Some of the widgets give me errors saying “Error loading QML file:” or the like. In this particular instance, a box is popping up with the output below. Is there a depencie package or something I need to add?
Error loading QML file: file:///home/h0b0/.local/share/plasma/plasmoids/rss_indicator/contents/ui/main.qml:21:37: Type CompactRepresentation unavailable
file:///home/h0b0/.local/share/plasma/plasmoids/rss_indicator/contents/ui/CompactRepresentation.qml:55:5: Type FullRepresentation unavailable
file:///home/h0b0/.local/share/plasma/plasmoids/rss_indicator/contents/ui/FullRepresentation.qml:5:1: module “QtQuick.XmlListModel” is not installed
Do you mean the KDE store? I look there but the search box doesn’t seem to work correctly. Typing in RSS results in “no results found”
Tried the following while in a Google chase:
yaourt -Syy qml-module-qtquick-xmllistmodel
sudo pacman -S --needed libxcb xcb-proto xcb-util xcb-util-image xcb-util-wm libxi~
import QtQuick.XmlListModel 2.0
Be careful using downloads from the KDE Store, it is full of old and abandoned user created widgets and themes that may or may not work. Always check activity first.
Qt5-quick is it mostly but there is 2 and 3d idk. Pacman -Ql | grep qtquick
Can local some pieces. Qt5 does contain also qml bit there is less a packages with qm. Sometimes some libs can be found with pkgfile if it has the same libs as example…
