Yes, youād be hard pressed to tell the original and this one apart in an ID lineup ![]()
New version is out: v1.6.12
The āInstalledā column has been polished a bit.
A check-mark glyph is not used instead of āYā to indicate an installed package.
Also there are glyphs for a couple of UI elements such as āSettingsā, āPkgbuildā, etc.
There are a couple of different styles to choose from.
You can also customize them yourself if you want.
In case those glyphs canāt be displayed properly, switch to āASCIIā to use the traditional āYā / ā-ā characters.
Very nice app/utility! Finally tried it, theming deserved a screenshot in the show my desktop. Love that it can seek and find AUR packages and can check the PKG build on the fly
This should be fixed in v1.6.14 btw:
I LOVE!!! ctr + u function of this
So simple and easy.
I havenāt read the whole thread here, but what are the steps to make this open up as default when I open terminal??
Not sure why youād want to do that. pacseek comes with a .desktop/launcher file already. ![]()
So you can just run pacseek from the menu instead.
If you really want to do this, just add it to your .bashrc or .zshrc or whatever shell youāre using⦠![]()
I honestly thought I had to start it every time through terminal. Teaches me about skimming roughly through the threads ![]()
All right.
New version again.
v1.7.1
This time we got RSS feed support implemented.
The āupgrades screenā now shows the latest Arch announcements.
The URL is configurable and you can even specify multiple ones (separate with semicolon) to combine different RSS feeds.
Tip: You can configure it to retrieve posts from this Forum as well:
For example, all postings in the āImportant notificationsā category:
https://forum.endeavouros.com/c/important-notifications.rss
Or in āAnnouncementsā
https://forum.endeavouros.com/c/announcements.rss
Or why not both ![]()
https://forum.endeavouros.com/c/important-notifications.rss;https://forum.endeavouros.com/c/announcements.rss
And if you get annoyed, just switch things off ![]()
I hereby declare Pacseek to be the Official Package Manager of EndeavourOSā¦on my computer. ![]()
Iāve got the latest version but i donāt see this feature?
Edit: Do you have to open the settings and change the url to get this?
Edit2: I guess i donāt have the latest. Yet!
aur/pacseek 1.7.1-1 (+19 5.51) (Installed: 1.6.15-1)
A terminal user interface for searching and installing Arch Linux packages
Is installed i think? What is
ctrl +G
Okayā¦i figured it out. Thanks!
this real nice , so
@moson only prob is remember it there
muscle memory/habit is terminal + yay.
i just now set keybind for open . hope this help me remember ( time tell) still it great you build this
While I am a fan of working from the command lineā¦
I really like this little program even though I do use the command line, I just wish that the installer would completely remove the go folder when it completes the update or install.
Is it possible to use this with tilix instead of gnome terminal?
I think you can start it in terminal $ pacseek
Actually looks pretty good started in the Guake drop down terminalā¦
Hmm. yeah that is actually the default GOPATH where it downloads any libraries to during compilation.
Now I should probably override it with something residing in $srcdir instead.
edit: Done
Alternatively you can also choose the pacseek-bin package which delivers the binary ootb so you wonāt even need to compile at all.
It should work in pretty much every modern terminal emulator I think.
Or are you referring to the launcher? In that case you might either want to change your default terminal app to tilix, or you override the launcher by placing it in .local/share/applications/ and adjusting the lines Exec / Terminal
For example
[Desktop Entry]
Name=pacseek
Comment=A terminal user interface for searching and installing Arch Linux packages
Icon=pacseek
Type=Application
Categories=Utility;
Keywords=terminal;package;
Exec=tilix -e "pacseek"
StartupNotify=false
#Terminal=true
