11:20:48 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x4a000000-0x4a1fffff]
Apr 25 11:20:48 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x4a200000-0x4a3fffff]
Apr 25 11:20:48 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x4a400000-0x4affffff]
Apr 25 11:20:48 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x4b000000-0x503fffff]
Apr 25 11:20:48 schur kernel: PM: hibernation: Registered nosave memory: [mem 0x50400000-0xfe00ffff]
Apr 25 11:20:48 schur kernel: PM: hibernation: Registered nosave memory: [mem 0xfe010000-0xfe010fff]
Apr 25 11:20:48 schur kernel: PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfed1ffff]
Apr 25 11:20:48 schur kernel: PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfed7ffff]
Apr 25 11:20:48 schur kernel: PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xffffffff]
Apr 25 11:20:48 schur kernel: [mem 0x50400000-0xfe00ffff] available for PCI devices
Apr 25 11:20:48 schur kernel: Booting paravirtualized kernel on bare hardware
