Plasma 6.8
There’s a bug related to color scheme
Anyone tried the Oxygen theme in Plasma 6.8?
Unfortunately, I can’t share everyone’s joy… With the latest KDE updates, two applications that I use very often have been killed - Yakuake and CopyQ. There are no alternatives.
:worried:
Works fine here.
And what, it opens on any desktop and not on the one on which it was launched for the first time?
I’ll clarify - Wayland.
Does it follow the mouse?
I didn’t quite understand the question, sorry
Is the screen it opens on the one with the mouse pointer on it. That’s how things seem to work for me in general.
No. It opens in the window where it was launched for the first time. That is, if I open Yakuake in window 1 and then try to do it in window 3, then I am “thrown” into window 1 and opens there.
You mean Virtual Desktops? Create a Window Rule and force it on all Desktops.
Yes, virtual tables. What property rule should I create?
I don’t use yakuake but a quick search suggests it should do that since 5.24. There was a suggestion:
System Settings → Window Management → Window Behaviour → enable Separate screen focus.
This setting helps manage which screen is active based on mouse position.
Edit: Ah virtual desktops, not monitors.
Yes
Does not work. Neither on the main system, nor in a virtual environment
Works here. Just to be sure try a logout and login.
Does not work. It’s been two weeks now.
Запись экрана_2026.10.16_13.49
But you didn’t have the Window Rule for two weeks? All I can say is it works here.
I tried the rule as soon as I noticed this behavior. And a few other options. Nothing worked. And it’s not just me who has this behavior…
Same behavior with CopyQ
Does it happen with a new user?
