Hi,
Possible to disable color bar (yellow,purple and green) in monitoring widgets? I have network speed monitor and total cpu usage. I prefer only text values
If it is the default widgets → right click → configure → display style → text only
It is the default widget. I have output/display as text only option … When selecting the censor a color is a chosen by default under censor section.
Smokeyyou have to choose Text Only in view mode under appearance and click apply …
Widget not showing after adding text only sensor
After checking it in the panel I can now see what you mean, I was only trying it on the desktop and it appears to work here and not in the panel. I didn’t try to resize it or anything so this may work but it may be a bug.
okies … cool … for now I will continue with this
