When I install EOs with Calamares using the automated defaults (Btrfs), “endeavouros” is set as the label and also as the partition name for the root partition. Because I don’t want to see this later in the file manager, I have to boot into live mode again after the installation to change these labels (usually with the names “root” or “System”).
Why isn’t it called “root” right away, I’m worried that changing it later could have consequences. The UUID is used as the identifier for mounting, but who knows …
Thanks @dalto , this explanation helps me and the reason for the naming is also understandable to me. I will certainly try out the possibility of changing the config.
One more question in this context: Does it matter in any way if there are capital letters in the label of a partition, e.g. “System” or “Root”, or should this be avoided?
