I am new to linux(just changed from windows 10 week ago). I am a student currently learning oracle sql. I want to install oracle sql on my endeavourOS.
I read arch wiki for installation of oracle-xe but in the comments saying not working.
I tried instaling oracle 19c through runinstaller and it is showing this error
error while loading shared libraries: libcrypt.so.1: cannot open shared object file: No such file or directory
I want to install 19c or express edition if possible.
How did you try to install it? Did you try to install oracle-xe (Oracle Express Edition) from AUR ? Which instruction on the Wiki did you follow?
Difficult to help without information.
I wouldn’t continue, because prerequisites will not be checked.
Where and which installer did you download (Link ?)? I could only find rpm packages for Linux. Maybe I missed something.
Nevertheless, I would try to install Oracle Express Edition from AUR. yay -S oracle-xe should do the job. It’s version oracle-xe 18.4.0.0.0-1. Installation worked here, but I didn’t test it.
