I uninstalled pop shell from gnome and now the lock screen animation won’t play anymore, how would I fix this?
Are you using Pop_Os or Endeavour OS?
This is something considering this with quick googling.
I am using endeavoros, I manually installed pop shell. I also want to completely remove it, not just disable it
@akarii ,
yay pop-shell | grep Installed
will show you the exact package name (gnome-shell-extension-pop-shell-git)
yay -Rns gnome-shell-extension-pop-shell-git
uninstalls it and the dependencies.
btw Super+Esc is the shortcut for screen lock. It’s easy to modify to Super+L in
gnome-control-center
/ Keyboard / Keyboard Shortcuts / System
thanks, and I also did rebind screen lock
Might you know how to bind toggling the touchpad and power profiles through gnome?
Let’s make a script tt.sh
#!/bin/bash
# This shell script is PUBLIC DOMAIN. You may do whatever you want with it.
TOGGLE=$HOME/.toggle
if [ ! -e $TOGGLE ]; then
touch $TOGGLE
gsettings set org.gnome.desktop.peripherals.touchpad send-events disabled
else
rm $TOGGLE
gsettings set org.gnome.desktop.peripherals.touchpad send-events enabled
fi
Add a custom shortcut e.g ALT+X and call /home/akarii/tt.sh Do not forget to make it executable
chmod +x tt.sh
The topic is closing…
powerprofilesctl get
powerprofilesctl set power-saver
powerprofilesctl set balanced
powerprofilesctl set performance
@akarii and something you can polish further
cat sp.sh
#!/bin/bash
PROFILE=$(powerprofilesctl get)
yad --title="$PROFILE" --completion \
--entry="Name:" "" \
"1-power-saver" "2-balanced" "3-performance" | \
while read line; do
ENTRY=`echo $line | awk -F',' '{print $1}'`
# echo $ENTRY
case $ENTRY in
1-power-saver )
powerprofilesctl set power-saver ;;
2-balanced )
powerprofilesctl set balanced ;;
3-performance )
powerprofilesctl set performance ;;
esac
done
