I have noticed that the “When battery is critically low” option is missing in EndeavourOS Cinnamon. This is visible and configurable on Mint Cinnamon. I am wondering if anyone knows of a package I can install to add this option or perhaps a config file that I can modify that corresponds to the appropriate setting to configure this?
Trere are some – hopefully not crucial – errors at starting mate-power-manager.
Remove the original power manager icon from taskbar if this mate version suits you.
Thanks, but I’d much rather get the option in Cinnamon settings if possible rather than replacing it with and relying on mate-power-manager. If there anyway to achieve this so I mirrors the Cinnamon settings?
Thanks
Finally I let the laptop accumulator to discharge and when there was no blinking on power button I connected the charger.
I pressed power-on and life went on thru grub (journal window proceeded among the other ones).
