Have you tried it @ 120Hz instead of 144Hz.
Yep still the same
What does xset q show for monitor settings.
Keyboard Control:
auto repeat: on key click percent: 0 LED mask: 00000002
XKB indicators:
00: Caps Lock: off 01: Num Lock: on 02: Scroll Lock: off
03: Compose: off 04: Kana: off 05: Sleep: off
06: Suspend: off 07: Mute: off 08: Misc: off
09: Mail: off 10: Charging: off 11: Shift Lock: off
12: Group 2: off 13: Mouse Keys: off
auto repeat delay: 600 repeat rate: 25
auto repeating keys: 00ffffffdffffbbf
fadfffefffedffff
9fffffffffffffff
fff7ffffffffffff
bell percent: 50 bell pitch: 400 bell duration: 100
Pointer Control:
acceleration: 2/1 threshold: 4
Screen Saver:
prefer blanking: yes allow exposures: yes
timeout: 0 cycle: 600
Colors:
default colormap: 0x20 BlackPixel: 0x0 WhitePixel: 0xffffff
Font Path:
built-ins
DPMS (Energy Star):
Standby: 0 Suspend: 0 Off: 0
DPMS is Enabled
Monitor is On
Try
xset -dpms
Edit: Does that turn off DPMS?
It does yes, but still nothing ![]()
Not sure if xset dpms turns it back on?
Edit: Actually it’s xset +dpms
Thanks
I really think I will just leave this all, I don’t think I’ll get it working, I’ll just save up and build a desktop and will make sure all the parts are fully supported by Linux.
Thank you @ricklinux and everyone for helping me, I really do appreciate it so much!
@anon37726204
I just wanted to check back with you on your MSI Monitor not waking from sleep mode. Are you sure you checked all the settings. On the OSD Menu of your monitor go to settings and there should be a check box for deep sleep. You want to turn that off.
I also have this problem. I believe the problem is with NVIDIA driver. Came here looking for the solution but I think I will also just switch to the AMD card.
My setup is
AMD Ryzen-5 5600X
Asrock B550 Motherboard
Nvidia 1030 Graphics card
Endeavour OS with 5.14.8 Kernel
Thanks
