quaqom
October 30, 2026, 7:09am
1
Hi. I performed a system upgrade, which upgraded plasma to 6.8.1. My desktop suddenly lost the panels and the wallpaper, but I can still see my cursors and autostarted windows. I can also use shortcuts except the launcher key due to the absence of the panel. Only way I open applications is by searching it through the KRunner.
Here’s my system info:
Operating System: EndeavourOS
KDE Plasma Version: 6.8.2
KDE Frameworks Version: 6.31.0
Qt Version: 6.12.0
Kernel Version: 7.2.11-arch1-1 (64-bit)
Graphics Platform: Wayland
Processors: 8 × Intel® Core™ i5-10300H CPU @ 2.50GHz
Memory: 24 GiB of RAM (23.3 GiB usable)
Graphics Processor: Mesa Intel® UHD Graphics
Manufacturer: Acer
Product Name: Predator PH315-53
System Version: V2.04
Here’s my past pacman logs:
Here’s my system logs:
journal-oct (Google Drive)
Does this happen on every login since the update, or did the panels disappear during the running session? Is there any error message or crash notification for Plasma? Please share the relevant error text if there is one, with any personal information removed.
quaqom
November 1, 2026, 5:00am
3
Yes. This happens every login since the update and the panels disappear during the running session. In the system logs, there are repeating error log from kwin_wayland that says No QSGTexture provided from updateSampledImage(). For plasmashell, here’s the full log from plasmashell:
Nob 01 12:54:08 achlys systemd[901]: plasma-plasmashell.service: Consumed 443ms CPU time over 180ms wall clock time, 119.5M memory peak.
Nob 01 12:54:08 achlys systemd[901]: plasma-plasmashell.service: Failed with result 'start-limit-hit'.
Nob 01 12:54:08 achlys systemd[901]: plasma-plasmashell.service: Start request repeated too quickly.
Nob 01 12:54:08 achlys systemd[901]: plasma-plasmashell.service: Scheduled restart job, restart counter is at 3.
Nob 01 12:54:08 achlys systemd[901]: plasma-plasmashell.service: Consumed 443ms CPU time over 2.209s wall clock time, 119.5M memory peak.
Nob 01 12:54:08 achlys systemd[901]: plasma-plasmashell.service: Failed with result 'core-dump'.
Nob 01 12:54:08 achlys systemd[901]: plasma-plasmashell.service: Main process exited, code=dumped, status=11/SEGV
Nob 01 12:54:08 achlys systemd-coredump[2442]: Process 2350 (plasmashell) of user 1000 dumped core.
#2 0x000055fa72e778a6 n/a (plasmashell + 0x618a6)
#3 0x000055fa72e97a52 n/a (plasmashell + 0x81a52)
#20 0x000055fa72e3d09a n/a (plasmashell + 0x2709a)
#23 0x000055fa72e3d8c5 n/a (plasmashell + 0x278c5)
Nob 01 12:54:08 achlys systemd-coredump[2441]: Process 2350 (plasmashell) of user 1000 terminated abnormally with signal 11/SEGV, processing...
Nob 01 12:54:08 achlys kernel: plasmashell[2350]: segfault at 8 ip 00007f6d191834c0 sp 00007ffdcbb99550 error 4 in libQt6Quick.so.6.12.0[1834c0,7f6d19112000+4a8000] likely on CPU 0 (core 0, socket 0)
Nob 01 12:54:08 achlys plasmashell[2350]: QQmlComponent: Component is not ready
Nob 01 12:54:08 achlys plasmashell[2350]: Member enabled of the object DeclarativeDropArea overrides a member of the base object. Consider renaming it or adding final or override specifier
Nob 01 12:54:07 achlys plasmashell[2350]: KPackageStructure of KPluginMetaData(pluginId:"org.kde.plasma.betterkickerdash", fileName: "/home/powerseal/.local/share/plasma/plasmoids/org.kde.plasma.betterkickerdash/metadata.json") does not match requested format "Plasma/Applet"
Nob 01 12:54:06 achlys systemd[901]: plasma-plasmashell.service: Scheduled restart job, restart counter is at 2.
Nob 01 12:54:06 achlys systemd[901]: plasma-plasmashell.service: Consumed 436ms CPU time over 1.478s wall clock time, 119.3M memory peak.
Nob 01 12:54:06 achlys systemd[901]: plasma-plasmashell.service: Failed with result 'core-dump'.
Nob 01 12:54:06 achlys systemd[901]: plasma-plasmashell.service: Main process exited, code=dumped, status=11/SEGV
Nob 01 12:54:06 achlys systemd-coredump[2318]: Process 2279 (plasmashell) of user 1000 dumped core.
#2 0x000056067bf9f8a6 n/a (plasmashell + 0x618a6)
#3 0x000056067bfbfa52 n/a (plasmashell + 0x81a52)
#20 0x000056067bf6509a n/a (plasmashell + 0x2709a)
#23 0x000056067bf658c5 n/a (plasmashell + 0x278c5)
Nob 01 12:54:05 achlys systemd-coredump[2314]: Process 2279 (plasmashell) of user 1000 terminated abnormally with signal 11/SEGV, processing...
