Thought for a brief time that the issue might be the KDE plasma DE as the few OS’s I tried to install were running Plasma.
Attempted install of Manjaro XFCE also failed – I suspect it also starts install with Calamares.
Now on a search for a linux OS that does not use calamares…
The recommendation to delete dev/nvme0n1p7 was done both with that partition empty, unallocated and then shrunk to remove it from the partition list.
Further OS install attempts with Arch failed several times.
Could not strap in packages: [‘/usr/bin/pacstrap’, ‘-C’, ‘/etc/pacman.conf’, ‘-K’, ‘/mnt/archinstall’,‘base’,‘base-devel’, ‘linux-firmware’, ‘linux’, ‘amd-ucode’
warning: could not get file information for boot/amd-ucode.img
error: Partition /mnt/archinstall/boot too full:
This was a working computer for previous last several months with an install of Windows OS, Manjaro, and Endeavouros—considering erasing installed 512 GB drive, losing data, and then build back-up to only my linux OS’s
