what Desktop is in use? package build should have installed desktop files and it should show up on menu… but not as “pamac” its called System Software Install or something… in case you will need to reboot to have it in the menu…
Thank you all for your advice. I ran pamac-manager and the pamac gui started. After closing it, the menu icon also appeared Add/Remove Software.
I use KDE and I switched back from Cachyos, which works with Octopi/paru
I read that gui package managers using packagekit as backend (discover, gnome software) cause problem on Arch.
Problem with pamac is that things in Arch repos and dependencies of pamac from AUR can update at different times and it can break pamac temporarily.
No that’s just someone espousing that view but it’s not necessarily true. I agree with both @UncleSpellbinder and @cactux
I also use it btw and yes it can get broken at times. But it doesn’t bother me as it’s only a tool i use periodically so it’s not an essential package that is needed to run EOS.