Nob 01 12:54:05 achlys kernel: plasmashell[2279]: segfault at 8 ip 00007fe4ce7834c0 sp 00007fffbfc95370 error 4 in libQt6Quick.so.6.12.0[1834c0,7fe4ce712000+4a8000] likely on CPU 0 (core 0, socket 0)
Nob 01 12:54:05 achlys plasmashell[2279]: QQmlComponent: Component is not ready
Nob 01 12:54:05 achlys plasmashell[2279]: Member enabled of the object DeclarativeDropArea overrides a member of the base object. Consider renaming it or adding final or override specifier
Nob 01 12:54:05 achlys plasmashell[2279]: KPackageStructure of KPluginMetaData(pluginId:"org.kde.plasma.betterkickerdash", fileName: "/home/powerseal/.local/share/plasma/plasmoids/org.kde.plasma.betterkickerdash/metadata.json") does not match requested format "Plasma/Applet"
Nob 01 12:54:05 achlys systemd[901]: plasma-plasmashell.service: Scheduled restart job, restart counter is at 1.
Nob 01 12:54:04 achlys systemd[901]: plasma-plasmashell.service: Consumed 482ms CPU time over 29.030s wall clock time, 142.1M memory peak.
Nob 01 12:54:04 achlys systemd[901]: plasma-plasmashell.service: Failed with result 'core-dump'.
Nob 01 12:54:04 achlys systemd[901]: plasma-plasmashell.service: Main process exited, code=dumped, status=11/SEGV
Nob 01 12:54:04 achlys systemd-coredump[2268]: Process 1026 (plasmashell) of user 1000 dumped core.
#2 0x0000562f926f58a6 n/a (plasmashell + 0x618a6)
#3 0x0000562f92715a52 n/a (plasmashell + 0x81a52)
#20 0x0000562f926bb09a n/a (plasmashell + 0x2709a)
#23 0x0000562f926bb8c5 n/a (plasmashell + 0x278c5)
Nob 01 12:54:04 achlys systemd-coredump[2267]: Process 1026 (plasmashell) of user 1000 terminated abnormally with signal 11/SEGV, processing...
Nob 01 12:54:04 achlys kernel: plasmashell[1026]: segfault at 8 ip 00007fa013b834c0 sp 00007ffe3138f490 error 4 in libQt6Quick.so.6.12.0[1834c0,7fa013b12000+4a8000] likely on CPU 0 (core 0, socket 0)
Nob 01 12:54:04 achlys plasmashell[1026]: QQmlComponent: Component is not ready
Nob 01 12:54:02 achlys plasmashell[1026]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Connection already associated with an application ID")
Nob 01 12:53:59 achlys plasmashell[1026]: Member enabled of the object DeclarativeDropArea overrides a member of the base object. Consider renaming it or adding final or override specifier
Nob 01 12:53:56 achlys plasmashell[1026]: QDBusConnection: name 'org.freedesktop.portal.Desktop' had owner '' but we thought it was ':1.53'
Nob 01 12:53:51 achlys plasmashell[1026]: KPackageStructure of KPluginMetaData(pluginId:"org.kde.plasma.betterkickerdash", fileName: "/home/powerseal/.local/share/plasma/plasmoids/org.kde.plasma.betterkickerdash/metadata.json") does not match requested format "Plasma/Applet"
Well I can read from the log there seems to be a problem with this plasmoid.
An improved fork of KDE Plasma's Kicker Dash Application Dashboard which is a fullscreen application launcher
On that page I can see some reference to plasma 5 and it has been created 4 years ago, so that would make sense. So it might not be compatible with plasma 6 (anymore), or something like that.
Try to switch to the default “kicker” and see what happens, or create a new user without using the above plasmoid.
quaqom
November 1, 2026, 7:20am
5
I can’t switch to the default “kicker” because the panels aren’t there as well as the desktop, unless there is a way to switch it on a terminal.
I tried to restart the plasmashell service to see new logs, and finally caught the core dump:
Nob 01 15:11:15 achlys systemd-coredump[18047]: Process 18017 (plasmashell) of user 1000 dumped core.
