Today the new pacman update and the new Yay update hit the repo, it, however, breaks the dependency of Kalu.
Our advice is to uninstall Kalu and perform the pacman and YAy update. For now, use the terminal commands (pacman or Yay) for checking updates. We are working on another update-notifier.
There’s no hurry, know Joe and Manuel are running it for quite some time now and from what I can see until right now it seems to be working. But just need a some more hours and updates before we release it to everyone.
The package is called eos-update-notifier. It is already in the repos, so you may install it like any other package. A reboot is recommended after installing it.
It is a systemd service for the current user, and to see it is running, give a command
systemctl --user status eos-update-notifier.timer
It checks for updates soon after login. Afterwards it checks for updates after every two hours.
In addition, it also checks if there are any Arch news that may affect your machine, i.e. are related to the software you have currently installed in the machine. Note that this feature is usually able to show the relevant news, but sometimes it doesn’t. The reason is in the simple ad hoc method how the news are checked. So, to be on the safe side, it is still a good idea to check the Arch news (https://www.archlinux.org/news) with a browser at times.
DISCLAIMER: this piece of software is already tested but still quite new, so there may be issues. If you find a problem, please report it in the Bug reports area.
Unable to install yay as it says signature from “EndeavourOS info@endeavouros.com” is unknown trust. Managed to update everything except yay.
Edit: Now I’m getting errors with signature trying to install eos-update-notifier.
