PLANK - Get to Settings Quickly
Plank veteran users probably already know this. But I’ve seen a lot of posts on various Linux forums regarding difficulties getting to Plank’s settings in order to change themes, position, size, and so on. For those unaware, there’s a way to get to Plank settings quickly. A simple ctrl -> right-click. Alternatively, you can run plank --preferences in terminal.
plank --preferences (:47) has always worked for me. :01-:46 I learned something, thank you.
I didn’t know that one. Yep… I learned something, too.
Added to description on YouTube video. Thanks.
Using Plasma I was messing around, and added the terminal command to a quick launch widget. It works like a charm.