Stack trace of thread 18017:
#0 0x00007f07037834c0 _ZN10QQuickItem13setParentItemEPS_ (libQt6Quick.so.6 + 0x1834c0)
#1 0x00007f0704093230 _ZN11PlasmaQuick15ContainmentView9setSourceERK4QUrl (libPlasmaQuick.so.8 + 0x44230)
#2 0x000055aaeb9338a6 n/a (plasmashell + 0x618a6)
#3 0x000055aaeb953a52 n/a (plasmashell + 0x81a52)
#4 0x00007f07011f6cc8 n/a (libQt6Core.so.6 + 0x1f6cc8)
#5 0x00007f0703f66656 _ZN6Plasma6Corona25containmentUiReadyChangedEPNS_11ContainmentEb (libPlasma.so.8 + 0x38656)
#6 0x00007f07011f6cc8 n/a (libQt6Core.so.6 + 0x1f6cc8)
#7 0x00007f0703f59bdb _ZN6Plasma11Containment14uiReadyChangedEb (libPlasma.so.8 + 0x2bbdb)
#8 0x00007f0703f545a5 n/a (libPlasma.so.8 + 0x265a5)
#9 0x00007f07011ebe19 _ZN7QObject5eventEP6QEvent (libQt6Core.so.6 + 0x1ebe19)
#10 0x00007f070270355f _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt6Widgets.so.6 + 0x10355f)
#11 0x00007f07011891d8 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt6Core.so.6 + 0x1891d8)
#12 0x00007f07013757b5 _ZN14QTimerInfoList14activateTimersEv (libQt6Core.so.6 + 0x3757b5)
#13 0x00007f07014c63a9 n/a (libQt6Core.so.6 + 0x4c63a9)
#14 0x00007f06ffcc775e n/a (libglib-2.0.so.0 + 0x6175e)
#15 0x00007f06ffcd0c50 n/a (libglib-2.0.so.0 + 0x6ac50)
#16 0x00007f06ffcd0db5 g_main_context_iteration (libglib-2.0.so.0 + 0x6adb5)
#17 0x00007f07014c4d22 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x4c4d22)
#18 0x00007f0701196a74 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x196a74)
#19 0x00007f070118cfca _ZN16QCoreApplication4execEv (libQt6Core.so.6 + 0x18cfca)
#20 0x000055aaeb8f909a n/a (plasmashell + 0x2709a)
#21 0x00007f0700827781 n/a (libc.so.6 + 0x27781)
#22 0x00007f07008278b9 __libc_start_main (libc.so.6 + 0x278b9)
#23 0x000055aaeb8f98c5 n/a (plasmashell + 0x278c5)
Stack trace of thread 18019:
#0 0x00007f07008a08f2 n/a (libc.so.6 + 0xa08f2)
#1 0x00007f07009112e5 __poll (libc.so.6 + 0x1112e5)
#2 0x00007f07023d0a18 n/a (libQt6WaylandClient.so.6 + 0x70a18)
#3 0x00007f0701378fdb n/a (libQt6Core.so.6 + 0x378fdb)
#4 0x00007f0700898042 n/a (libc.so.6 + 0x98042)
#5 0x00007f070092072c n/a (libc.so.6 + 0x12072c)
Stack trace of thread 18021:
#1 0x00007f07009119d7 ppoll (libc.so.6 + 0x1119d7)
#2 0x00007f06ffcd0c9e n/a (libglib-2.0.so.0 + 0x6ac9e)
#3 0x00007f06ffcd0db5 g_main_context_iteration (libglib-2.0.so.0 + 0x6adb5)
#4 0x00007f07014c4d22 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x4c4d22)
#5 0x00007f0701196a74 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x196a74)
#6 0x00007f07012c4a02 _ZN7QThread4execEv (libQt6Core.so.6 + 0x2c4a02)
#7 0x00007f0701379075 n/a (libQt6Core.so.6 + 0x379075)
#8 0x00007f0700898042 n/a (libc.so.6 + 0x98042)
#9 0x00007f070092072c n/a (libc.so.6 + 0x12072c)
Stack trace of thread 18030:
#1 0x00007f0700894c79 n/a (libc.so.6 + 0x94c79)
#2 0x00007f07008974ec pthread_cond_wait (libc.so.6 + 0x974ec)
#3 0x00007f06d722744e n/a (libgallium-26.2.6-arch1.1.so + 0x62744e)
#4 0x00007f06d71dc6bd n/a (libgallium-26.2.6-arch1.1.so + 0x5dc6bd)
#5 0x00007f06d722738d n/a (libgallium-26.2.6-arch1.1.so + 0x62738d)
#6 0x00007f0700898042 n/a (libc.so.6 + 0x98042)
#7 0x00007f070092072c n/a (libc.so.6 + 0x12072c)
Stack trace of thread 18018:
#7 0x00007f07022c9781 n/a (libQt6DBus.so.6 + 0x38781)
#8 0x00007f0701378fdb n/a (libQt6Core.so.6 + 0x378fdb)
#9 0x00007f0700898042 n/a (libc.so.6 + 0x98042)
#10 0x00007f070092072c n/a (libc.so.6 + 0x12072c)
Stack trace of thread 18038:
Stack trace of thread 18031:
Stack trace of thread 18020:
