Please help, System won't boot after update. Stuck on "A start job is running for dev-disk-by..."
After updating, I got a kernel panic when trying to boot the OS. I was able to fix it by generating a new grub and fstab config. Now the system starts to boot, but stops when trying to mount root.
fstab:
# Use ‘blkid’ to print the universally unique identifier for a device; this may
# /dev/nvme0n1p1 UUID=3F55-147E
# /dev/nvme0n1p2 UUID=595f7627-4012-4017-93ce-745a32ae84b2
LABEL=root              /               btrfs           rw,relatime,ssd,discard=async,space_cache=v2,subvol=/@ 0 0
/dev/nvme0n1p1          /efi            vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 2
# /dev/nvme0n1p3 UUID=1d3ce05d-53c8-4512-9172-7d76c307aef8
LABEL=home              /home           btrfs           rw,relatime,ssd,discard=async,space_cache=v2,subvol=/ 0 0
LABEL=root              /var/cache      btrfs           rw,relatime,ssd,discard=async,space_cache=v2,subvol=/@cache   0 0
LABEL=root              /var/log        btrfs           rw,relatime,ssd,discard=async,space_cache=v2,subvol=/@log     0 0
[liveuser@eos-2025.03.19 ~]$ sudo blkid
/dev/nvme0n1p5: LABEL="Windows X-Lite" BLOCK_SIZE="512" UUID="0A8026BC8026ADDF" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="8104d3db-450c-4629-ac04-9910d6cd639d"
/dev/nvme0n1p3: LABEL="home" UUID="1d3ce05d-53c8-4512-9172-7d76c307aef8" UUID_SUB="6b70f165-5ad2-4e1f-8876-47a41ca51d03" BLOCK_SIZE="4096" TYPE="btrfs" PARTUUID="d02e9935-b67a-4548-8f92-271ae2b6cb85"
/dev/nvme0n1p1: UUID="3F55-147E" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="44b70316-caf0-4228-b367-35d315c45bd7"
/dev/nvme0n1p4: PARTLABEL="Microsoft reserved partition" PARTUUID="27ee7713-db42-42ed-b211-814c855e022e"
/dev/nvme0n1p2: LABEL="root" UUID="595f7627-4012-4017-93ce-745a32ae84b2" UUID_SUB="f86c754a-d040-4a57-a311-48a7399df111" BLOCK_SIZE="4096" TYPE="btrfs" PARTUUID="a16bf6df-dad5-4b20-bcf0-308a0a1f3993"
/dev/loop0: BLOCK_SIZE="1048576" TYPE="squashfs"
/dev/mapper/ventoy: BLOCK_SIZE="2048" UUID="2025-03-19-11-30-07-00" LABEL="EOS_202503" TYPE="iso9660" PTUUID="ea64eddc" PTTYPE="dos"
/dev/sda2: SEC_TYPE="msdos" LABEL_FATBOOT="VTOYEFI" LABEL="VTOYEFI" UUID="3F32-27F5" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="VTOYEFI" PARTUUID="7bbd096c-76d5-420a-b8d0-f8b9af45efaf"
/dev/sda1: LABEL="Medicat" BLOCK_SIZE="512" UUID="5858A2206B824400" TYPE="ntfs" PARTLABEL="Ventoy" PARTUUID="f809d1a1-c3b7-4fba-8155-b7f03d431e1c"
inxi:
  Kernel: 6.13.7-arch1-1 arch: x86_64 bits: 64
  Desktop: KDE Plasma v: 6.3.3 Distro: EndeavourOS
  Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA401QC_GA401QC
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: GA401QC v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: GA401QC.415 date: 08/11/2023
Battery:
  ID-1: BAT0 charge: 54.7 Wh (100.0%) condition: 54.7/76.0 Wh (72.0%)
    volts: 15.8 min: 15.8
  Info: 8-core model: AMD Ryzen 9 5900HS with Radeon Graphics bits: 64
    type: MT MCP cache: L2: 4 MiB
  Speed (MHz): avg: 1099 min/max: 400/4680 cores: 1: 1099 2: 1099 3: 1099
    4: 1099 5: 1099 6: 1099 7: 1099 8: 1099 9: 1099 10: 1099 11: 1099 12: 1099
    13: 1099 14: 1099 15: 1099 16: 1099
  Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] driver: nouveau v: kernel
  Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
    Radeon Mobile Series] driver: amdgpu v: kernel
  Display: unspecified server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    driver: X: loaded: amdgpu,modesetting unloaded: radeon dri: radeonsi,nouveau
    gpu: amdgpu,nouveau resolution: 1: 2560x1440~60Hz 2: 2560x1440~120Hz
  API: EGL v: 1.5 drivers: nouveau,radeonsi,swrast
    platforms: gbm,x11,surfaceless,device
  API: OpenGL v: 4.6 compat-v: 4.3 vendor: amd mesa v: 25.0.1-arch1.2
    renderer: AMD Radeon Graphics (radeonsi renoir ACO DRM 3.61 6.13.7-arch1-1)
    de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: NVIDIA GA107 High Definition Audio driver: snd_hda_intel
  Device-2: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
  Device-3: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    driver: N/A
  Device-4: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
  API: ALSA v: k6.13.7-arch1-1 status: kernel-api
  Server-1: PipeWire v: 1.4.1 status: active
  Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
    driver: mt7921e
  IF: wlan0 state: down mac: 8e:31:46:75:9b:d6
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
  IF: eth0 state: up speed: 1000 Mbps duplex: full mac: 5c:28:86:7c:10:0b
Bluetooth:
  Device-1: IMC Networks Wireless_Device driver: btusb type: USB
  Report: btmgmt ID: hci0 state: up address: 48:E7:DA:55:CF:F4 bt-v: 5.2
  Local Storage: total: 990.96 GiB used: 0 KiB (0.0%)
  ID-1: /dev/nvme0n1 vendor: Western Digital model: WD BLACK SN850X 1000GB
  ID-2: /dev/sda model: Mass Storage Device size: 59.45 GiB type: USB
  ID-1: / size: 10 GiB used: 231.9 MiB (2.3%) fs: overlay source: ERR-102
  System Temperatures: cpu: 82.1 C mobo: 46.0 C gpu: amdgpu temp: 61.0 C
  Fan Speeds (rpm): cpu: 2500
  Memory: total: 16 GiB note: est. available: 15.03 GiB used: 4.54 GiB (30.2%)
  Processes: 346 Uptime: 18m Shell: Bash inxi: 3.3.37
I also tried checking, repairing, and rebalancing the btrfs file system, but that didn’t help.
If you need any logs, please let me know. I really don’t want to reinstall the system.
Shouldn’t you have something like
subvol=/@home
in accordance with the pattern you have used for naming the other subvolumes?
