Plasma features missing
On kde I notice alternate calendars is missing from default digital clock settings and weather report is missing from system tray entry how do I get those?
Welcome to the forum!
Do you have the package kdeplasma-addons installed? If not, install that.
Is it sudo pacman -S plasma-addons?
No, it’s
sudo pacman -S kdeplasma-addons
Thank you
If you want to get web calendar events to show up in the widget you’ll also need to install kdepim-addons