Stack trace of thread 18042:
Stack trace of thread 18036:
#2 0x00007f0700897702 pthread_cond_timedwait (libc.so.6 + 0x97702)
#3 0x00007f070137f8e9 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt6Core.so.6 + 0x37f8e9)
#4 0x00007f07024119f1 _ZN15QtWaylandClient14QWaylandWindow16waitForFrameSyncEi (libQt6WaylandClient.so.6 + 0xb19f1)
#5 0x00007f06f1863c24 _ZN15QtWaylandClient17QWaylandGLContext11swapBuffersEP16QPlatformSurface (libqt-plugin-wayland-egl.so + 0xcc24)
#6 0x00007f0701dec8ad n/a (libQt6Gui.so.6 + 0x5ec8ad)
#7 0x00007f0701c36647 _ZN4QRhi8endFrameEP13QRhiSwapChain6QFlagsINS_12EndFrameFlagEE (libQt6Gui.so.6 + 0x436647)
#8 0x00007f0703ac33b8 n/a (libQt6Quick.so.6 + 0x4c33b8)
#9 0x00007f0701378fdb n/a (libQt6Core.so.6 + 0x378fdb)
#10 0x00007f0700898042 n/a (libc.so.6 + 0x98042)
#11 0x00007f070092072c n/a (libc.so.6 + 0x12072c)
Stack trace of thread 18041:
Stack trace of thread 18045:
#4 0x00007f07012c1845 n/a (libQt6Core.so.6 + 0x2c1845)
#5 0x00007f0701378fdb n/a (libQt6Core.so.6 + 0x378fdb)
Stack trace of thread 18044:
Stack trace of thread 18039:
Stack trace of thread 18037:
Stack trace of thread 18043:
Stack trace of thread 18040:
ELF object binary architecture: AMD x86-64
Before I made this post, I logged into my test user accounts. The desktops and the panels are there.
I think it’s relevant to mention that I used to have the catpswin56’s vistathemeplasma, until I encountered graphical glitches, so I uninstalled it using its uninstallation script and reinstalled libplasma, but it messed up and my default Plasma Wayland session now had affected some widgets like the Activity Switcher.
Well I guess this line on the website should probably have been a red flag not to install a theme like that.
This software comes "as is" without warranty of any kind. It's always recommended to make backups of your system just in case. I am not responsible for broken systems, please proceed with caution.
Anyway , it probably will be of no use to do this, but maybe look for some config files left behind.
quaqom
November 8, 2026, 2:54am
7
Followed the answer post in Plasmashell crashes with black screen and cursor (wayland) - #4 by ZippyDippy by deleting the non-KDE plasmoids `.local/share/plasma/plasmoids/`
Ran plasmashell with -n option to avoid crash loop, which outputted only these lines:
qt.qml.propertyCache.append: Member enabled of the object DeclarativeDropArea overrides a member of the base object. Consider renaming it or adding final or override specifier
KCrash: Application 'plasmashell' crashing... crashRecursionCounter = 2
Segmentation fault (core dumped) plasmashell -n
Attempted to run coredumpctl debug plasmashell. This was the output:
PID: 8359 (plasmashell)
TID: 8359 (plasmashell)
UID: 1000 (powerseal)
GID: 1000 (powerseal)
Signal: 11 (SEGV) si_code: SI_TKILL
Timestamp: Sun 2026-11-08 10:46:14 PST (12s ago)
Command Line: plasmashell -n
Executable: /usr/bin/plasmashell
Control Group: /user.slice/user-1000.slice/user@1000.service/app.slice/app-org.kde.konsole-3250.scope/tab(3258).scope
Unit: user@1000.service
User Unit: app-org.kde.konsole-3250.scope
Slice: user-1000.slice
Owner UID: 1000 (powerseal)
Boot ID: 7ed25c5b421f419fbd1ac430d3d713c5
Machine ID: 1e69431a084f46b7b37b015b9c544715
Hostname: achlys
Storage: /var/lib/systemd/coredump/core.plasmashell.1000.7ed25c5b421f419fbd1ac430d3d713c5.8359.1794105974000000.zst (present)
Size on Disk: 10.4M
Message: Process 8359 (plasmashell) of user 1000 dumped core.
