New install on an Asus GL753VE (used as a workstation because of broken internal screen)
I went for Plasma (for the first time in my life!). Everything vital works out of the box!! Very impressive I must say!!
I have only one problem. It is not possible to import keys when I install from aur and I have tried 5-10 packages so I suspect something is wrong!
Hi and thanks for answering!
I just installed Endeavour OS on this laptop (used as a workstation with external screen and external keyboard.)
I want to install linux-ck kernel and when I add repo I have to import their pacman-key.
“pacman-key -r 5EE46C4C && pacman-key --lsign-key 5EE46C4C
gpg: fetching from keyserver failed”
Same thing happens with some other packages too. As a matter of fact I haven’t been able to import one single key on this system yet!
I usually go with Openbox so I have no experience of Plasma at all. (Very beautiful though!) Is there something with Plasma and keys?
For me it doesn’t work that solution, I have problems with importing keys for Spotify and Dropbox. Any other solution possible ? Or maybe I have forgotten something ?
I don’t know about dropbox (it installed over here), but Spotify has been flagged out of date for three weeks now, so that might be the problem. You can try spotify-dev.
And then adding the key after that, and that worked for me. And then installing the package. Probably not the most beautiful way, but it is a solution, hopefully temporary.
Hello all…
I have looked and looked…Followed links…Checked wikis…Updated…Not updated…And basically tried anything and everything I could think of…
I am a once and probably future user of Endeavour…Currently using a vanilla XFCE off an ISO by EZARCH…
The problem was the same on Endeavour…So I hope someone has a solution here…
The problem…
PGP keys need importing:
-> EA0A77BF9E115615FC3BD8BC7653B940E494FE87, required by: mullvad-vpn
==> Import? [Y/n]
:: Importing keys with gpg…
gpg: keyserver receive failed: General error
problem importing keys
Again…I have tried…No luck yet…
Any help would be greatly appreciated…
Recognizing that in the world we are currently living this is a tiny problem…
Peace and health to all…
No this is not solved!
I managed to import keys for linux-ck but I have had problems after that !
This is not an Endeavour OS problem!!
All Arch-distros (that I know of!) have this problem and it seems like there are too many solutions right now!! (but no permanent one!) Do not give up this great distro (with a wonderful community) yet!!
My guess is that is has to do with key-servers.
@brandent
Thank you for the quick reply…Much appreciated…
I haven’t abandoned Endeavour, just as is my wont, taking side trips…
It is a wonderful community…
Time fixes everything…Or not… Hahaha
Thanks …
Peace and health…
