I just installed htop yesterday and have been watch nothing seems out of the ordinary but will keep monitoring to see thanks
Fwiw, you might want to add -z to your command:
-z, --filter Adds security filters for IP/MAC addresses, serial numbers,
location (-w), user home directory name, host name.
Sorry! Of course I do not mean anything but I will take note. This is how I found it somewhere here.
I will change to:
inxi -FAZ --no-host | eos-sendlog
which I got from A friendly intro about our community rules and tips for the forum
Host: Aurorar-12 Kernel: 6.4.7-arch1-3 arch: x86_64 bits: 64 Desktop: GNOME
v: 44.3 Distro: EndeavourOS
Type: Desktop System: Alienware product: Alienware Aurora R12 v: 1.1.19
serial:
Mobo: Alienware model: 07W25T v: A01 serial:
UEFI: Alienware v: 1.1.19 date: 12/20/2022
Info: 8-core model: 11th Gen Intel Core i7-11700F bits: 64 type: MT MCP
cache: L2: 4 MiB
Speed (MHz): avg: 2614 min/max: 800/4800:4900 cores: 1: 2500 2: 4337
3: 2500 4: 2500 5: 2500 6: 2500 7: 2500 8: 2500 9: 2500 10: 2500 11: 2500
12: 2500 13: 2500 14: 2500 15: 2500 16: 2500
Device-1: NVIDIA GA104 [GeForce RTX 3070 Lite Hash Rate] driver: nvidia
v: 535.86.05
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2 driver: X:
loaded: nvidia unloaded: modesetting gpu: nvidia,nvidia-nvswitch resolution:
1: 3440x1440 2: 3840x2160
API: OpenGL v: 4.6.0 NVIDIA 535.86.05 renderer: NVIDIA GeForce RTX
3070/PCIe/SSE2
Device-1: Intel driver: snd_hda_intel
Device-2: NVIDIA GA104 High Definition Audio driver: snd_hda_intel
API: ALSA v: k6.4.7-arch1-3 status: kernel-api
Server-1: PipeWire v: 0.3.76 status: active
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi
IF: wlan0 state: down mac: 02:24:58:2c:ea:71
Device-2: Realtek Killer E3000 2.5GbE driver: r8169
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: 30:d0:42:fe:6f:10
Bluetooth:
Device-1: Intel AX201 Bluetooth driver: btusb type: USB
Report: rfkill ID: hci0 state: up address: see --recommends
Local Storage: total: 12.76 TiB used: 73.66 GiB (0.6%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: PC711 NVMe 1TB size: 953.87 GiB
ID-2: /dev/sda vendor: Western Digital model: WD8002FRYZ-01FF2B0
ID-3: /dev/sdb vendor: Samsung model: SSD 870 QVO 4TB size: 3.64 TiB
ID-4: /dev/sdc vendor: Samsung model: SSD 860 QVO 1TB size: 931.51 GiB
ID-1: / size: 3.58 TiB used: 73.39 GiB (2.0%) fs: ext4 dev: /dev/sdb2
System Temperatures: cpu: 37.0 C pch: 32.0 C mobo: N/A gpu: nvidia
temp: 59 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 0%
Processes: 326 Uptime: 2h 33m Memory: total: 16 GiB note: est.
available: 15.3 GiB used: 2.35 GiB (15.4%) Shell: Bash inxi: 3.3.28
Hi @kcmccombs
I see your machine is OK. You have more than enough.
The only thing that maybe causing issues is NVIDIA graphic cards as far as I read here. But as I mentioned earlier I am no expert by any means and never tried NVIDIA. So I leave this to the experts here, maybe they can add something.
Well, for the DE you chose (Gnome), I do not know if there is a problem with it. I am using KDE Plasma and never had an issue with it.
It appears to me you can simply do a reinstall of EndeavourOS.
I put myself in your place, if I were you I would reinstall but with KDE Plasma, maybe it will work fine.
My limited knowledge and experience tells me:
- the only reason for freezing maybe the NVIDIA graphics card
- KDE Plasma might work better perhaps.
- I noticed
which is not supposed to be too much data being indexed.
This is all what I can say!
Hopefully someone more experienced than me can help.
Yeah I like KDE I went with gnome because of the way dock is set in the center wasn’t sure if I could do that with KDE thanks for all your input if I continue having issues I may give KDE a try
Just my 2 cents. Most here are on KDE Plasma for many reasons (you may search and read about it). I am not saying no to Gnome or yes to KDE Plasma, it is a personal taste.
I am sure you will enjoy anyway.