Stack trace of thread 8359:
#0 0x00007f5efae9a11c n/a (libc.so.6 + 0x9a11c)
#1 0x00007f5efae3e5d0 raise (libc.so.6 + 0x3e5d0)
#2 0x00007f5efe273ee9 _ZN6KCrash19defaultCrashHandlerEi (libKF6Crash.so.6 + 0x7ee9)
#3 0x00007f5efae3e6f0 n/a (libc.so.6 + 0x3e6f0)
#4 0x00007f5efdb834c0 _ZN10QQuickItem13setParentItemEPS_ (libQt6Quick.so.6 + 0x1834c0)
#5 0x00007f5efe4d7230 _ZN11PlasmaQuick15ContainmentView9setSourceERK4QUrl (libPlasmaQuick.so.8 + 0x44230)
#6 0x000055bc67e468a6 n/a (plasmashell + 0x618a6)
#7 0x000055bc67e66a52 n/a (plasmashell + 0x81a52)
#8 0x00007f5efb7f6cc8 n/a (libQt6Core.so.6 + 0x1f6cc8)
#9 0x00007f5efe3aa656 _ZN6Plasma6Corona25containmentUiReadyChangedEPNS_11ContainmentEb (libPlasma.so.8 + 0x38656)
#10 0x00007f5efb7f6cc8 n/a (libQt6Core.so.6 + 0x1f6cc8)
#11 0x00007f5efe39dbdb _ZN6Plasma11Containment14uiReadyChangedEb (libPlasma.so.8 + 0x2bbdb)
#12 0x00007f5efe3985a5 n/a (libPlasma.so.8 + 0x265a5)
#13 0x00007f5efb7ebe19 _ZN7QObject5eventEP6QEvent (libQt6Core.so.6 + 0x1ebe19)
#14 0x00007f5efcb0355f _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt6Widgets.so.6 + 0x10355f)
#15 0x00007f5efb7891d8 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt6Core.so.6 + 0x1891d8)
#16 0x00007f5efb9757b5 _ZN14QTimerInfoList14activateTimersEv (libQt6Core.so.6 + 0x3757b5)
#17 0x00007f5efbac63a9 n/a (libQt6Core.so.6 + 0x4c63a9)
#18 0x00007f5efa12675e n/a (libglib-2.0.so.0 + 0x6175e)
#19 0x00007f5efa12fc50 n/a (libglib-2.0.so.0 + 0x6ac50)
#20 0x00007f5efa12fdb5 g_main_context_iteration (libglib-2.0.so.0 + 0x6adb5)
#21 0x00007f5efbac4d22 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x4c4d22)
#22 0x00007f5efb796a74 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x196a74)
#23 0x00007f5efb78cfca _ZN16QCoreApplication4execEv (libQt6Core.so.6 + 0x18cfca)
#24 0x000055bc67e0c09a n/a (plasmashell + 0x2709a)
#25 0x00007f5efae27781 n/a (libc.so.6 + 0x27781)
#26 0x00007f5efae278b9 __libc_start_main (libc.so.6 + 0x278b9)
#27 0x000055bc67e0c8c5 n/a (plasmashell + 0x278c5)
Stack trace of thread 8360:
#0 0x00007f5efaea08f2 n/a (libc.so.6 + 0xa08f2)
#1 0x00007f5efaf119d7 ppoll (libc.so.6 + 0x1119d7)
#2 0x00007f5efa12fc9e n/a (libglib-2.0.so.0 + 0x6ac9e)
#3 0x00007f5efa12fdb5 g_main_context_iteration (libglib-2.0.so.0 + 0x6adb5)
#4 0x00007f5efbac4d22 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x4c4d22)
#5 0x00007f5efb796a74 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x196a74)
#6 0x00007f5efb8c4a02 _ZN7QThread4execEv (libQt6Core.so.6 + 0x2c4a02)
#7 0x00007f5efbd69781 n/a (libQt6DBus.so.6 + 0x38781)
#8 0x00007f5efb978fdb n/a (libQt6Core.so.6 + 0x378fdb)
#9 0x00007f5efae98042 n/a (libc.so.6 + 0x98042)
#10 0x00007f5efaf2072c n/a (libc.so.6 + 0x12072c)
Stack trace of thread 8373:
#4 0x00007f5efbac4d42 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x4c4d42)
#7 0x00007f5efb979075 n/a (libQt6Core.so.6 + 0x379075)
#8 0x00007f5efae98042 n/a (libc.so.6 + 0x98042)
#9 0x00007f5efaf2072c n/a (libc.so.6 + 0x12072c)
Stack trace of thread 8363:
Stack trace of thread 8375:
#0 0x00007f5efaf1e46d syscall (libc.so.6 + 0x11e46d)
#1 0x00007f5efa15dbde g_cond_wait (libglib-2.0.so.0 + 0x98bde)
#2 0x00007f5efa0eb4ad n/a (libglib-2.0.so.0 + 0x264ad)
#3 0x00007f5efa164027 n/a (libglib-2.0.so.0 + 0x9f027)
#4 0x00007f5efa161b54 n/a (libglib-2.0.so.0 + 0x9cb54)
#5 0x00007f5efae98042 n/a (libc.so.6 + 0x98042)
#6 0x00007f5efaf2072c n/a (libc.so.6 + 0x12072c)
Stack trace of thread 8389:
#1 0x00007f5efae94c79 n/a (libc.so.6 + 0x94c79)
#2 0x00007f5efae974ec pthread_cond_wait (libc.so.6 + 0x974ec)
#3 0x00007f5ec662744e n/a (libgallium-26.2.6-arch1.1.so + 0x62744e)
#4 0x00007f5ec65dc6bd n/a (libgallium-26.2.6-arch1.1.so + 0x5dc6bd)
#5 0x00007f5ec662738d n/a (libgallium-26.2.6-arch1.1.so + 0x62738d)
