When installing, the installer crashed towards the end of the install, siting the error “bad main script file”. It seems that it somehow made the /tmp/calamares-root-ipi9jfp2/efi/EFI/Microsoft directory read only. I used Rufus to burn the ISO to my thumb drive, and I was installing it to the same drive that had Windows on it.
I retried using grub2 bootloader selected, and it finished the install. However, when I rebooted, it still booted into windows. I will check the bios to see if it has the endeavouros boot detected.
edit: it is not there.
however, I did not have all the security boot options disabled, as well as CSM.
Now I see the boot option, but it fails to boot it.
To install EndeavourOS on an EFI System it is always recommended to use EFI boot mode and not the legacy CSM mode.
If you have to us ethat Bios/legacy/CSM Mode to boot, it is recommended to go for GPT partition Scheme and teh 8MB empty partition flagged as bios-grub.
EXTRA INFO: I do have an RTX 2060, and I don’t know if that classifies as the “newer” nvidia cards.
this is supported by latest Nvidia, to check you can use this webside:
Or nvidia-driver-supported-branches from a terminal on ISO live boot.
