OK so here's a weird issue - Screen Flickering In KDE
My screen is flickering blinking to black when i move my mouse cursor.
Same both on my HTPC and main PC.
I just did an update and i did get an weird kernel panic error(blue one) and system rebooted.
After this my mouse issue showed up.
Luckily no bricked system. :sweat_smile:
I did reinstalld graphics drivers as well as Linux kernel + LTS after.
Rebooted
But issue persists.
Any ideas?
Logs:(From my HTPC)
https://paste.c-net.org/EclipseHistoric
Seems to be a KDE 6.8 issue. I don’t run KDE, but according to this bug report, a workaround is setting this:
> ~/.config/environment.d/99-kwin-flicker.conf:
>     KWIN_USE_BUFFER_AGE=0
>     KWIN_DRM_FORCE_GL_FINISH_PRESENT=1
>     KWIN_FORCE_SW_CURSOR=1
> ~/.config/kwinrc:
>     [Plugins]
>     shakecursorEnabled=false
Possibly related:
I had this when 6.8 was released. The update to kwin 6.8.2 fixed the flickering around the cursor for me.
OK well I’ll try that next time I’m at my HTPC.
My system is up to date so it’s not fixed yet.
I can also still reproduce the flickers/black screen with mouse movement on 6.8.2 - its not fixed.
inxi -F
  Host: 8570w Kernel: 7.2.14-arch1-1 arch: x86_64 bits: 64
  Desktop: KDE Plasma v: 6.8.2 Distro: EndeavourOS
  Type: Laptop System: Hewlett-Packard product: HP EliteBook 8570w
    v: A1029D1103 serial: <superuser required>
  Mobo: Hewlett-Packard model: 176B v: KBC Version 50.1F
    serial: <superuser required> Firmware: BIOS vendor: Hewlett-Packard
    v: 68IAV Ver. F.71 date: 04/19/2019
Battery:
  ID-1: BAT0 charge: 21.6 Wh (100%) condition: 21.6/21.6 Wh (100%) volts: 7.47
    min: 14.8
  Info: quad core model: Intel Core i7-3840QM bits: 64 type: MT MCP cache:
    L2: 1024 KiB
  Speed (MHz): avg: 1200 min/max: 1200/3800 cores: 1: 1200 2: 1200 3: 1200
    4: 1200 5: 1200 6: 1200 7: 1200 8: 1200
  Device-1: NVIDIA GK107GLM [Quadro K2000M] driver: nouveau v: kernel
  Device-2: Chicony Integrated HP HD Webcam driver: uvcvideo type: USB
  Display: wayland server: X.org v: 1.21.1.25 with: Xwayland v: 24.1.14
    compositor: kwin_wayland driver: X: loaded: modesetting dri: nouveau
    gpu: nouveau resolution: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: nouveau,swrast
    platforms: gbm,wayland,x11,surfaceless,device
  API: OpenGL v: 4.6 compat-v: 4.3 vendor: mesa v: 26.2.6-arch1.1
    renderer: NVE7
  API: Vulkan v: 1.4.363 drivers: nvk surfaces: N/A
    de: kscreen-console,kscreen-doctor wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
Hmmm, I wonder if it related to the Nvidia GPU drivers. I don’t have a Nvidia GPU.
“Common seems to be usage of the nouveau driver and nvidia cards.”
inxi -F
  Host: UM890 Kernel: 7.2.14-zen1-1-zen arch: x86_64 bits: 64
  Type: Mini-pc System: Micro (HK) Tech product: EliteMini Series v: 1.0
  Mobo: Meigao Innovation (Shen Zhen) model: HPBSD v: 1.0
    serial: <superuser required> Firmware: UEFI vendor: American Megatrends LLC.
    v: 1.06 date: 11/10/2025
  Info: 8-core model: AMD Ryzen 9 PRO 8945HS w/ Radeon 780M Graphics bits: 64
    type: MT MCP cache: L2: 8 MiB
  Speed (MHz): avg: 1512 min/max: 403/5263 cores: 1: 1512 2: 1512 3: 1512
    4: 1512 5: 1512 6: 1512 7: 1512 8: 1512 9: 1512 10: 1512 11: 1512 12: 1512
    13: 1512 14: 1512 15: 1512 16: 1512
  Device-1: Advanced Micro Devices [AMD/ATI] HawkPoint1 driver: amdgpu
    v: kernel
  Display: wayland server: Xwayland v: 24.1.14 compositor: kwin_wayland
    driver: gpu: amdgpu resolution: 3840x2160~144Hz
  API: EGL v: 1.5 drivers: radeonsi,swrast
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.2.6-arch1.1 renderer: AMD
    Radeon 780M Graphics (radeonsi phoenix ACO DRM 3.64 7.2.14-zen1-1-zen)
  API: Vulkan v: 1.4.363 drivers: radv surfaces: N/A
  Device-1: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    driver: snd_hda_intel
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor
    driver: snd_pci_ps
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio
  API: ALSA v: k7.2.14-zen1-1-zen status: kernel-api
  Server-1: PipeWire v: 1.6.10 status: active
  Device-1: Realtek RTL8125 2.5GbE driver: r8169
  IF: enp2s0 state: up speed: 2500 Mbps duplex: full mac: 38:05:25:35:82:2f
  Device-2: Realtek RTL8125 2.5GbE driver: r8169
  IF: enp3s0 state: down mac: 38:05:25:35:82:2e
  Device-3: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    driver: mt7921e
  IF: wlan0 state: down mac: 22:53:0c:80:54:d7
  IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
  IF-ID-2: virbr0 state: down mac: 52:54:00:16:a2:95
Bluetooth:
  Device-1: MediaTek Wireless_Device driver: btusb type: USB
  Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: disabled
  Local Storage: total: 3.73 TiB used: 520.13 GiB (13.6%)
  ID-1: /dev/nvme0n1 vendor: HP model: SSD FX900 Pro 4TB size: 3.73 TiB
  ID-1: / size: 3.66 TiB used: 519.78 GiB (13.9%) fs: btrfs
    dev: /dev/nvme0n1p2
  ID-2: /home size: 3.66 TiB used: 519.78 GiB (13.9%) fs: btrfs
    dev: /dev/nvme0n1p2
  ID-3: /var/log size: 3.66 TiB used: 519.78 GiB (13.9%) fs: btrfs
    dev: /dev/nvme0n1p2
  ID-1: swap-1 type: partition size: 66.68 GiB used: 0 KiB (0.0%)
    dev: /dev/nvme0n1p3
  System Temperatures: cpu: 36.8 C mobo: N/A gpu: amdgpu temp: 31.0 C
  Fan Speeds (rpm): N/A
  Memory: total: 64 GiB note: est. available: 60.61 GiB used: 5.02 GiB (8.3%)
  Processes: 391 Uptime: 16m Shell: fish inxi: 3.3.41
No it’s not. I have 3 different machines, 2 uses nvidia (3070 TI and GTX 1070). Both machines with the nvidia drivers are working just fine.
