eosbtw
1
For example, how can I extract just leafpad out of
/usr/share/applications/leafpad.desktop
I would like to account for not just /usr/share/applications/ but also for ~/.local/share/applications.
The best I could come up with is to use a combination:
echo ${selected##*/} | cut -d '.' -f1 (where selected is in the context of the code below)
#!/usr/bin/bash
desktop_file() {
fd . -H -e .desktop /usr/share/applications "$HOME/.local/share/applications"
selected="$(desktop_file | sort | fzf --reverse)"
[ -z "$selected" ] && exit
cd || return
echo ${selected##*/} | cut -d '.' -f1 | tr '[:upper:]' '[:lower:]' | xargs -I{} setsid -f bash -c "{}"
Source: bits taken from here
(The tr bit is because of Alacritty.)
basename /usr/share/applications/leafpad.desktop .desktop
dalto
3
#!/usr/bin/env bash
MYPATH=/usr/share/applications/leafpad.desktop
NAME=$(basename ${MYPATH} .desktop)
echo "$NAME"
This won’t remove the .desktop suffix if I’m right
dalto
5
You are right, I didn’t read it carefully enough. Fixed.
manuel
6
Maybe first we need to know exactly what the OP wants to do…
eosbtw
7
I’ve given the entire script. It’s an application launcher with .desktop files as the source.
manuel
8
Do you want to extract the app name from the name of the desktop file, or from the contents of the desktop file?
eosbtw
9
Just from the name of the .desktop file, not from the contents.
manuel
10
OK, then basename is your command.
dalto
11
Be aware that desktop files can also look like this:
okularApplication_powerpoint_calligra.desktop
org.strawberrymusicplayer.strawberry.desktop
eosbtw
12
Yes! I have /usr/share/applications/org.pwmt.zathura.desktop and that’s a problem.
So back to the drawing board
$ basename /usr/share/applications/org.pwmt.zathura.desktop .desktop
org.pwmt.zathura
Is this output not what you expect?
dalto
14
If you just want the name, I agree with @manual that extracting it out of the desktop file is a better solution.
manuel
16
Something like this:
cat /usr/share/applications/xed.desktop | grep ^Exec= | head -n1 | cut -d'=' -f2 | awk '{print $1}'
manuel
17
But even the above may not be optimal if there are many Exec= lines, or quotes used…
eosbtw
18
Yes, and there are the options like xed --new window and field codes (%F, %U, etc).
Overall too many possibilities
manuel
19
The above already handles some problems, try it and see.
eosbtw
20
And I just saw there is
/usr/share/applications/org.gnome.FileRoller.desktop:TryExec=file-roller