#6 0x00007f5efae98042 n/a (libc.so.6 + 0x98042)
#7 0x00007f5efaf2072c n/a (libc.so.6 + 0x12072c)
Stack trace of thread 8374:
#4 0x00007f5efa12fe02 n/a (libglib-2.0.so.0 + 0x6ae02)
#5 0x00007f5efa161b54 n/a (libglib-2.0.so.0 + 0x9cb54)
Stack trace of thread 8382:
#3 0x00007f5efb97f981 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt6Core.so.6 + 0x37f981)
#4 0x00007f5efdec399e n/a (libQt6Quick.so.6 + 0x4c399e)
#5 0x00007f5efb978fdb n/a (libQt6Core.so.6 + 0x378fdb)
Stack trace of thread 8390:
Stack trace of thread 8361:
#4 0x00007f5efc8529b7 n/a (libQt6WaylandClient.so.6 + 0x709b7)
Stack trace of thread 8370:
Stack trace of thread 8385:
Stack trace of thread 8376:
#3 0x00007f5efa12ff77 g_main_loop_run (libglib-2.0.so.0 + 0x6af77)
#4 0x00007f5ef5833b64 n/a (libgio-2.0.so.0 + 0x121b64)
Stack trace of thread 8362:
#1 0x00007f5efaf112e5 __poll (libc.so.6 + 0x1112e5)
#2 0x00007f5efc852a18 n/a (libQt6WaylandClient.so.6 + 0x70a18)
#3 0x00007f5efb978fdb n/a (libQt6Core.so.6 + 0x378fdb)
#4 0x00007f5efae98042 n/a (libc.so.6 + 0x98042)
#5 0x00007f5efaf2072c n/a (libc.so.6 + 0x12072c)
Stack trace of thread 8377:
#2 0x00007f5efae97702 pthread_cond_timedwait (libc.so.6 + 0x97702)
#3 0x00007f5efb97f8e9 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt6Core.so.6 + 0x37f8e9)
#4 0x00007f5efb8c1845 n/a (libQt6Core.so.6 + 0x2c1845)
Stack trace of thread 8383:
Stack trace of thread 8371:
Stack trace of thread 8384:
Stack trace of thread 8386:
Stack trace of thread 8391:
Stack trace of thread 8387:
Stack trace of thread 8388:
When enabling the debuginfod, gdb itself crashed.
/usr/include/c++/16/string_view:291: constexpr const std::basic_string_view<_CharT, _Traits>::value_type& std::basic_string_view<_CharT, _Traits>::back() const [with _CharT = char; _Traits = std::char_traits<char>; const_reference = const char&]: Assertion 'this->_M_len > 0' failed.
Fatal signal: Aborted
----- Backtrace -----
Reading symbols from /usr/lib/libSvtAv1Enc.so.4...
0x56231a4a0481 ???
0x56231a6341ed ???
0x7f4a46e3e6ef ???
0x7f4a46e9a11c ???
0x7f4a46e3e5cf gsignal
0x7f4a46e25684 abort
0x7f4a4729d5bc _ZSt21__glibcxx_assert_failPKciS0_S0_
0x56231a2e7f73 ???
0x56231a30257d ???
0x56231a584638 ???
0x56231a58372a ???
0x56231a5834b5 ???
0x7f4a46e9d79b ???
0x7f4a46e9d818 pthread_once
0x56231afe1e6e ???
0x7f4a472ea858 ???
0x7f4a46e98041 ???
0x7f4a46f2072b ???
0xffffffffffffffff ???
At this point, I am at lost. My last resort would be to create a new account and move the .config file into my account.
EDIT:
I got gdb to work now by reverting my theme, which was Oxygen when I installed plasma-meta, back to Breeze.
quaqom
November 8, 2026, 11:34pm
9
That link doesn’t lead me anywhere.
Where do I set those settings?
Omig
November 8, 2026, 11:49pm
10
Be careful, the link in the post of coldpillar820 above lead me to a site with adult content!
quaqom
November 11, 2026, 7:38am
11
Accidentally deleted my .config in the process of moving .config of the new account into my account. I was expecting plasmashell to work and the desktop and the widgets to come back, but plasmashell still crashed and the desktop and the widgets didn’t.
Here’s the terminal output of plasmashell -n:
Here’s the core dump of plasmashell -n:
PID: 9812 (plasmashell)
TID: 9812 (plasmashell)
Signal: 11 (SEGV) si_code: SEGV_MAPERR
Timestamp: Wed 2026-11-11 12:43:47 PST (2h 54min ago)
Control Group: /user.slice/user-1000.slice/user@1000.service/app.slice/app-org.kde.konsole-4604.scope/tab(4612).scope
User Unit: app-org.kde.konsole-4604.scope
Boot ID: 9ad4e61253a444458c4a86033403b0c0
Hostname: achlys
Storage: /var/lib/systemd/coredump/core.plasmashell.1000.9ad4e61253a444458c4a86033403b0c0.9812.1794372227000000.zst (present)
Size on Disk: 10.4M
Message: Process 9812 (plasmashell) of user 1000 dumped core.
