Yes, I have tried installing both xow and xow-git via paru as well as manually by cloning the github page and running make.
This made no difference.
I meant that I have tried installing both AUR packages, as well as attempted a manual build/install following the instructions in the xow repo, leaving the AUR out of the process.
Neither method has worked so far. This is a new OS installation and I have not altered permissions.
ls -l ~/.cache/paru/clone/xow-git/pkg/
total 0
drwxr-xr-x 1 celty celty 0 Dec 28 09:36 xow-git
I own the files, yet the error persists. I’m not familiar with tmpfs. I have one disk with btrfs and snapper subvols i.e.
nvme0n1 259:2 0 232.9G 0 disk
├─nvme0n1p1 259:3 0 300M 0 part /boot
├─nvme0n1p2 259:4 0 8G 0 part [SWAP]
└─nvme0n1p3 259:5 0 224.6G 0 part /var_log
/home
/.snapshots
No other modifications have been made. I’m not sure what I’m looking for in the mount output, but there are mentions of tmpfs.
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,nr_inodes=1048576,inode64)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=1635304k,nr_inodes=408826,mode=700,uid=1000,gid=1000,inode64)
Full output:
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
sys on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
dev on /dev type devtmpfs (rw,nosuid,relatime,size=8110804k,nr_inodes=2027701,mode=755,inode64)
run on /run type tmpfs (rw,nosuid,nodev,relatime,mode=755,inode64)
efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
/dev/nvme0n1p3 on / type btrfs (rw,noatime,compress=zstd:3,ssd,space_cache=v2,subvolid=256,subvol=/@)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
none on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=19568)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
/dev/nvme0n1p3 on /.snapshots type btrfs (rw,noatime,compress=zstd:3,ssd,space_cache=v2,subvolid=258,subvol=/@snapshots)
/dev/nvme0n1p3 on /home type btrfs (rw,noatime,compress=zstd:3,ssd,space_cache=v2,subvolid=257,subvol=/@home)
/dev/nvme0n1p3 on /var_log type btrfs (rw,noatime,compress=zstd:3,ssd,space_cache=v2,subvolid=259,subvol=/@var_log)
**tmpfs on /tmp type tmpfs (rw,nosuid,nodev,nr_inodes=1048576,inode64)**
/dev/nvme0n1p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
net_cls on /sys/fs/cgroup/net_cls type cgroup (rw,relatime,net_cls)
//192.168.1.253/D2/ on /mnt/D2 type cifs (rw,relatime,vers=3.0,cache=strict,username=MAIN,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.1.253,file_mode=0777,dir_mode=0777,iocharset=utf8,soft,nounix,serverino,mapposix,noperm,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1)
//192.168.1.253/D1/ on /mnt/D1 type cifs (rw,relatime,vers=3.0,cache=strict,username=MAIN,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.1.253,file_mode=0777,dir_mode=0777,iocharset=utf8,soft,nounix,serverino,mapposix,noperm,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1)
//192.168.1.253/D3/ on /mnt/D3 type cifs (rw,relatime,vers=3.0,cache=strict,username=MAIN,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.1.253,file_mode=0777,dir_mode=0777,iocharset=utf8,soft,nounix,serverino,mapposix,noperm,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=10
00,group_id=1000)
