Opengl using ipgpu instead dgpu
Help when I using shows igpu but with DRI_PRIME=1 shows dgpu when I started game in portproton or steam game dong using dgpu with opengl only with vulkan but vulkan don’t works igpu-uhd620 dgpu-r7 m340 gpu is works in Minecraft use hyprland with Wayland with systemd
Sorry, not sure I followed that.
So DRI_PRIME=1 works?
glxinfo | grep 'OpenGL renderer'
DIR_PRIME=1 glxinfo | grep 'OpenGL renderer'
If running through something like steam then edit the game launch options for, ex;
DRI_PRIME=1 %command%
Or is the problem that with this configuration opengl is still on the iGPU?
When I write glxinfo | grep ‘OpenGL renderer’ shows igpu but when I add DRI_PRIME=1 shows dgpu but in steam don’t working DRI_PRIME=1 i used 1,2,3,4,0 but shows only igpu it’s only when uses wine3d3d if game dvxk than shows dgpu but it’s so laggy I think game don’t wont with vulkan
How is this being applied?
Tanks you it’s working with DRI_PRIME=0 %command% but mangohud not running