Stack trace of thread 9812:
#0 0x00007f5d25d834c0 _ZN10QQuickItem13setParentItemEPS_ (libQt6Quick.so.6 + 0x1834c0)
#1 0x00007f5d266e2230 _ZN11PlasmaQuick15ContainmentView9setSourceERK4QUrl (libPlasmaQuick.so.8 + 0x44230)
#2 0x00005565ea7918a6 n/a (plasmashell + 0x618a6)
#3 0x00005565ea7b1a52 n/a (plasmashell + 0x81a52)
#4 0x00007f5d239f6cc8 n/a (libQt6Core.so.6 + 0x1f6cc8)
#5 0x00007f5d265b5656 _ZN6Plasma6Corona25containmentUiReadyChangedEPNS_11ContainmentEb (libPlasma.so.8 + 0x38656)
#6 0x00007f5d239f6cc8 n/a (libQt6Core.so.6 + 0x1f6cc8)
#7 0x00007f5d265a8bdb _ZN6Plasma11Containment14uiReadyChangedEb (libPlasma.so.8 + 0x2bbdb)
#8 0x00007f5d265a35a5 n/a (libPlasma.so.8 + 0x265a5)
#9 0x00007f5d239ebe19 _ZN7QObject5eventEP6QEvent (libQt6Core.so.6 + 0x1ebe19)
#10 0x00007f5d24d0355f _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt6Widgets.so.6 + 0x10355f)
#11 0x00007f5d239891d8 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt6Core.so.6 + 0x1891d8)
#12 0x00007f5d23b757b5 _ZN14QTimerInfoList14activateTimersEv (libQt6Core.so.6 + 0x3757b5)
#13 0x00007f5d23cc63a9 n/a (libQt6Core.so.6 + 0x4c63a9)
#14 0x00007f5d2232675e n/a (libglib-2.0.so.0 + 0x6175e)
#15 0x00007f5d2232fc50 n/a (libglib-2.0.so.0 + 0x6ac50)
#16 0x00007f5d2232fdb5 g_main_context_iteration (libglib-2.0.so.0 + 0x6adb5)
#17 0x00007f5d23cc4d22 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x4c4d22)
#18 0x00007f5d23996a74 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x196a74)
#19 0x00007f5d2398cfca _ZN16QCoreApplication4execEv (libQt6Core.so.6 + 0x18cfca)
#20 0x00005565ea75709a n/a (plasmashell + 0x2709a)
#21 0x00007f5d23027781 n/a (libc.so.6 + 0x27781)
#22 0x00007f5d230278b9 __libc_start_main (libc.so.6 + 0x278b9)
#23 0x00005565ea7578c5 n/a (plasmashell + 0x278c5)
Stack trace of thread 9816:
#0 0x00007f5d230a08f2 n/a (libc.so.6 + 0xa08f2)
#1 0x00007f5d231119d7 ppoll (libc.so.6 + 0x1119d7)
#2 0x00007f5d2232fc9e n/a (libglib-2.0.so.0 + 0x6ac9e)
#3 0x00007f5d2232fdb5 g_main_context_iteration (libglib-2.0.so.0 + 0x6adb5)
#4 0x00007f5d23cc4d22 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x4c4d22)
#5 0x00007f5d23996a74 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x196a74)
#6 0x00007f5d23ac4a02 _ZN7QThread4execEv (libQt6Core.so.6 + 0x2c4a02)
#7 0x00007f5d23b79075 n/a (libQt6Core.so.6 + 0x379075)
#8 0x00007f5d23098042 n/a (libc.so.6 + 0x98042)
#9 0x00007f5d2312072c n/a (libc.so.6 + 0x12072c)
Stack trace of thread 9830:
#0 0x00007f5d230a89a8 malloc (libc.so.6 + 0xa89a8)
#1 0x00007f5cfadd001e n/a (libgallium-26.2.6-arch1.1.so + 0x5d001e)
#2 0x00007f5cfadccbe8 n/a (libgallium-26.2.6-arch1.1.so + 0x5ccbe8)
#3 0x00007f5cfaf5c70b n/a (libgallium-26.2.6-arch1.1.so + 0x75c70b)
#4 0x00007f5cfaeacaa2 n/a (libgallium-26.2.6-arch1.1.so + 0x6acaa2)
#5 0x00007f5cfaec79ef n/a (libgallium-26.2.6-arch1.1.so + 0x6c79ef)
#6 0x00007f5cfaca191a n/a (libgallium-26.2.6-arch1.1.so + 0x4a191a)
#7 0x00007f5cfa96f536 n/a (libgallium-26.2.6-arch1.1.so + 0x16f536)
#8 0x00007f5cfa970209 n/a (libgallium-26.2.6-arch1.1.so + 0x170209)
#9 0x00007f5cfa970925 n/a (libgallium-26.2.6-arch1.1.so + 0x170925)
#10 0x00007f5cfa972057 n/a (libgallium-26.2.6-arch1.1.so + 0x172057)
#11 0x00007f5cfa9721cd n/a (libgallium-26.2.6-arch1.1.so + 0x1721cd)
