Optimus-manager
Easy peasy then :smirk: you can mark the thread as solved, whichever post you think solved your problem. So that someone finds easily the answer in the future.
XD im so dumb
I don’t think so. You just gained knowledge how to switch from Wayland and xorg, and that hybrid graphics work generally better on xorg.
Some useful info to learn more with time…https://wiki.archlinux.org/title/wayland
<3
this was the solution
and not this
Edit: just in case others should use this solution
You should try Envycontrol, it is simple af and plays nicely with GNOME. You also won’t have to replace GDM with GDM Prime.
