Polkit does not work
Ive installed polkit-gnome then i used (exec /usr/libexec/polkit-gnome-autentication-agent-1 &), afterwards i tried to open gparted from terminal but i get the message (Error executing command as another user: No authentication agent found.)
http://ix.io/4GJK
That path is not quite right. Did you get any error message when you ran it? The path should be like this:
/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1 &
You can add it to your config.py file so it starts automatically with Qtile, as described here: https://github.com/qtile/qtile/issues/1264
You need an authentication agent (v. https://wiki.archlinux.org/index.php/Polkit#Authentication_agents).
In Arch Linux ou can write an autostart.sh file, if you have polkit-gnome installed, like this:
#! /bin/bash
/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1 & # Graphical authentication agent
Don’t forget chmod +x autostart.sh.
Then put this at your config.py file:
##### STARTUP PROGRAMS #####
@hook.subscribe.startup_once
def start_once():
     home = os.path.expanduser("~")
     subprocess.call([home + "/.config/qtile/autostart.sh"])
You need to import os for this python code.
Then, when Qtile start, the authentication agent will start too (and all programs you call at your autostart.sh file, like a compositor, a wallpaper setter et cetera).
Thank you, that worked.
