Budgie now develops a fork of the gnome-control-center that replaces it for budgie!
budgie-control-center:
https://aur.archlinux.org/packages/budgie-control-center
It is recommended to not use gnome-control-center on budgie anymore, it is known to crash on some tabs like you can see reported all over:
“crashed when I viewed “multitasking” panel.”
Remove the gnome one and install the new one made for Budgie:
To get all unneeded dependencies from gnome-control-center removed:
sudo pacman -Rc gnome-control-center
(thanks@dalto to edit the command to -Rc from -Rsc)
As always keep an eye on what it will remove to not uninstall stuff you need ![]()
update the system:
sudo pacman -Syu
and install the new control center (we added it to the EndeavourOS repo because it is not moved to repos from AUR for now {at arch})
sudo pacman -S budgie-control-center
