Plasma weather plasmoid
Got an error when trying to activate plasma weather in status and notification
file:///usr/share/plasma/plasmoids/org.kde.plasma.weather/contents/ui/main.qml:438:25: Type FullRepresentation unavailable
file:///usr/share/plasma/plasmoids/org.kde.plasma.weather/contents/ui/FullRepresentation.qml:38:24: Cannot assign object of type "QQC2.Action" to property of type "Action_QMLTYPE_124*" as the former is neither the same as the latter nor a sub-class of it.
If I delete these files, does plasma restore them automatically?
Does anyone know what should be in the lines?
I just tried it out and get the same error on mine.
EDIT was just about to ask on kde forum but see you are one step ahead of me
https://bugs.kde.org/show_bug.cgi?id=488907
@smokey A small step quicker :rofl: Thank you anyways :enos:
Thanks @Stefax2001 thats it. Then let’s wait for the bug to be fixed
My knowledge (and understanding) is very basic and I know you are asking specifically about that. I personally got that bug and then it got fixed I assumed after I updated.
However, if you check the bug tracker on the original (not duplicate) others have mentioned other problems and they all seem to be related to “Kirigami”.
My issue is after updating, if you go into settings, you have that QML error and cannot load some settings. Some old responses said to “install kirigami” but funnily enough, I have all of those installed.
I am afraid of deleting those and breaking the whole system, so I just reinstall without removing and it fixes it. I guess we’ll just have to wait until they fix it :smiley:
got an answer on KDE Forum
It seems org.kde.plasma.extras is no longer compatible with QtQuick.Controls Action
So those PlaceholderMessage should be ported to Kirigami.PlaceholderMessage
I see. Where and how would we report that? Or can we simply “wait until they fix it”? :rofl:
I actually just wanted to try out a new weather widget. Plasma weather does not work so now I use weather widget 3 I would never have realized that there was a issue
I wouldn’t have noticed if you didn’t ask which made me try it out
on the kde bug list @Stefax2001 gives us
I wasn’t completely satisfied with the wunderground widget. That’s the only reason i came across it
In reference to Nate’s post on kdebugs:
Nate Graham 2024-06-21 19:03:26 UTC
Can you please make a backup of ~/.cache? After that, you can delete the contents of that folder, which will fix the issue.
Delete content of ~./cache then reboot.
This didnt fix it for me.
@smokey, do you have time to reproduce this again?
I will give it a go now. Get back to you shortly.
OK so I managed to get it working by enabling it, then deleting the cache and logging out than back in
That’s exactly what I’m going to try now.
I switched it off, deleted the cahe, restarted it, activated it and the error was still there. see you soon
Yer the first time I tried it I had the weather disabled and it didn’t work but when I did it with it enabled it did
Thats it @smokey , you’re my hero tonight :heart:
It worked by enabling first then delete the cache.
Your welcome, at least I was able to solve one puzzle today
And that was the most important puzzle today. Without you, I wouldn’t have a weather forecast but would have to look out of the window :rofl:
