I have the latest version of VS Code and Gnome installed.
Weirdly enough, when opening all directories from the Places menu on the top-left, it opens in VS Code instead of the file manager.
How could I fix this?
This is happening in your ~/.config/mimeapps.list
Change the inode/directory
and inode/symlink
to use the file manager.
I don’t recall the exact name but it is something like org.gnome.Nautilus.desktop
but you can verify by listing
ls /usr/share/applications/org.gnome*
Worked perfectly! Though there wasn’t any inode/symlink but only /directory.
Should I add the line or what’s the difference?