#12 0x00007f5cfac1e8d0 n/a (libgallium-26.2.6-arch1.1.so + 0x41e8d0)
#13 0x00007f5cfabd8259 n/a (libgallium-26.2.6-arch1.1.so + 0x3d8259)
#14 0x00007f5d24606645 n/a (libQt6Gui.so.6 + 0x606645)
#15 0x00007f5d25eb6250 _ZN16QSGBatchRenderer8Renderer19ensurePipelineStateEPNS_7ElementEPKNS_19ShaderManagerShaderEb (libQt6Quick.so.6 + 0x2b6250)
#16 0x00007f5d25ed13ed n/a (libQt6Quick.so.6 + 0x2d13ed)
#17 0x00007f5d25ebc0f7 _ZN16QSGBatchRenderer8Renderer17prepareRenderPassEPNS0_17RenderPassContextE (libQt6Quick.so.6 + 0x2bc0f7)
#18 0x00007f5d25ebdd3d _ZN16QSGBatchRenderer8Renderer6renderEv (libQt6Quick.so.6 + 0x2bdd3d)
#19 0x00007f5d25edc2e1 n/a (libQt6Quick.so.6 + 0x2dc2e1)
#20 0x00007f5d25e68e55 _ZN19QQuickWindowPrivate16renderSceneGraphEv (libQt6Quick.so.6 + 0x268e55)
#21 0x00007f5d260c338f n/a (libQt6Quick.so.6 + 0x4c338f)
#22 0x00007f5d23b78fdb n/a (libQt6Core.so.6 + 0x378fdb)
#23 0x00007f5d23098042 n/a (libc.so.6 + 0x98042)
#24 0x00007f5d2312072c n/a (libc.so.6 + 0x12072c)
Stack trace of thread 9823:
#1 0x00007f5d23094c79 n/a (libc.so.6 + 0x94c79)
#2 0x00007f5d230974ec pthread_cond_wait (libc.so.6 + 0x974ec)
#3 0x00007f5cfae2744e n/a (libgallium-26.2.6-arch1.1.so + 0x62744e)
#4 0x00007f5cfaddc6bd n/a (libgallium-26.2.6-arch1.1.so + 0x5dc6bd)
#5 0x00007f5cfae2738d n/a (libgallium-26.2.6-arch1.1.so + 0x62738d)
#6 0x00007f5d23098042 n/a (libc.so.6 + 0x98042)
#7 0x00007f5d2312072c n/a (libc.so.6 + 0x12072c)
Stack trace of thread 9814:
#1 0x00007f5d231112e5 __poll (libc.so.6 + 0x1112e5)
#2 0x00007f5d24a52a18 n/a (libQt6WaylandClient.so.6 + 0x70a18)
#3 0x00007f5d23b78fdb n/a (libQt6Core.so.6 + 0x378fdb)
#4 0x00007f5d23098042 n/a (libc.so.6 + 0x98042)
#5 0x00007f5d2312072c n/a (libc.so.6 + 0x12072c)
Stack trace of thread 9813:
#7 0x00007f5d23f69781 n/a (libQt6DBus.so.6 + 0x38781)
#8 0x00007f5d23b78fdb n/a (libQt6Core.so.6 + 0x378fdb)
#9 0x00007f5d23098042 n/a (libc.so.6 + 0x98042)
#10 0x00007f5d2312072c n/a (libc.so.6 + 0x12072c)
Stack trace of thread 9815:
Stack trace of thread 9832:
Stack trace of thread 9836:
Stack trace of thread 9824:
Stack trace of thread 9839:
#2 0x00007f5d23097702 pthread_cond_timedwait (libc.so.6 + 0x97702)
#3 0x00007f5d23b7f8e9 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt6Core.so.6 + 0x37f8e9)
#4 0x00007f5d23ac1845 n/a (libQt6Core.so.6 + 0x2c1845)
#5 0x00007f5d23b78fdb n/a (libQt6Core.so.6 + 0x378fdb)
Stack trace of thread 9841:
Stack trace of thread 9843:
Stack trace of thread 9840:
Stack trace of thread 9831:
Stack trace of thread 9842:
Stack trace of thread 9834:
Stack trace of thread 9835:
Stack trace of thread 9838:
Stack trace of thread 9837:
Stack trace of thread 9833:
quaqom
November 12, 2026, 1:38am
12
I need to explore more around the directories. Seems like I viewed every directory in my /home/user. Are there directories outside /home that are specific to a session or user? It might give me pointers to look for faulty config files of plasmashell.
quaqom
November 12, 2026, 4:34am
13
I got it working! The directory that’s problematic is the ~/.local/share/plasma, though that’s the whole directory.
I discovered it by moving .../plasma into a backup directory ~/.local.bak .
I’d like to check which subdirectory inside .../plasma that causes problems by moving each subdirectory into ~/.local.bak.
