Hello,
I have had this issue for a few months, my PC is setup to sleep after 15 minutes of inactivity but it will inconsistently freeze instead of going to sleep. I have not figured out what makes it freeze so I can’t reproduce this, it just happens sometimes.
There is no output to screens, mouse and keyboard don’t seem to do anything (Numlock light stays on when I hit the key), can’t connect with ssh, REISUB doesn’t have any effect. I have to hold the power button to shutdown and reboot.
Here are some logs : inxi output, journalctl -b -1.
On this last log, sleep was supposed to be around 03:55 when there are the amdgpu errors (during those errors, power consumption dips about 50 W then goes back up after the log ends, then power becomes almost constant (+/- 0.5W) 7 minutes after that).
I update about once a week.
What can I do to diagnose the issue and resolve it ?
Thank you.
avril 13 13:11:05 <filter>-2025 kernel: Secure boot enabled
You need to disable secure boot in the bios.
Thank you, I thought I disabled it to install the OS but wouldn’t have thought to disable it for this problem anyway.
Hope that fixes your issue. Secure boot should be off anyway.
Hi @Stormweaker
Just had a look at your logs and I don’t think Secure Boot is the culprit here — your actual problem shows up around 03:55 when the system tried to sleep:
amdgpu: device lost from bus!
amdgpu: SMU: response:0xFFFFFFFF
Your RX 9070 XT is basically falling off the PCIe bus during suspend, and then the GPU’s power management chip stops responding entirely — hence the hard freeze.
There’s also this warning already at boot:
SMU driver if version not matched (driver expects 0x2e, GPU firmware is 0x33)
You own a very new GPU and the amdgpu driver is still catching up, especially around suspend/resume.
A few things you can try:
- Add
amdgpu.runpm=0 to your kernel parameters as a workaround (disables GPU runtime power management)
- Keep an eye on kernel updates — RDNA 4 fixes are landing fast
- For now you might just want to disable sleep entirely until a fix arrives
Also worth reporting on the AMD bugtracker with these logs, other 9070 XT users will thank you!
Good luck
Thank you, you’re right, I disabled sleep and got the same issue with the same errors in log.
I’ll try the kernel parameter (I’ll need to read more, editing /etc/kernel/cmdline didn’t change add the parameter after reboot EDIT : managed to add the kernel parameter, I edited /efi/loader/entries/kernel.conf).
Is this the bugtracker where I should report the issue ?
EDIT : problem also appears with amdgpu.runpm=0
